Hallo to everyone, I updated the system at Qonos 21.2.2, but I have several errors for something about “ELECTRON”: I’m sorry for my newbie, but I never herd this application
Hereby some indication:
inxi -Gaz
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Acer Incorporated ALI
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1d10 class-ID: 0302
Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:4
chip-ID: 04f2:b5c5 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 140 s-size: 348x195mm (13.7x7.7")
s-diag: 399mm (15.7")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: NVIDIA GeForce MX150/PCIe/SSE2 v: 4.6.0 NVIDIA 495.46
direct render: Yes
sudo dmesg | grep electron
[ 19.963384] traps: electron[1560] trap divide error ip:7f178bad3b27 sp:7fffb8fb9a50 error:0 in vdpau_drv_video.so[7f178bad3000+f000]
[ 19.963433] audit: type=1701 audit(1643403981.661:107): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=1560 comm="electron" exe="/usr/lib/electron14/electron" sig=8 res=1
$ electron --trace-deprecation
Electron 16.0.7 - Build cross platform desktop apps with JavaScript, HTML, and CSS
Usage: electron [options] [path]
A path to an Electron app may be specified. It must be one of the following:
- index.js file.
- Folder containing a package.json file.
- Folder containing an index.js file.
- .html/.htm file.
- http://, https://, or file:// URL.
Options:
-i, --interactive Open a REPL to the main process.
-r, --require Module to preload (option can be repeated).
-v, --version Print the version.
-a, --abi Print the Node ABI version.
GPU at BusId 0x1 doesn't have a supported video decoder
[5177:0128/222032.417278:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5177:0128/222032.829638:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5177:0128/222033.210126:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5177:0128/222033.818741:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5177:0128/222034.325816:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5177:0128/222034.836189:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5330:0128/222034.841704:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is disabled, ANGLE is
journalctl -x -p3 -b0
gen 28 22:06:05 swift3 kernel:
gen 28 22:06:22 swift3 systemd-coredump[1650]: [🡕] Process 1560 (electron) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id e4928c61148e651d67ca59cd11805e39c611af66
Module libvdpau_nvidia.so.1 with build-id 35b7e61656fe32417b7209e9c735de6a143e5b41
Module nvidia_drv_video.so with build-id 5b5feba705dbf4817759d8c58da9e754b387d998
Module libxcb-glx.so.0 with build-id 8ad115382ad874165523dc5b4488c99d73bbc3c4
Module libnvidia-glcore.so.495.46 with build-id 8113b84202e276df12ecc4fc58788506fd>
Module libnvidia-tls.so.495.46 with build-id 59f61b3d522665be01a2429d278e7892f4e56>
Module libnvidia-glsi.so.495.46 with build-id 154fbd536ea77f1e1d9c99b9d73b3abcc4ed>
Module libGLX_nvidia.so.0 with build-id 89b00558892b708601c1f576e64db5f08d9aaf07
Module libGLX.so.0 with build-id 2a08836c6e6126ce9ff4496b6aacaf29ae9b4e7b
Module libGLdispatch.so.0 with build-id 501765b3a78d668860fa54229b18107473aeda4c
Module libGL.so.1 with build-id 912ac4f37a9fa2d5abcf7a9088c9983cfe46f12a
Module libX11-xcb.so.1 with build-id 0db4f94d8ae31b8dc9a83f825a9171656f1e532c
Module libEGL.so with build-id d78bf43f3ac2bcd0ddd2b51702647c0ef30687e2
Module libGLESv2.so with build-id b57a054667f69fddf91ae360f4190050e9d287fe
Module libgomp.so.1 with build-id 144b2725c3c7bcd7999b6a248b02c301af8a9fa2
Module libgpg-error.so.0 with build-id 3801187d42c4955bd93c605451430cdf1b164e63
Module libasyncns.so.0 with build-id 6acff139d56b5139ce5eb50a66c62b215e1d332d
Module libsndfile.so.1 with build-id 72d5531e74ed3e9afe49e95e449c40cb8984a258
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
Module libcrypto.so.1.1 with build-id 4c926b672d97886b123e03a008387aecf0786de4
Module libhogweed.so.6 with build-id 2d70cff7b1841b4d9ca4e8e7726cd4b944c07fdc
Module libnettle.so.8 with build-id 9a878e513c02007598fcf1e2e286c2203f13536e
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Module libunistring.so.2 with build-id 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libp11-kit.so.0 with build-id f97c44b297b54185bbe3eb6ed6dab5d8967f1532
Module libmvec.so.1 with build-id 9aa05e22565568b778a97933527b3c64bdb8418b
Module libsoxr.so.0 with build-id 9e49936ed807c1e52705b88d5d71706fe11d9ed1
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libjson-glib-1.0.so.0 with build-id 5865be5fcc01b48a0a113e0145ec45529bff89a6
Module libsqlite3.so.0 with build-id 5f711261aabe285f02a673ded77a37b413afbfa2
Module libstemmer.so.0 with build-id aa44a40dfb223020ed8e49cd2d28fc3887128463
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libXcursor.so.1 with build-id eb6315bcd7526aaf51b0a1307efdc587cea0a152
Module libwayland-egl.so.1 with build-id 791e39283cdcc5a08cfd091b8cd4c59869a11278
Module libwayland-cursor.so.0 with build-id 79d7e67af210407c2afe92ba8c189c8648a647>
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
Module libcap.so.2 with build-id f56c6cd6ad4d35053340d7ff2f8f954498796739
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libzstd.so.1 with build-id 6214183688018e3fba6d66db10c2c8d0b45e0578
Module librt.so.1 with build-id 75484da2d6f1515189eefa076e0a40328834cd16
Module libblkid.so.1 with build-id 057b6bc8eebd42d1f5cafe4f4ac72646aae1f2c5
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libavahi-client.so.3 with build-id 1858551543958190c653b565cf0eb64609ad908a
Module libavahi-common.so.3 with build-id 80fda945459a3476ccd1050783dfd5f5c17c479a
Module libpulsecommon-15.0.so with build-id a2e110b7a0b3bb46e42515afd55a61d7818583>
Module libwayland-server.so.0 with build-id 645526447334b85a6f4bf5a8b37737b2769636>
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
Module libvdpau.so.1 with build-id 96ac4ef0ce4b2bdbe091782d97eafadd6e4cea90
Module libva-x11.so.2 with build-id e6a0ffef32570ba034a3724e735ba0fa90d39eee
Module libva-drm.so.2 with build-id 5ac46263a883c725bfed65d98ff2e3162fd464ad
Module libssh.so.4 with build-id 8490056688e60790230f9d990c439b181236e9b6
Module libsrt.so.1.4 with build-id ad13eeb20e5ea3f04a0b089de1152ff89a9fa65c
Module libgnutls.so.30 with build-id 8c87466eacaec0041a370df713d0fd200358c94c
Module libgmp.so.10 with build-id e58d34ab389d1b649c24195c2d145e3ff2e58290
Module libbluray.so.2 with build-id ebaa74ef4d549c1d3f01fafb8625045d286b8940
Module libmodplug.so.1 with build-id b00dcb12e7d2d5882b4fa414295eba449875dae4
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libmfx.so.1 with build-id 8281ba744d2215511b252db50250f1d4e073d36d
Module libva.so.2 with build-id d0042003bbdf0c10b26dbc25c80cb06eb64b4f5c
Module libxvidcore.so.4 with build-id 43bc390a7842a7ca3a0302e93442ea561d7f013a
Module libx265.so.199 with build-id 22130b9b0d2aa957b148b0fdeb27e3fd04f0fb58
Module libx264.so.163 with build-id 8f90efeb3197366ecf6574384b1adf9c8996157e
Module libvorbisenc.so.2 with build-id 28ed815b8b1d322e6bf2bfdce4b0af2789b74335
Module libvorbis.so.0 with build-id ad0a6c1af8f219b4e314090b6e8847223d424cbe
Module libtheoradec.so.1 with build-id 19d321fd5455c7b7611ca9602a804b496124e06f
Module libtheoraenc.so.1 with build-id cde750f0621140f313e4ef4e5f212e662f24a38b
Module libSvtAv1Enc.so.0 with build-id 3ebe5abcc88d5855fde0b2645844f80f03982902
Module libspeex.so.1 with build-id 39721dbe21b62978562c2943279f6dffbffe8946
Module librav1e.so.0 with build-id 2e9e70e2433e4d2955a870f2de730172729fbe4f
Module libopenjp2.so.7 with build-id 0a329c12468c33c92ecbc3968f4dc9c79cc5db96
Module libopencore-amrnb.so.0 with build-id a3d78948c85fa235e66549119b2f130e69af7b>
Module libmp3lame.so.0 with build-id 48c901805551a3dd58d02502c4cd67f6aa848107
Module libgsm.so.1 with build-id 1cc6240f7eaedaaac302bc7c0f64ebbeae596f22
Module libaom.so.3 with build-id 17c2d78932dffd790b290358a144c2b0ef5ddd17
Module librsvg-2.so.2 with build-id 6b6b837ebec63485c2e1b826260885f065d22683
Module libopencore-amrwb.so.0 with build-id 28da8ed3dfca59280e835c46bd40da295dae99>
Module libdav1d.so.5 with build-id 82862181dbe48302fde94240f68e17fb6f9a03c7
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module libvpx.so.7 with build-id 0dce08d8df560a9817a17291a53f905fd7d17c62
Module libswresample.so.3 with build-id e46062e25d0903796dc55ca3c82c188d7887b433
Module libtiff.so.5 with build-id e8d89a0fb0847641ddb75c5f03fa89d68155a75d
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libtracker-sparql-3.0.so.0 with build-id b0eee5a9b660fed5221ea15139e9608282>
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf9>
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id b6357fc6b748c512f90339433d74502b9d0621dc
Module libcairo-gobject.so.2 with build-id abbf5a8a182ea1b8b7d68540df5c2e25c0bdae0c
Module libfribidi.so.0 with build-id 79124bad061c2aab4ec89f25d067363d5b781114
Module libpangoft2-1.0.so.0 with build-id ef74c3ce7ee52a746fb5f2840d80a84e314edb92
Module libpangocairo-1.0.so.0 with build-id 10d2af38056eee9a6b3458d8aac24095c4dfab>
Module libgdk-3.so.0 with build-id 6f77a9486fc38cb4e374d862662cb5e39ca3988a
Module libsystemd.so.0 with build-id 69dfd360ef432adc8911dd446411765f1922fb48
Module libplc4.so with build-id 44dcd42fb72cc8aab586dbf4000293590bb19e67
Module libplds4.so with build-id e915f74a1aff6a20d65b5f03f5ee2e0197153a33
Module libresolv.so.2 with build-id c915c72668282861a813f7ea3c0780f37b681dc0
Module libmount.so.1 with build-id 39e178b712b6635a8681182f7a9fbb64e6074aee
Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module ld-linux-x86-64.so.2 with build-id 040cc3dd10461562f177df39e3be2f3704258c3c
Module libc.so.6 with build-id 4b406737057708c0e4c642345a703c47a61c73dc
Module libgcc_s.so.1 with build-id 7f8508bb914546ada778809b64b99d234337d835
Module libstdc++.so.6 with build-id 9b5eeeb149bf3c4efe787fb398b44f00507aec87
Module libnghttp2.so.14 with build-id eca975f5266a67fc4895065727647e98ff99a128
Module libcares.so.2 with build-id 1b9ea0fcbb8807a755056cf9a715a8114f81fac2
Module libminizip.so.1 with build-id b618dcb7711cb690717dd50d0c08ce94a5a0b264
Module libFLAC.so.8 with build-id e568dc3d434723c72d6d302eb0b2559f27e91faa
Module libcups.so.2 with build-id 68a2ef2ccefd545e68b78c5acb20bcb2818c5049
Module libxslt.so.1 with build-id 6085ceddf5c745052dc31c6dcea8e03b24b9f0f2
Module libxml2.so.2 with build-id b710b880b0d4e9c93554fa632129db44c20632cd
Module libatspi.so.0 with build-id de251156cf6f2f447c5e2b8721bd913d79995d4f
Module libsnappy.so.1 with build-id 36e3fb247a476fe2f755162644ebcd8ebd5d92cb
Module libpulse.so.0 with build-id 10bd0ce0cfbb9405cee189faa1830cf34cab61a8
Module libasound.so.2 with build-id b17fc1317a484842433c772360376623b64ec3d8
Module libwayland-client.so.0 with build-id 0a237f2fd096bada4ca381eec5d64474c4078b>
Module libre2.so.9 with build-id 266f2661502fa7f110de81fa19c23a4df26073d2
Module libgbm.so.1 with build-id 20c4f3d50d078a101a7cc68395bfc979bed083cc
Module libxkbcommon.so.0 with build-id 1f1bc7527e57c886c3df5803068122e1971d4724
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libharfbuzz-subset.so.0 with build-id c72f9ccd2c0caa35d87f961dfa445cb0e5b10>
Module libfontconfig.so.1 with build-id 1103a641395c7d3b42e49b793d3a9ea927c77bf6
Module libexpat.so.1 with build-id 64e977cfebfe7539f428dec3b388f5d0498b3108
Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
Module libwebp.so.7 with build-id 87e81472aa7ff3ed1061cfc13d6960dbe00c35ab
Module libwebpmux.so.3 with build-id 4e17ff5fa40f00cda51d08d9edd48d442d3044e2
Module libwebpdemux.so.2 with build-id b7d359c460bcb828b2ab4f34adfa8673af8a657b
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
Module libavutil.so.56 with build-id 4349b10cc6d45ef37bbb95bf73f936e885b4456a
Module libavformat.so.58 with build-id 8b172cc1d947afa363cf842c83a281bf17510644
Module libavcodec.so.58 with build-id ee7f4c1bebe06325cb15545d9c748bd94473112d
Module libopus.so.0 with build-id 649d3ddab8764d7caf73648004a35cb13e23a5e1
Module libm.so.6 with build-id 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
Module libjpeg.so.8 with build-id 879ca18a2f58c25d77ba881db3a44a5676ef6c7d
Module libevent-2.1.so.7 with build-id 4cf856bfbd3644008bc09ccf8d436baf574680e5
Module libgdk_pixbuf-2.0.so.0 with build-id ca4beb15a30de8d8767f7bca8222038c61b58b>
Module libcairo.so.2 with build-id 06820af9cf79c2deb207d9533a61caf04e67a8ad
Module libharfbuzz.so.0 with build-id 1d9dee49dd99162c3f83eb3259c3c88c6b4cd7fe
Module libpango-1.0.so.0 with build-id 730a8183a36afae82dd6a5564c0e490fed239a40
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module libgtk-3.so.0 with build-id e17042e459bfe2a5cd401828a90435a81a82b70d
Module libdrm.so.2 with build-id 457a1a1bd25f1d5541a10d3f16c5dc1440d77c7d
Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287>
Module libatk-1.0.so.0 with build-id aacaa40363d304858b654728a893bc212a4ca119
Module libnspr4.so with build-id c5d12234f7975d11a11e67646533657d014d9540
Module libnssutil3.so with build-id 4b6db37071663adf3a3945a4188333ec692a2658
Module libnss3.so with build-id 874a009fd052f183e0270e1a1db5fc1ab8b4269c
Module libsmime3.so with build-id 3999d0802814ac03c37987476ee0b05d2e14e797
Module libgio-2.0.so.0 with build-id bce5a3881708e1e885fa1c9c32e2769a6447c411
Module libxshmfence.so.1 with build-id 8876d9ccf620858795724ca24b9e567585a77cec
Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
Module libgobject-2.0.so.0 with build-id e67b3a29cecdd98c3d8bd6eb7524a812331b20a2
Module libglib-2.0.so.0 with build-id 220436a4e27f39372710df014d2517c0387eefa4
Module libgmodule-2.0.so.0 with build-id 5da4523e8d6b5c244a0193e27093d1e61f6ac9e4
Module libpthread.so.0 with build-id 07c8f95b4f3251d08550217ad8a1f31066229996
Module libdl.so.2 with build-id 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Module libatomic.so.1 with build-id e5554ec28832bc2afb013a349b872738965223d6
Module libgtk3-nocsd.so.0 with build-id a7cd4fe8479511e8d7c67d88c1df3f154d0d1ad6
Module electron with build-id 82ed6a5cb65e231d7ad62fd8c7b773bd14249870
Stack trace of thread 1560:
#0 0x00007f178bad3b27 n/a (nvidia_drv_video.so + 0x3b27)
#1 0x00007f178bad6989 n/a (nvidia_drv_video.so + 0x6989)
#2 0x00007f178bad6e1f __vaDriverInit_1_10 (nvidia_drv_video.so + 0x6e1f)
#3 0x00007f1791e84c7f n/a (libva.so.2 + 0x3c7f)
#4 0x00007f1791e8a83a vaInitialize (libva.so.2 + 0x983a)
#5 0x000055864fda043f n/a (electron + 0x3d9d43f)
#6 0x000055864fda00bb n/a (electron + 0x3d9d0bb)
#7 0x000055864fd9c82b n/a (electron + 0x3d9982b)
#8 0x000055864fda72e2 n/a (electron + 0x3da42e2)
#9 0x00005586543e0e6a n/a (electron + 0x83dde6a)
#10 0x0000558652f115f1 n/a (electron + 0x6f0e5f1)
#11 0x00005586543e07df n/a (electron + 0x83dd7df)
#12 0x000055864fdf63c2 n/a (electron + 0x3df33c2)
#13 0x000055864fdf76ff n/a (electron + 0x3df46ff)
#14 0x000055864fdf4d88 n/a (electron + 0x3df1d88)
#15 0x000055864fdf558c n/a (electron + 0x3df258c)
#16 0x000055864eeef679 n/a (electron + 0x2eec679)
#17 0x00007f17a00a4b25 __libc_start_main (libc.so.6 + 0x27b25)
#18 0x000055864ebe9a6e _start (electron + 0x2be6a6e)
Stack trace of thread 1567:
#0 0x00007f17a3fe18ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
#1 0x00007f17a3fdb574 pthread_cond_timedwait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf5>
#2 0x0000558651b5d1fd n/a (electron + 0x5b5a1fd)
#3 0x0000558651b5d9b8 n/a (electron + 0x5b5a9b8)
#4 0x0000558651ad837d n/a (electron + 0x5ad537d)
#5 0x0000558651b23687 n/a (electron + 0x5b20687)
#6 0x0000558651af672b n/a (electron + 0x5af372b)
#7 0x0000558651b3b399 n/a (electron + 0x5b38399)
#8 0x0000558651b3b1ae n/a (electron + 0x5b381ae)
#9 0x0000558651b60996 n/a (electron + 0x5b5d996)
#10 0x00007f17a3fd5259 start_thread (libpthread.so.0 + 0x9259)
#11 0x00007f17a017b5e3 __clone (libc.so.6 + 0xfe5e3)
░░ Subject: Il processo 1560 (electron) ha generato un dump.
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Il processo 1560 (electron) si è bloccato generando un dump.
░░ Questo di solito capita per un errore di programmazione nell'applicazione e
░░ dovrebbe essere segnalato come bug al vendor.
Thanks a lot for your attention
