enable_systemd_timers=('fstrim' 'pkgfile-update')
is in profile.conf but calamares did not enable them.
may you post the output of
systemctl list-timers
first
Ran “systemctl status *.timer” not there.
Will have to build iso again to get info as they are not there. I put them in enable_systemd and calamares added service to them so they don’t work.
Below Systemctl you can see they are in but not enabled
systemctl status fstrim.timer
○ fstrim.timer - Discard unused blocks once a week
Loaded: loaded (/usr/lib/systemd/system/fstrim.timer; disabled; preset: disabled)
Active: inactive (dead)
Trigger: n/a
Triggers: ● fstrim.service
Docs: man:fstrim
systemctl status pkgfile-update.timer
○ pkgfile-update.timer - pkgfile database update timer
Loaded: loaded (/usr/lib/systemd/system/pkgfile-update.timer; disabled; preset: disabled)
Trigger: n/a
Triggers: ● pkgfile-update.service
@philm @oberon Looking in calamares log it does not mention enable_ systemd_timers at all, has it ever worked?
see Error in buildiso and problem with calamares for solution
