natrim
8 September 2020 08:43
1
Hi Guys,
I am trying to do a key refresh
sudo pacman-key --refresh-keys
I get
Could you please tell me how to find what local key cannot be updated?
Note:
I have followed the pacman troubleshooting in manjaro wiki already without success.
Thanks in advance.
natrim
8 September 2020 09:42
3
Hi thanks,
I executed this (I saw it in another post in the Forum)
sudo pacman-key --refresh-keys -u --keyserver hkps.pool.sks-keyservers.net
gpg: refreshing 140 keys from hkp://hkps.pool.sks-keyservers.net
(hkp instead of hkps)
However when running
it shows a different message (connecting using hkps)
gpg: refreshing 140 keys from hkps://hkps.pool.sks-keyservers.net
Should I be concerned about that difference hkp or hkps?
Would you know how to make hkps to work?
Thanks
no is as http:// and https://
natrim
8 September 2020 09:52
5
I know hkp and hkps relate to tls encryption being used or not
What I mean is… is it safer to use hkps (as it is safer to use https) than hkp?
And if so how can I enforce hkps instead of hkp?
Thanks.
system
Closed
11 September 2020 09:52
6
