Im trying to find a way to enable the fingerprint scanner built in to this laptop, but I cant find anything about it as a option in my settings at all. Im pretty new to Linux so I dont even know how to look for anything to do with this type of thing in the terminal.
Thank you.
Hi and welcome to the Forum
Help others to help you better by:
Providing system info about your hardware by posting program output instead of describing your hardware.
Use new lines when a sentence ends, so it is better readable and followable by others.
If english is not your native language please see:
English [HowTo] Become multi-language on internet
Türkçe [Nasıl] İnternette çok dilli olun
Deutsch [Wie man] Werden Sie im Internet mehrsprachig
Français [Comment] Devenir multilingue sur internet
Española [Cómo] Conviértete en multilenguaje en Internet
中文 [如何] 成为互联网上的多语言
Italiana [Come] Diventa multilingua su internet
русский язык [Как] Стать многоязычным в Интернете
Please read and follow all advice in this thread:
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links when…
Especially:
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to f…
If you often have a need to do a “Hard reset ” or “Power off ” to get back to your system, then avoid that when possible by following:
Difficulty: ★★☆☆☆
This tutorial was created because people are using a hard power off during freezes, so this will teach you how to turn off your computer when everything is frozen using softer means.
So whenever you see someone saying they had to “Power Off” or “Hard Reset” their system without doing a REISUB, please send them here!
If you’re reading this in response to a question, please click the green link above this text to bring you to the full unabridged text of the tutorial…
Without actual info on your laptop no one will be able to assist you in a meaningful way…
