See title, this is the error message, from the latest “manjaro-firmware” installed today
if I try to use buildiso it stops with the above error, also trying to reinstall the file it produces the same error.
try cleaning your build root
Edit - perhaps your build mirror has not yet synced (manjaro-tools.conf default to manjaro.moson.eu)
I just built an iso - no issues
buildiso -p lxqt-kwin -b stable -k linux515
==> Done [Build ISO]
--> Time compress_images: 3.45 minutes
==> Finished building [lxqt-kwin]
--> Time make_profile: 6.73 minutes
perhaps that is because I the used a not up-to-date mirror.
For some unknown reasons it has been deactivated… I can also not reinstall it due this issue. No idea, but you can activate it again, if really needed:
sudo pacman-key --list-keys "ramon@manjaro.org"
sudo pacman-key --edit-key "77DC01C9971AC3C39A0626F72C089F09AC97B894"
gpg> enable
gpg> quit
Then it works again.
Don’t you get this message in unstable branch?
$ sudo pacman-key --edit-key "77DC 01C9 971A C3C3 9A06 26F7 2C08 9F09 AC97 B894"
pub rsa4096/2C089F09AC97B894
erzeugt: 2014-09-28 verfällt: niemals Nutzung: SC
Vertrauen: marginal Gültigkeit: vollständig
*** Hinweis: Dieser Schlüssel ist abgeschaltet
sub rsa4096/33B09366293AD067
erzeugt: 2014-09-28 verfällt: niemals Nutzung: E
[vollständig] (1). Ramon Buldó <ramon@manjaro.org>
*** Hint: This Key has been disabled.
No
$ sudo pacman-key --list-keys "ramon@manjaro.org"
pub rsa4096 2014-09-28 [SC]
uid [ full ] Ramon Buldó <ramon@manjaro.org>
sub rsa4096 2014-09-28 [E]
created: 2014-09-28 expires: never usage: SC
trust: marginal validity: full
created: 2014-09-28 expires: never usage: E
[ full ] (1). Ramon Buldó <ramon@manjaro.org>
$ pacman-mirrors -G
unstable
$ sudo pacman -Syu
core 170,8 KiB 6,18 MiB/s 00:00 [##########################################################] 100%
extra 1862,5 KiB 90,9 MiB/s 00:00 [##########################################################] 100%
community 7,0 MiB 99,7 MiB/s 00:00 [##########################################################] 100%
multilib 182,7 KiB 59,5 MiB/s 00:00 [##########################################################] 100%
sublime-text 1846,0 B 4,55 KiB/s 00:00 [##########################################################] 100%
there is nothing to do
True… I see no error there… since is already installed, but if I try to reinstall it:
$ pacman-mirrors -aG 1 ✘ 5s
unstable
$ LANG=C pamac reinstall manjaro-firmware
Preparing...
Warning: manjaro-firmware-20160419-1 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To reinstall (1):
manjaro-firmware 20160419-1 extra 567.2 kB
Total download size: 567.2 kB
Apply transaction ? [y/N] y
Herunterladen von manjaro-firmware (20160419-1) gestartet
Herunterladen von manjaro-firmware (20160419-1) beendet
Überprüfe Schlüsselring... [1/1]
Integrität wird überprüft... [1/1]
Fehler: manjaro-firmware: Schlüssel "Ramon Buldó <ramon@manjaro.org>" ist deaktiviert
Entferne ungültige Dateien und wiederhole Vorgang...
Abhängigkeiten werden aufgelöst...
Interne Konflikte werden überprüft...
Error: Vorgang konnte nicht abgeschlossen werden: Ungültiges oder beschädigtes Paket (PGP-Signatur):
I only sync a couple of times a week - or if I need a specific package I don’t have - even for a brief session - so I don’t get every single change.
$ sudo pacman -S manjaro-firmware
warning: manjaro-firmware-20160419-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) manjaro-firmware-20160419-1
Total Installed Size: 2,44 MiB
Net Upgrade Size: 0,00 MiB
(1/1) checking keys in keyring [##########################################################] 100%
(1/1) checking package integrity [##########################################################] 100%
(1/1) loading package files [##########################################################] 100%
(1/1) checking for file conflicts [##########################################################] 100%
(1/1) checking available disk space [##########################################################] 100%
(1/1) reinstalling manjaro-firmware [##########################################################] 100%
(1/1) Arming ConditionNeedsUpdate...
Version seems to be correct:
LANG=C pamac info manjaro-keyring
Version : 20220503-1
Description : Manjaro PGP keyring
URL : http://manjaro.org
Licenses : GPL
Repository : core
Installed Size : 83.4 kB
Groups : --
Depends On : --
Optional Dependencies : --
Required By : pacman
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Packager : Manjaro-ARM Build Server <build@manjaro.org>
Build Date : Tue May 3 09:04:24 2022
Install Date : Tue May 3 16:51:16 2022
Install Reason : Installed as a dependency for another package
Validated By : Signature
Backup files : --
your keyring is built by manjaro-arm - so your system must be Manjaro ARM
mine is is
$ pamac info manjaro-keyring
Version : 20220421-1
Licenses : GPL
Repository : core
Installed Size : 187,1 kB
Groups : --
Depends On : --
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Packager : Philip Müller <philm@manjaro.org>
Build Date : tor 21 apr 2022 03:11:51 CEST
Install Date : lør 23 apr 2022 10:10:13 CEST
Backup files : --
$ inxi -S
Host: tiger Kernel: 5.15.35-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.24.4 Distro: Manjaro Linux
I’m not running ARM… so seems the wrong package has been pushed today
$ inxi -S
Host: manjaro Kernel: 5.15.36-1-MANJARO arch: x86_64 bits: 64
Desktop: GNOME v: 42.0 Distro: Manjaro Linux
My guess is - you hit a sync at the wrong time - the maintainer made an error and before the error was corrected you synced your system.
ok another try:
[user@manjaro ~]$ mbn update --force
:: Branch: archlinux
:: Paketdatenbanken werden synchronisiert …
core 155,9 KiB 791 KiB/s 00:00 [################################] 100%
extra 1699,9 KiB 6,08 MiB/s 00:00 [################################] 100%
community 6,6 MiB 6,49 MiB/s 00:01 [################################] 100%
:: Branch: unstable
core 170,5 KiB 528 KiB/s 00:00 [################################] 100%
extra 1862,8 KiB 4,97 MiB/s 00:00 [################################] 100%
community 7,0 MiB 6,64 MiB/s 00:01 [################################] 100%
multilib 182,5 KiB 2,79 MiB/s 00:00 [################################] 100%
:: Branch: testing
core 170,8 KiB 534 KiB/s 00:00 [################################] 100%
extra 1864,1 KiB 5,35 MiB/s 00:00 [################################] 100%
community 7,0 MiB 6,26 MiB/s 00:01 [################################] 100%
multilib 182,7 KiB 2,66 MiB/s 00:00 [################################] 100%
:: Branch: stable
core 169,1 KiB 466 KiB/s 00:00 [################################] 100%
extra 1854,2 KiB 5,03 MiB/s 00:00 [################################] 100%
community 6,9 MiB 6,36 MiB/s 00:01 [################################] 100%
multilib 182,0 KiB 2,54 MiB/s 00:00 [################################] 100%
[user@manjaro ~]$ mbn info manjaro-keyring --quiet
Branch : unstable
Repository : core
Build Date : Tue 03 May 2022 09:04:24
Branch : testing
Repository : core
Branch : stable
Repository : core
[user@manjaro ~]$ sudo pacman-mirrors --status
Local mirror status for unstable branch
Mirror #1 -- 01:59 Germany https://mirror.23m.com/manjaro/
Mirror #2 -- 13:52 Germany https://mirrors.xtom.de/manjaro/
Mirror #3 -- 12:52 Germany http://ftp.tu-chemnitz.de/pub/linux/manjaro/
Mirror #4 OK 00:02 Germany https://mirror.alpix.eu/manjaro/
Mirror #5 OK 00:12 Germany https://mirror.moson.org/manjaro/
Mirror #6 -- 00:49 Germany https://ftp.gwdg.de/pub/linux/manjaro/
Mirror #7 OK 00:02 Germany https://manjaro.moson.eu/
Mirror #8 -- 01:52 Germany https://ftp.halifax.rwth-aachen.de/manjaro/
Mirror #9 -- 06:59 Germany https://mirror.netcologne.de/manjaro/
No change… ok such a mistake could happen on unstable. Nevermind. Hopefully it gets fixed soon.
But is not only unstable right now.
But I don’t get it: Why is this key of ramon@manjaro.org
disabled on ARM?
I’m, on unstable on a desktop and even reinstalling manjaro-keyring it is still showing
“Manjaro-ARM Build Server <build@manjaro.org”
Your system will always use the first mirror even if out-of-sync
On an x86_64 system - replace your system keyring with the one from the x86_64 repo using
sudo pacman -U https://manjaro.moson.eu/pool/overlay/manjaro-keyring-20220421-1-any.pkg.tar.zst
Because there is no need for that key on ARM. Remember that ARM is - compared to Ramon - a new Manjaro development which Ramon never contributed to as packager - which makes the removal of the key a valid decision.
I’ll mention another possible cause for this.
The keyring package has been updated to revoke ramons key. We have a CI system in place, that automatically builds the package for ARM. But since it’s an any
architecture package, the maintainer might have thought that uploaded the package created on the ARM CI to the x64 would not be an issue. And I think he would be right. There should be no issue.
The issue, to me at least, seems to be that although Ramon has not packaged anything for years, there are still packages in the repository, which he has signed, like the manjaro-firmware
package. So these will now fail to install, since the key has been revoked. An oversight when updating the keyring package to revoke Ramons key, I’m sure.
There is no ARM specific manjaro-keyring
package. We have our own manjaro-arm-keyring
package and use the regular manjaro-keyring
package as well.
And the reason why @linux-aarhus does not have this issue, is likely that he has not updated/sync his repo databases yet, because the one in the repository is 20220503. At least here on my Stable branch install.
Will readd the key …
You are correct - my mirror is not up-to-date
