veera
July 3, 2021, 1:03pm
1
I have installed Manjaro Linux version - “manjaro-kde-21.0.7-210614-linux510” recently in my Lenovo laptop. All are works good Except Wifi. I am unable to enable the wifi. the checkbox is non clickable.
I have tried some methods but not working…
Installed headers but not sure what should be added XXXX - “pamac build XXXX-dkms-git”
cmd: uname -a
Linux vsnu 5.10.42-1-MANJARO #1 SMP PREEMPT Thu Jun 3 14:37:11 UTC 2021 x86_64 GNU/Linux
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
Can someone help me on this?
It would help if you would provide additional information (full inxi output) about your system, even though you might not think that it is necessary. Is it possible that there is a physical switch on that laptop that turns wifi on and off? Can you post the results of:
rfkill list
Please read:
Welcome to Manjaro!
To allow all of us helpful gurus on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone probably linked you to this tutorial, so if you’re reading this in response to a question, please click the green link above this text to bring you to the full and unabridged text of the tutorial…
veera
July 4, 2021, 3:50am
3
Thanks for your quick reply. There is no physical switch to turn on the Wi Fi. Added inxi and rfkill list below
ystem:
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64
root=UUID=880261d6-1f2d-4026-bfa1-f3005d0d0e28 rw quiet apparmor=1
security=apparmor resume=UUID=3bed07ec-9fe7-4495-8e51-d2bf9cfc9e31
udev.log_priority=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 20042 v: Lenovo G560 serial: <filter>
Mobo: LENOVO model: N/A serial: <filter> BIOS: LENOVO v: 29CN41WW(V2.18)
date: 02/02/2012
ID-1: BAT1 charge: 11.3 Wh (39.8%) condition: 28.4/47.5 Wh (59.7%)
volts: 10.4 min: 11.1 model: LG PABAS024 type: Li-ion serial: <filter>
status: Discharging
RAM: total: 1.87 GiB used: 1.41 GiB (75.5%)
Info: Dual Core model: Intel Core i3 M 380 bits: 64 type: MT MCP
arch: Nehalem family: 6 model-id: 25 (37) stepping: 5 microcode: 7 cache:
L2: 3 MiB bogomips: 20225
Speed: 1907 MHz min/max: 933/2533 MHz Core speeds (MHz): 1: 1907 2: 1855
3: 1531 4: 1647
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flush_l1d fpu fxsr ht ibpb
ibrs lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pdcm pebs pge pni popcnt pse pse36 pti rdtscp rep_good sep ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc vme xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Device-1: NVIDIA GT218M [GeForce 310M] vendor: Lenovo driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:0a70 class-ID: 0300
Device-2: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 2-1.3:3
chip-ID: 5986:0148 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: NVA8 v: 3.3 Mesa 21.1.2 direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Device-2: NVIDIA High Definition Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Lenovo
driver: ath9k v: kernel port: 5000 bus-ID: 06:00.0 chip-ID: 168c:002b
class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 2000 bus-ID: 07:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp7s0 state: down mac: <filter>
IF-ID-1: enp0s29u1u4 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Device-1: Qualcomm Android type: USB driver: rndis_host v: kernel
bus-ID: 2-1.4:5 chip-ID: 05c6:aaff class-ID: 0a00 serial: <filter>
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 465.76 GiB used: 25.71 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500325AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: LVM1 scheme: GPT
Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DS8A8SH rev: KL31
dev-links: cdrom
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 9.98 GiB (10.2%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 880261d6-1f2d-4026-bfa1-f3005d0d0e28
ID-2: /boot raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 60 MiB (5.9%)
fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL uuid: 7AFC-0529
ID-3: /home raw-size: 356.74 GiB size: 350.07 GiB (98.13%)
used: 14.84 GiB (4.2%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 03dae9a9-5597-4ad3-9e20-984469e7efe0
ID-1: swap-1 type: partition size: 8 GiB used: 854.3 MiB (10.4%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3bed07ec-9fe7-4495-8e51-d2bf9cfc9e31
ID-1: /dev/sda5 maj-min: 8:5 size: 8 MiB fs: <superuser required> label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.3:3 info: Acer Lenovo EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:0148
class-ID: 0e02
Device-2: 2-1.4:5 info: Qualcomm Android type: Bluetooth,CDC-Data
driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 2-1.6:4 info: Realtek USB 2.0 multicard reader type: Mass Storage
driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0bda:0158 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 54.0 C mobo: N/A gpu: nouveau temp: 61.0 C
Processes: 205 Uptime: 1h 09m wakeups: 1 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1215 pacman: 1208 lib: 324
flatpak: 0 snap: 7 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
RFKILL LIST
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
moson
July 4, 2021, 8:18am
4
Are you sure about that? Because:
veera:
Hard blocked: yes
veera
July 4, 2021, 8:28am
5
You are correct. that was my mistake. Sorry… … I did not noticed. I am able to connect Wi Fi now.
Thank you so much @moson and @jrichard326
system
Closed
July 19, 2021, 8:28am
6
