Hi There !!
I would like to know how to enable Japanese characters as seen in the original matrix. I have installed one random Japanese fonts found on Arch Package but I guess I would have to install some specific package for that.
I have less knowledge about dealing with fonts & locale thing
I found this arch thread but everything went over my head
Can anyone help me ?
Try the GLMatrix or XMatrix as found in xscreensaver
cmatrix --help
-c: Use Japanese characters as seen in the original matrix. Requires appropriate fonts
@ishaan2479
Gives me black screen nothing will be displayed
cmatrix --help
Requires appropriate fonts being the keyword which I have no idea of
@linux-aarhus
Isn’t there any ways to enable japanese in Cmatrix ?
- Unicode Japanese Characters · Issue #57 · abishekvashok/cmatrix · GitHub
- Install japanese fonts for cmatrix - #2 by cges30901
There is always the noto-fonts-cjk package - I don’t know it that helps.
Seems like I am not the only one haha…
I tried looking for GLmatrix and Xmatrix
Can you tell me what package do they belong to ?
I have installed xscreensaver but trying to execute glmatrix or xmatrix in terminal doesnot work
It’s a screen saver - use xscreensaver-settings to test and to setup
You can easily implement on demand by means of a hotkey combination - where N is the program in the list in .xscreensaver
xscreensaver-command -select N
Example .xscreensaver
# XScreenSaver Preferences File
# Written by xscreensaver-settings 6.03 for fh on Fri Mar 25 15:17:55 2022.
# https://www.jwz.org/xscreensaver/
timeout: 0:10:00
cycle: 0:10:00
lock: False
lockTimeout: 0:00:00
passwdTimeout: 0:00:30
visualID: default
installColormap: True
verbose: False
splash: True
splashDuration: 0:00:05
demoCommand: xscreensaver-settings
nice: 10
fade: True
unfade: True
fadeSeconds: 0:00:03
ignoreUninstalledPrograms:False
font:
dpmsEnabled: False
dpmsQuickOff: False
dpmsStandby: 2:00:00
dpmsSuspend: 2:00:00
dpmsOff: 4:00:00
grabDesktopImages: True
grabVideoFrames: False
chooseRandomImages: False
imageDirectory:
mode: one
selected: 0
textMode: file
textLiteral: XScreenSaver
textFile:
textProgram: fortune
textURL: https://en.wikipedia.org/w/index.php?title=Special:NewPages&feed=rss
dialogTheme: default
programs: \
GL: xmatrix -root -small -phone 004980923309094
In the above example the xmatrix is the first - so this command will run the xmatrix (note the selected: 0 which is N-1) so if you have selected a specific screensaver you can force run it by supplying N as selected + 1
xscreensaver-command -select 1
More info using
xscreensaver-command -h
or
man xscreensaver-command
I use unimatrix from github: GitHub - will8211/unimatrix: Python script to simulate the display from "The Matrix" in terminal. Uses half-width katakana unicode characters by default, but can use custom character sets. Accepts keyboard controls while running. Based on CMatrix.
sudo curl -L https://raw.githubusercontent.com/will8211/unimatrix/master/unimatrix.py -o /usr/local/bin/unimatrix
sudo chmod a+rx /usr/local/bin/unimatrix
Wow !!
Loved unimatrix so much
Thank you ![]()
