hello,
whenever I’m using print then print comes as long unknown scripts code on paper .please provide the solution why it has coming in unknown language script
You have provided no information about your system. Is the driver installed? Is Cups installed? Is CUPS enabled? What have you tried so far?
Driver is available from AUR and has been updated as recently as 3/16/2021:
https://aur.archlinux.org/packages/epson-inkjet-printer-201401w
hello, thanks,
my modal is sony svf15213sn, 8GB I did download this which had mentioned by you and install them from the PPD file instead drive option. and successfully install the driver and printer, but it hasn’t work looks like it off mode.
please help me provide step by step method:
