I had an Ubuntu dualboot next to Windows and wanted to replace Ubuntu by Manjaro by deleting the partition where Ubuntu was located from Windows in the “disk management”.
However, when I rebooted my computer, I could not access either Windows or Ubuntu (which is quite logical). After some attempts to recover Windows I decided to remove my Bootsecure, to delete Windows because I don’t really need it and to replace it by Manjaro KDE. So I booted on my USB key and during the installation I chose the option to remove everything and put Manjaro. However after finishing the installation and reboot I got this error:
ERROR: device 'UUID=number" not found. Skipping fsck.
mount: /new_root: can't find UUID=number.
You are now being dropped into an emergency shell.
sh: can't access tty: job control turned off
I looked at a lot of pages related to this error. I understood that the grub was broken. I managed to reinstall a grub where I can select my Manjaro. It seems to recognize the installation I did of Manjaro but I immediately get the error above.
This is what the command returns to me lsblk -f
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda iso9660 Joliet Extension MANJARO_KDE_2112 2021-09-04-18-07-46-00 0 100% /run/miso/bootmnt
├─sda1 iso9660 Joliet Extension MANJARO_KDE_2112 2021-09-04-18-07-46-00
└─sda2 vfat FAT12 MISO_EFI F9F3-0D0C
nvme0n1
├─nvme0n1p1 vfat FAT32 NO_LABEL F151-C1D1
├─nvme0n1p2 ext4 1.0 d7088230-cae3-49c4-a3ac-0b972e930e48
└─nvme0n1p3 ext4 1.0 c0624f10-8cb5-4500-8c83-3da637c4801f
Does anyone have an idea to save my life? I’ve looked at many similar problems on forums but nothing seems to work for me.
Thank you for reading.
