I originally had electron37, then electron38 arrived, and now eletron39. What is it? I saw online that it’s a way to run Javascript apps, but I don’t create apps. Can I uninstall it? Right now, the system is suggesting I update electron-castlab-bin v39.1.0+wvcus-1. Do I need it?
inxi -v7azy
Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=9ba4fe53-daa3-4374-953c-194203898f06 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
Type: Laptop System: Dell product: Vostro 3558 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 05W6N2 v: A00 serial: <superuser required> part-nu: 06C1
uuid: <superuser required> Firmware: UEFI vendor: Dell v: A17
date: 09/11/2020
ID-1: BAT0 charge: 8.5 Wh (100%) condition: 8.5/41.4 Wh (20.5%) volts: 16.44
min: 14.8 model: LGC DELL 991XP66T66T type: Li-ion serial: <filter> charging:
status: full control: start: 50% end: 90% type: adaptive
avail: adaptive,custom,standard,trickle cycles: N/A
System RAM: total: 8 GiB available: 7.67 GiB used: 3.74 GiB (48.7%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: DIMM A type: DDR3 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Hynix/Hyundai part-no: HMT451S6BFR8A-PB serial: <filter>
Device-2: DIMM B type: DDR3 detail: synchronous size: 4 GiB
manufacturer: Crucial part-no: CT51264BF160B.C16F serial: <filter>
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 500/1900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 15966
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs intel_pt invpcid lahf_lm lm
mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Microdia Integrated Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-5:2 chip-ID: 0c45:6710
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c5 built: 2014 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
device-ID: 8086:1616 memory: 7.49 GiB unified: yes
API: Vulkan v: 1.4.321 layers: 1 device: 0 type: integrated-gpu name: Intel
HD Graphics 5500 (BDW GT2) driver: mesa intel v: 25.2.3-arch1.2
device-ID: 8086:1616 surfaces: N/A
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:08b3 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-6:3 chip-ID: 8087:07dc
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 111.79 GiB used: 49.86 GiB (44.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C1
dev-links: cdrom
ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 22.16 GiB (56.7%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: manjaro
uuid: 9ba4fe53-daa3-4374-953c-194203898f06
used: 5.5 MiB (1.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 67E1-1A00
ID-3: /home raw-size: 44.79 GiB size: 43.54 GiB (97.20%)
used: 27.69 GiB (63.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: home
uuid: cc103fd9-908c-44ef-a10f-3e89995738eb
ID-1: swap-1 type: file size: 4 GiB used: 267.1 MiB (6.5%) priority: -2
file: /swapfile
ID-1: /dev/sda4 maj-min: 8:4 size: 17 GiB fs: ext4 label: Voyager
uuid: e957a9b8-5817-4ef1-9117-ea64584383c2
ID-2: /dev/sda5 maj-min: 8:5 size: 9.31 GiB fs: ext4 label: N/A
uuid: fe4cad98-8057-4aa1-8e78-0fe2ccf5b1e3
ID-3: /dev/sda6 maj-min: 8:6 size: 400.4 MiB fs: vfat label: N/A
uuid: 6977-22C7
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 2-1:8 info: HP DeskJet 3700 series type: printer driver: N/A
interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 2mA chip-ID: 03f0:0653 class-ID: 0701 serial: <filter>
Device-2: 2-5:2 info: Microdia Integrated Webcam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0c45:6710 class-ID: 0e02
Device-3: 2-6:3 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
Device-4: 2-8:4 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 47.0 C mobo: N/A sodimm: 33.0 C
Fan Speeds (rpm): cpu: 0 fan-2: 0 fan-3: 0 fan-4: 0
Processes: 208 Power: uptime: 6h 42m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 3.05 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1500 libs: 392 tools: pamac pm: flatpak pkgs: 0
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.3.3
running-in: konsole inxi: 3.3.40
Community assistant edit: something very wrong about inxi formatting, tried to fix it
eduardolp3:
Can I uninstall it?
Depends on whether or not anything depends on it. For the version(s) of electron installed, you can check with pacman -Qi:
pacman -Qi electron37
and look for the Required By : part. If nothing requires it, probably safe to remove it.
And electron is a framework for developing apps: Electron (software framework) - Wikipedia
jofi
1 December 2025 16:28
3
I’m sure one could post some pacman -xyz to show a package’s dependency. I prefer GUI tools, so in Pamac or “Add/Remove Software” you can search for the package and show its details like “Install Reason”. The package you mention is only listed in the AUR which is something different. Anyway, you can’t break anything by trying to remove the package. If there is a hard dependency you get an error dialog telling you so. If it is an optional dependency you get a warning dialog telling you so, and you can still cancel the operation at this point.
It’s an AUR package.
So, by definition, nothing crucial.
Something does require it, probably.
Another AUR package - nothing from the repos will be asking for that.
This is something you have installed (from the AUR) and only you can decide if you need it.
That said, all software sourced via the AUR must be rebuilt sooner or later – it’s seldom ever “set and forget”.
Keep in mind the usual warnings that the AUR is not officially supported on Manjaro (or Arch Linux), and that if it is used, switching to the Unstable branch is generally recommended.
https://wiki.manjaro.org/index.php/Switching_Branches
TL:DR
DISCLAIMER: AUR packages are user produced content. Any use of the provided files is at your own risk.
sudo pacman-mirrors -aS unstable
sudo pacman -Syu base-devel
When you sync your system any CUSTOM package may cease to function without warning OR your system may cease to function due to a CUSTOM package - therefore one must remove all CUSTOM packages before an issue can be validated as related to Manjaro.
custom packages - unsupported - you are on your own!
Examples
→ Spectac…
eduardolp3:
No you don’t need it.
Just don’t install apps that depend on it. There are plenty that don’t.
Adding to other already correct answers, lazy programmers these days choose to develop with Electron to get instant cross platform result while coding in a web development fashion using JavaScript. It’s essentially a Chrom(e|ium) browser, as you can check with [h|b]top when you run such applications. Here are some of them:
Slack
Discord
Visual Studio Code
WhatsApp Desktop
Etcher
Mailspring
MS Teams
Postman
Signal
So the need is indirect. If you use any of these apps, they will have dependency on it, sometimes multiple version of it. The bad news: as much as I hate it for being resource hog, some apps just don’t provide any other options.
jofi:
I prefer GUI tools
If the electron packages are no longer needed by another package they will be listed as orphan packages in Pamac GUI
Users that prefer CLI tools can remove orphan packages with:
pamac remove --orphans
Manjaro Wiki - Pamac - Dealing with Orphaned packages
Or
sudo pacman -Rs $(pacman -Qdtq)
Manjaro Wiki - Pacman - Viewing and Removing Orphans
Actually Signal Desktop does not depend on Electron. I have Signal Desktop and Zero installed copies of Electron.
How well the Signal GUI runs on my system is another matter all together.
Not trying to ruin your confidence, but feel free to check:
$ pacman -Ql signal-desktop
On Arch Linux derivatives, Electron is bundled instead of listed as dependency. This avoids incompatible version problem but yes, you now have multiple copies of Electron, possibly of the same version.
You can also inspect `[h|b]top` as I suggested above, the process tree will look familiar if you’re used to seeing one from Chrom(e|ium) and other derivatives, e.g. Edge.
pamac info signal-desktop
Version : 7.80.1-1
Description : Signal Private Messenger for Linux
URL : https://signal.org
Licenses : AGPL-3.0-only
Repository : extra
Installed Size : 459.2 MB
Groups : --
Depends On : alsa-lib libasound.so=2-64 at-spi2-core
libatk-bridge-2.0.so=0-64 cairo libcairo.so=2-64 dbus
libdbus-1.so=3-64 expat libexpat.so=1-64 gcc-libs glib2
libgio-2.0.so=0-64 glibc gtk3 hicolor-icon-theme libcups
libdrm libnotify libpulse libx11 libxcb libxcomposite
libxdamage libxext libxfixes libxkbcommon
libxkbcommon.so=0-64 libxrandr mesa nspr nss pango
libpango-1.0.so=0-64 systemd-libs libudev.so=1-64
Optional Dependencies : xdg-desktop-portal: Screensharing with Wayland [Installed]
Required By : --
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Packager : kpcyrd <kpcyrd@archlinux.org>
Build Date : Wed 26 Nov 2025 08:51:27
Install Date : Tue 02 Dec 2025 08:54:31
Install Reason : Explicitly installed
Validated By : Signature
Backup files : --
signal-desktop /usr/
signal-desktop /usr/bin/
signal-desktop /usr/bin/signal-desktop
signal-desktop /usr/lib/
signal-desktop /usr/lib/signal-desktop/
signal-desktop /usr/lib/signal-desktop/LICENSE.electron.txt
signal-desktop /usr/lib/signal-desktop/LICENSES.chromium.html
signal-desktop /usr/lib/signal-desktop/chrome-sandbox
signal-desktop /usr/lib/signal-desktop/chrome_100_percent.pak
signal-desktop /usr/lib/signal-desktop/chrome_200_percent.pak
signal-desktop /usr/lib/signal-desktop/chrome_crashpad_handler
signal-desktop /usr/lib/signal-desktop/icudtl.dat
signal-desktop /usr/lib/signal-desktop/libEGL.so
signal-desktop /usr/lib/signal-desktop/libGLESv2.so
signal-desktop /usr/lib/signal-desktop/libffmpeg.so
signal-desktop /usr/lib/signal-desktop/libvk_swiftshader.so
signal-desktop /usr/lib/signal-desktop/libvulkan.so.1
signal-desktop /usr/lib/signal-desktop/locales/
signal-desktop /usr/lib/signal-desktop/locales/af-ZA.pak
signal-desktop /usr/lib/signal-desktop/locales/af.pak
signal-desktop /usr/lib/signal-desktop/locales/am.pak
signal-desktop /usr/lib/signal-desktop/locales/ar.pak
signal-desktop /usr/lib/signal-desktop/locales/az-AZ.pak
signal-desktop /usr/lib/signal-desktop/locales/bg-BG.pak
signal-desktop /usr/lib/signal-desktop/locales/bg.pak
signal-desktop /usr/lib/signal-desktop/locales/bn-BD.pak
signal-desktop /usr/lib/signal-desktop/locales/bn.pak
signal-desktop /usr/lib/signal-desktop/locales/bs-BA.pak
signal-desktop /usr/lib/signal-desktop/locales/ca.pak
signal-desktop /usr/lib/signal-desktop/locales/cs.pak
signal-desktop /usr/lib/signal-desktop/locales/da.pak
signal-desktop /usr/lib/signal-desktop/locales/de.pak
signal-desktop /usr/lib/signal-desktop/locales/el.pak
signal-desktop /usr/lib/signal-desktop/locales/en-GB.pak
signal-desktop /usr/lib/signal-desktop/locales/en-US.pak
signal-desktop /usr/lib/signal-desktop/locales/es-419.pak
signal-desktop /usr/lib/signal-desktop/locales/es.pak
signal-desktop /usr/lib/signal-desktop/locales/et-EE.pak
signal-desktop /usr/lib/signal-desktop/locales/et.pak
signal-desktop /usr/lib/signal-desktop/locales/eu.pak
signal-desktop /usr/lib/signal-desktop/locales/fa-IR.pak
signal-desktop /usr/lib/signal-desktop/locales/fa.pak
signal-desktop /usr/lib/signal-desktop/locales/fi.pak
signal-desktop /usr/lib/signal-desktop/locales/fil.pak
signal-desktop /usr/lib/signal-desktop/locales/fr.pak
signal-desktop /usr/lib/signal-desktop/locales/ga-IE.pak
signal-desktop /usr/lib/signal-desktop/locales/gl-ES.pak
signal-desktop /usr/lib/signal-desktop/locales/gu-IN.pak
signal-desktop /usr/lib/signal-desktop/locales/gu.pak
signal-desktop /usr/lib/signal-desktop/locales/he.pak
signal-desktop /usr/lib/signal-desktop/locales/hi-IN.pak
signal-desktop /usr/lib/signal-desktop/locales/hi.pak
signal-desktop /usr/lib/signal-desktop/locales/hr-HR.pak
signal-desktop /usr/lib/signal-desktop/locales/hr.pak
signal-desktop /usr/lib/signal-desktop/locales/hu.pak
signal-desktop /usr/lib/signal-desktop/locales/id.pak
signal-desktop /usr/lib/signal-desktop/locales/it.pak
signal-desktop /usr/lib/signal-desktop/locales/ja.pak
signal-desktop /usr/lib/signal-desktop/locales/ka-GE.pak
signal-desktop /usr/lib/signal-desktop/locales/kk-KZ.pak
signal-desktop /usr/lib/signal-desktop/locales/km-KH.pak
signal-desktop /usr/lib/signal-desktop/locales/kn-IN.pak
signal-desktop /usr/lib/signal-desktop/locales/kn.pak
signal-desktop /usr/lib/signal-desktop/locales/ko.pak
signal-desktop /usr/lib/signal-desktop/locales/ky-KG.pak
signal-desktop /usr/lib/signal-desktop/locales/lt-LT.pak
signal-desktop /usr/lib/signal-desktop/locales/lt.pak
signal-desktop /usr/lib/signal-desktop/locales/lv-LV.pak
signal-desktop /usr/lib/signal-desktop/locales/lv.pak
signal-desktop /usr/lib/signal-desktop/locales/mk-MK.pak
signal-desktop /usr/lib/signal-desktop/locales/ml-IN.pak
signal-desktop /usr/lib/signal-desktop/locales/ml.pak
signal-desktop /usr/lib/signal-desktop/locales/mr-IN.pak
signal-desktop /usr/lib/signal-desktop/locales/mr.pak
signal-desktop /usr/lib/signal-desktop/locales/ms.pak
signal-desktop /usr/lib/signal-desktop/locales/my.pak
signal-desktop /usr/lib/signal-desktop/locales/nb.pak
signal-desktop /usr/lib/signal-desktop/locales/nl.pak
signal-desktop /usr/lib/signal-desktop/locales/pa-IN.pak
signal-desktop /usr/lib/signal-desktop/locales/pl.pak
signal-desktop /usr/lib/signal-desktop/locales/pt-BR.pak
signal-desktop /usr/lib/signal-desktop/locales/pt-PT.pak
signal-desktop /usr/lib/signal-desktop/locales/ro-RO.pak
signal-desktop /usr/lib/signal-desktop/locales/ro.pak
signal-desktop /usr/lib/signal-desktop/locales/ru.pak
signal-desktop /usr/lib/signal-desktop/locales/sk-SK.pak
signal-desktop /usr/lib/signal-desktop/locales/sk.pak
signal-desktop /usr/lib/signal-desktop/locales/sl-SI.pak
signal-desktop /usr/lib/signal-desktop/locales/sl.pak
signal-desktop /usr/lib/signal-desktop/locales/sq-AL.pak
signal-desktop /usr/lib/signal-desktop/locales/sr.pak
signal-desktop /usr/lib/signal-desktop/locales/sv.pak
signal-desktop /usr/lib/signal-desktop/locales/sw.pak
signal-desktop /usr/lib/signal-desktop/locales/ta-IN.pak
signal-desktop /usr/lib/signal-desktop/locales/ta.pak
signal-desktop /usr/lib/signal-desktop/locales/te-IN.pak
signal-desktop /usr/lib/signal-desktop/locales/te.pak
signal-desktop /usr/lib/signal-desktop/locales/th.pak
signal-desktop /usr/lib/signal-desktop/locales/tl-PH.pak
signal-desktop /usr/lib/signal-desktop/locales/tr.pak
signal-desktop /usr/lib/signal-desktop/locales/ug.pak
signal-desktop /usr/lib/signal-desktop/locales/uk-UA.pak
signal-desktop /usr/lib/signal-desktop/locales/uk.pak
signal-desktop /usr/lib/signal-desktop/locales/ur.pak
signal-desktop /usr/lib/signal-desktop/locales/vi.pak
signal-desktop /usr/lib/signal-desktop/locales/yue.pak
signal-desktop /usr/lib/signal-desktop/locales/zh-CN.pak
signal-desktop /usr/lib/signal-desktop/locales/zh-HK.pak
signal-desktop /usr/lib/signal-desktop/locales/zh-Hant.pak
signal-desktop /usr/lib/signal-desktop/locales/zh-TW.pak
signal-desktop /usr/lib/signal-desktop/resources.pak
signal-desktop /usr/lib/signal-desktop/resources/
signal-desktop /usr/lib/signal-desktop/resources/app-update.yml
signal-desktop /usr/lib/signal-desktop/resources/app.asar
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/libsignal-client/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/libsignal-client/prebuilds/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/libsignal-client/prebuilds/linux-x64/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/libsignal-client/prebuilds/linux-x64/@signalapp+libsignal-client.node
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/ringrtc/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/ringrtc/build/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/ringrtc/build/linux/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/ringrtc/build/linux/libringrtc-x64.node
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/sqlcipher/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/sqlcipher/prebuilds/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/sqlcipher/prebuilds/linux-x64/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/@signalapp/sqlcipher/prebuilds/linux-x64/@signalapp+sqlcipher.node
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/fs-xattr/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/fs-xattr/build/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/fs-xattr/build/Release/
signal-desktop /usr/lib/signal-desktop/resources/app.asar.unpacked/node_modules/fs-xattr/build/Release/xattr.node
signal-desktop /usr/lib/signal-desktop/resources/apparmor-profile
signal-desktop /usr/lib/signal-desktop/resources/org.signalapp.enable-backups.policy
signal-desktop /usr/lib/signal-desktop/resources/org.signalapp.view-aep.policy
signal-desktop /usr/lib/signal-desktop/resources/package-type
signal-desktop /usr/lib/signal-desktop/signal-desktop
signal-desktop /usr/lib/signal-desktop/snapshot_blob.bin
signal-desktop /usr/lib/signal-desktop/v8_context_snapshot.bin
signal-desktop /usr/lib/signal-desktop/vk_swiftshader_icd.json
signal-desktop /usr/share/
signal-desktop /usr/share/applications/
signal-desktop /usr/share/applications/signal-desktop.desktop
signal-desktop /usr/share/icons/
signal-desktop /usr/share/icons/hicolor/
signal-desktop /usr/share/icons/hicolor/1024x1024/
signal-desktop /usr/share/icons/hicolor/1024x1024/apps/
signal-desktop /usr/share/icons/hicolor/1024x1024/apps/signal-desktop.png
signal-desktop /usr/share/icons/hicolor/128x128/
signal-desktop /usr/share/icons/hicolor/128x128/apps/
signal-desktop /usr/share/icons/hicolor/128x128/apps/signal-desktop.png
signal-desktop /usr/share/icons/hicolor/16x16/
signal-desktop /usr/share/icons/hicolor/16x16/apps/
signal-desktop /usr/share/icons/hicolor/16x16/apps/signal-desktop.png
signal-desktop /usr/share/icons/hicolor/24x24/
signal-desktop /usr/share/icons/hicolor/24x24/apps/
signal-desktop /usr/share/icons/hicolor/24x24/apps/signal-desktop.png
signal-desktop /usr/share/icons/hicolor/256x256/
signal-desktop /usr/share/icons/hicolor/256x256/apps/
signal-desktop /usr/share/icons/hicolor/256x256/apps/signal-desktop.png
signal-desktop /usr/share/icons/hicolor/32x32/
signal-desktop /usr/share/icons/hicolor/32x32/apps/
signal-desktop /usr/share/icons/hicolor/32x32/apps/signal-desktop.png
signal-desktop /usr/share/icons/hicolor/48x48/
signal-desktop /usr/share/icons/hicolor/48x48/apps/
signal-desktop /usr/share/icons/hicolor/48x48/apps/signal-desktop.png
signal-desktop /usr/share/icons/hicolor/512x512/
signal-desktop /usr/share/icons/hicolor/512x512/apps/
signal-desktop /usr/share/icons/hicolor/512x512/apps/signal-desktop.png
signal-desktop /usr/share/icons/hicolor/64x64/
signal-desktop /usr/share/icons/hicolor/64x64/apps/
signal-desktop /usr/share/icons/hicolor/64x64/apps/signal-desktop.png
[tracy@daphne cups]$ pacman -Qd | grep electron
Oh well it’s just as well I don’t actually use the Official Repo version, I was about to remove it, but for this little ‘spat’, because it doesn’t load properly. I don’t care what’s in the flatpak, which I do use. Neither of which, probably because of the electron dependency, don’t actually scale correctly on my desktop, which is running wayland and is scaled to 85%. I can live with it as a flatpak, because I only use it as an indicator that I have a message.
