Hi, I have a Brother HL-L2350DW printer and I have installed the aur driver but I can’t get CUPS or Gnome Printers to add that driver to make the printer work. What do I have to do to add that printer to the system? Thanks for Manjaro.
I cannot tell you how to use the GUI tools (the Cups web interface or the Manjaro Printer GUI) to choose the driver which you have installed.
It’s normally a simple and intuitive process - I do not remember the specifics.
… provided that the driver is actually there …
However:
the printer appears to be a network capable printer - which means you don’t need any driver at all - if you configure it as a network printer.
What I remember of the process:
avahi needs to be active - not just present
Perhaps this here helps:
the whole Article, not just the portion about Brother
and I found this (in EOS forum):
Printer Brother HL-L2350DW may not be connected - #9 by joekamprad - Newbie - EndeavourOS
Only mentioning this because I cannot remember if it’s enabled by default or not, anyway you may need to enable the systemd avahi daemon. I personally do not have a Brother printer, but I did recently buy a Canon printer and it didn’t work until I remembered that I had masked avahi
Somebody requested support for the same printer a few years ago. Maybe it helps
There does seem to be a driver for it in the AUR:
$ pamac search L2350
brother-hll2350dw 4.0.0-2 AUR
Brother HL-L2350DW CUPS driver
Which can be easily installed using:
pamac build brother-hll2350dw
Hope it helps!
a Reminder: While use of the AUR is possible, it’s neither recommended nor supported. See:
Hello, Thank you all for your help. The driver is installed but CUPS does not detect the driver and in the list of printers to choose a .ppd file does not appear. I have decided to control the printer through the mobile with the native application of Brother for android. Thank you very much.
I am by no means an expert, but I can recommend:
https://wiki.archlinux.org/title/CUPS
This helped me set up my printer and it was the first one I’ve ever had on Linux.
Installing the driver was part of the process to get the server to work. I did the following:
- By following the steps at Printing - Manjaro I ran the commands listed below:
sudo gpasswd -a your_username sys
sudo systemctl enable --now cups.service
sudo systemctl enable --now cups.socket
sudo systemctl enable --now cups.path
sudo systemctl enable --now avahi-daemon.service
- Then ran the following commands to install the driver:
pamac update --force-refresh
pamac update --aur
- Configured the printer using the “Print Settings” app (aka the CUPS Desktop Interface).
I was able to print the documents successfully ![]()
