Error: file '/grub/i386-pc/normal.mod' not found
When booting my desktop, it displays this error:
error: file `/grub/i386-pc/normal.mod not found Entering rescue mode…
grub rescue> _
I have tried entering my BIOS, but it is frozen…
I have a win10 SSD and a Manjaro SSD so I tried disconnecting each of them before booting but no matter which is connected, it boots to the same screen.
I then tried replacing my CMOS battery… No luck.
I tried disconnecting both and plugging in a live Linux USB that I had handy. Still the same result.
I’m at a loss here. What can I do to get my desktop working again?
Edit: some outputs:
grub rescue> set
cmdpath=(hd0)
prefix=(hd0,msdos1)/grub
root=hd0,msdos1
grub rescue> ls
(hd0) (hd0,msdos1) (hd1) (hd2) (hd3) (hd3,msdos1)
(hd0,msdos1) is the only one that doesn’t return (filesystem is unknown). If I run set prefix=(hd0,msdos1)/grub then run insmod normal, then it just returns the same normal.mod error.
This is my latest available inxi output from a previous forum post. I cannot access the current output for obvious reasons.
Once I was able to boot to Manjaro, I updated the inxi output:
$ inxi -zv8         ✔
  Kernel: 5.10.206-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=cf91cf20-ab16-4e38-abc6-4222c1cf2929 ro quiet apparmor=1
    security=apparmor resume=UUID=a3fd6cf2-dd64-4f65-bc0b-81cd05ad3f2f
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
    v: 5.113.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux
    base: Arch Linux
  Type: Desktop System: ASUS product: All Series v: N/A
    serial: <superuser required>
  Mobo: ASUSTeK model: SABERTOOTH Z97 MARK 1 v: Rev 1.xx
    serial: <superuser required> part-nu: All uuid: <superuser required>
    UEFI: American Megatrends v: 2702 date: 10/27/2015
  System RAM: total: 16 GiB available: 15.57 GiB used: 3.13 GiB (20.1%)
  Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
  Device-1: DIMM_A1 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: curr: 1.65 min: 2 max: 2 width (bits): data: 64
    total: 64 manufacturer: 1302 part-no: 1333EL Series serial: N/A
  Device-2: DIMM_A2 type: DDR3 detail: synchronous size: 4 GiB
  Device-3: DIMM_B1 type: DDR3 detail: synchronous size: 4 GiB
  Device-4: DIMM_B2 type: DDR3 detail: synchronous size: 4 GiB
  Info: model: Intel Core i7-4790 bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3616 high: 3825 min/max: 800/4000 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 3505 2: 3285 3: 3716
    4: 3825 5: 3656 6: 3530 7: 3615 8: 3799 bogomips: 57620
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs
    ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
    msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep
    smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
    tsc_adjust tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
    prctl and seccomp
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
    driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-01; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 108 s-size: 1054x342mm (41.50x13.46")
    s-diag: 1108mm (43.63")
  Monitor-1: DP-1 pos: right res: 1920x1080 hz: 60 dpi: 81
    size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
  Monitor-2: DVI-D-0 pos: primary,left res: 2560x1440 dpi: 109
    size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
    6GB/PCIe/SSE2 memory: 5.86 GiB
  API: Vulkan v: 1.3.274 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1060 6GB driver: nvidia v: 545.29.06 device-ID: 10de:1c03
    surfaces: xcb,xlib
  Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK 9
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
    class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Device-3: Creative Labs EMU20k2 [Sound Blaster X-Fi Titanium Series]
    driver: snd_ctxfi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 05:00.0 chip-ID: 1102:000b class-ID: 0403
  API: ALSA v: k5.10.206-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel
    port: f040 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
    vendor: ASUSTeK AM1I-A driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  Device-3: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 8086:2526 class-ID: 0280
  IF: wlp10s0 state: up mac: <filter>
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-8:3
    chip-ID: 8087:0025 class-ID: e001
  Local Storage: total: 1.82 TiB used: 137.24 GiB (7.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000524AS
    tech: HDD rpm: 7200 serial: <filter> fw-rev: JC45 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 500GB
  ID-1: / raw-size: 448.33 GiB size: 440.22 GiB (98.19%)
    used: 137.24 GiB (31.2%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: cf91cf20-ab16-4e38-abc6-4222c1cf2929
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: E177-9383
  ID-1: swap-1 type: partition size: 17.14 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdc3 maj-min: 8:35 label: N/A
    uuid: a3fd6cf2-dd64-4f65-bc0b-81cd05ad3f2f
  ID-1: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: N/A
    uuid: 124B-1E93
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 465.45 GiB fs: ntfs label: N/A
    uuid: 7A4605234604E1AD
  ID-4: /dev/sdb1 maj-min: 8:17 size: 931.5 GiB fs: ext4 label: Spare_HDD
    uuid: b20f320b-bf4a-4a20-a58f-a788a7e0ee62
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 8087:8009 class-ID: 0900
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Device-1: 3-6:2 info: KnoblesseOblige Freebird60 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: adad:fb60 class-ID: 0300
  Device-2: 3-8:3 info: Intel Wireless-AC 9260 Bluetooth Adapter
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-3: 3-14:4 info: Laview Mionix NAOS 8200 [STM32F103 MCU]
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 200mA
    chip-ID: 22d4:1301 class-ID: 0300
  Hub-6: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 48.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1710 libs: 523 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    2: https://manjaro.kyberorg.fi/stable/$repo/$arch
    3: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    4: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    5: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    6: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    7: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    9: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    10: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    12: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    13: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    14: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    15: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    16: https://manjaro.ynh.ovh/stable/$repo/$arch
    17: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    18: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    20: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    21: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    22: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://repos.silknet.com/manjaro/stable/$repo/$arch
    24: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    25: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    26: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    27: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    28: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    29: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
    30: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    31: http://manjaro.mirror.ac.za/stable/$repo/$arch
    32: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    33: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    34: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    35: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    36: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    37: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    38: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    39: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    40: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    41: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    42: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    43: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    44: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    45: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    46: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    47: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    48: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    50: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    51: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    52: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    53: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    54: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    55: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    56: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    57: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    58: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    59: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    60: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    61: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    62: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    63: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    64: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    65: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    66: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    67: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    68: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    69: https://linorg.usp.br/manjaro/stable/$repo/$arch
    70: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    71: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    72: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    73: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    74: https://mirrors2.manjaro.org/stable/$repo/$arch
    75: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    76: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    77: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    78: https://mirror.23m.com/manjaro/stable/$repo/$arch
    79: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    80: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    81: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    82: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    83: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    84: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    85: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    86: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    87: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    88: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    89: https://mirror.init7.net/manjaro/stable/$repo/$arch
    90: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    91: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    92: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    93: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    94: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    95: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    96: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    97: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    98: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    99: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    100: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    101: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    102: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    103: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    104: https://manjaro.kurdy.org/stable/$repo/$arch
    105: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    106: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    107: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    108: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    109: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    110: http://manjaro.grena.ge/stable/$repo/$arch
    111: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    112: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    113: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    114: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    115: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    116: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    117: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 256
  1: cpu: 45.5% command: firefox pid: 2016 mem: 512.1 MiB (3.2%)
  2: cpu: 13.9% command: firefox pid: 2516 mem: 339.6 MiB (2.1%)
  3: cpu: 12.7% command: firefox pid: 3184 mem: 217.4 MiB (1.3%)
  4: cpu: 5.5% command: xorg pid: 1044 mem: 119.6 MiB (0.7%)
  5: cpu: 4.6% command: kwin_x11 pid: 1320 mem: 134.4 MiB (0.8%)
  Memory top: 5 of 256
  1: mem: 581.2 MiB (3.6%) command: plasmashell pid: 1352 cpu: 2.9%
  2: mem: 512.1 MiB (3.2%) command: firefox pid: 2016 cpu: 45.5%
  3: mem: 339.6 MiB (2.1%) command: firefox pid: 2516 cpu: 13.9%
  4: mem: 234.0 MiB (1.4%) command: firefox pid: 2214 cpu: 4.4%
  5: mem: 217.4 MiB (1.3%) command: firefox pid: 3184 cpu: 12.7%
  Processes: 256 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 0 hibernate: platform
    avail: shutdown,reboot,suspend,test_resume image: 6.22 GiB
    daemons: upowerd,org_kde_powerdevil Init: systemd v: 255
  Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.21 running-in: konsole inxi: 3.3.32
Have you tried restoring grub?
And enter the uefi once more and set everything to EFI, disable CSM or compatibility mode. A system sold with win10 is at most couple of years old and should be uefi, and grub should not try to locate anything 386. It might be if the uefi is confusing it.
Check the settings in uefi and reinstall grub in efi mode.
If I boot to UEFI, it’s frozen. I tried a different keyboard and mouse but nothing works. Can’t access the BIOS unfortunately.
Can you boot (in UEFI mode) to a Manjaro Installer; whether it be DVD, ISO or USB?
If you can, then I refer you back to the question from @Teo …
Your system seems to have been booting in Legacy (BIOS) mode, and running only 32-bit operating systems (a guess). Is your system capable of running a 64-bit OS in UEFI mode?
Some more information might be helpful to someone. Please post the output of the following commands, if you can manage to boot via the Manjaro Installer (in any mode), and enter chroot:
System information:
inxi --admin --verbosity=8 --filter --no-host --width
Recent logs:
journalctl --boot=-1 --priority=3 --catalog --no-pager
Cheers.
My BIOS freezes so I can’t boot or change the boot settings.
I found a manual to reset the CMOS battery so I could reset my BIOS.
Did it help?
When you can get to it
it’s easiest to just remove the battery for a few minutes (or hours, to be on the safe side)
Then install it again (preferrably a new one).
Then you’ll have to set your BIOS/Uefi to defaults and then set it to the settings you need/want …
and then proceed to boot any OS
I reset my BIOS, and disabled secure boot. Then, I was able to boot into Manjaro!
The first thing that I did was update the inxi output above and run $ pacdiff -o which returned the following:
$ pacdiff -o
/usr/share/icons/default/index.theme.pacnew
/etc/shells.pacnew
/etc/locale.gen.pacnew
/etc/default/grub.pacnew
/etc/pamac.conf.pacnew
/etc/mkinitcpio.conf.pacnew
/etc/pacman.conf.pacnew
/etc/sane.d/canon_lide70.conf.pacnew
/etc/sane.d/escl.conf.pacnew
/etc/pam.d/sddm.pacnew
So, I found this forum post and then went into the pamac-manager gui, disabled AUR, and kicked off a multi-GB update which is in progress now…
You are (at some point, it is not urgent) supposed to compare the content of the new files with that of the existing files
and incorporate the changes into the actually used files
Those .pacnew files do need to be merged. You may find some useful info/links here.
I wonder if this is the cause of some of the issues where people report “missing” icons?
I have never seen a pacnew for anything outside of /etc except for a few pacsaves in /usr…
I have that too:
cat /usr/share/icons/default/index.theme
[Icon Theme]
Inherits=Adwaita
cat /usr/share/icons/default/index.theme.pacsave
[icon theme]
Inherits=xcursor-breeze
I would not know which one to choose - it was all working fine with the original …
Mine’s this (no new .pacsave or .pacnew here after this update):
[Icon Theme]
Inherits=Adwaita
… in case that’s of any importance? I’d have to check an old .ISO image.
Any news on progress …? :smiley:
The update was a success! There’s just some AUR packages that error out but that’s something I can handle in a separate ticket I think since the core issue has been resolved. :slight_smile:
