Hallo to everyone,
this is my first post because I need some help because after updating from Opera 81.0 to 82.0 the browser didn’t work anymore, the CPU became very high, and also the fan raising the speed
When I tried to start Opera 82.0 from console I have this messages:
[gianmario@swift3 ~]$ opera &
[1] 5763
[gianmario@swift3 ~]$ [5763:5763:0123/171431.334953:ERROR:url_pattern_set.cc(290)] Invalid url pattern: chrome://startpage/
[5763:5763:0123/171431.335069:ERROR:url_pattern_set.cc(290)] Invalid url pattern: chrome://startpage/
[5763:5763:0123/171431.335109:ERROR:url_pattern_set.cc(290)] Invalid url pattern: chrome://startpage/
GPU at BusId 0x1 doesn't have a supported video decoder
[5763:5763:0123/171432.317252:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5763:5763:0123/171432.921843:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5763:5763:0123/171433.567652:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5763:5763:0123/171434.158683:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5763:5763:0123/171434.728725:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[5763:5763:0123/171435.330103:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[6867:6867:0123/171435.338465:ERROR:gpu_init.cc(458)] Passthrough is not supported, GL is disabled, ANGLE is
Sorry, I’am a newbie , I don’t understand your advise: I have to put the command string “opera --user-data-dir=/tmp/chrom-test-profile” into a terminal to start Opera ?
If that is the correct flag, then just copy/paste it into terminal and hit Enter
But maybe you need to check whatever the proper options are with
opera --help
or
man opera
PS - that prime profile means that unless you did some extra configuration, or you are launching opera with prime-run then yes, it should be using the intel, not the nvidia.
EDIT - it appears opera doesnt expose any options in help or provide a man page … … but I managed to download it, and it seems the chromium options work …so go ahead and test with
Thanks CSCS for your effort
I upgrade to Opera 82.0 and I into a console I use the comand string
opera --user-data-dir=/tmp/opera-test-profile
Opera starts without personalization, loads a Opera’s international web page and stay in running to load another page unsuccesfull, again the CPU Load raising to 90%: there is same alert messages:
[gianmario@swift3 ~]$ opera --user-data-dir=/tmp/opera-test-profile &
[1] 11278
[gianmario@swift3 ~]$ [11278:11278:0124/215946.697458:ERROR:url_pattern_set.cc(290)] Invalid url pattern: chrome://startpage/
[11278:11278:0124/215946.697638:ERROR:url_pattern_set.cc(290)] Invalid url pattern: chrome://startpage/
[11278:11278:0124/215946.697689:ERROR:url_pattern_set.cc(290)] Invalid url pattern: chrome://startpage/
[11278:11278:0124/215947.333780:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[11278:11278:0124/215947.795107:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[11278:11278:0124/215948.182461:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[11278:11278:0124/215948.706081:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[11278:11278:0124/215949.571410:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[11278:11278:0124/215950.523985:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=136
[11788:11788:0124/215950.531655:ERROR:gpu_init.cc(458)] Passthrough is not supported, GL is disabled, ANGLE is
[1]+ Completato opera --user-data-dir=/tmp/opera-test-profile
Oh … so it should be nvidia only … ok … well … then thats a bit different.
You have the prime profile enabled … meaning you are keeping it in dynamic mode with both available (and in its default state should mean intel, then nvidia with prime-run) … but you are using only the nvidia? how did you configure that ?
That link doesnt work, but if I prepend archived. to it for the old forum then it does … and provides a quite old guide. That doesnt really apply - it was before PRIME was fully and easily available… PRIME is now the default. It also shows ~4 different methods … so what did you actually do?
Ok, many thanks CSCS, I will read the wiki and I will try to change the configuration or do you think would be better starting with a new installation ?
Its probably simple enough to get back to a ‘normal’ config … you just have to see what you may have done … such as check installed packages, for the file /etc/X11/xorg.conf.d/optimus.conf, and other such things you may have committed previously (refer to the guide used).
If that is a bother … then sure you can always reinstall if you like.
I just installed Opera 83.0.4254.27 from Arch package and started from console with a new profile using the command
Same problems as Opera 82.0: CPU loading just to 45% (with Opera 81.0 is more or less lower than 10%)
The Start Page does not works, ad also the Dial Page; it is possible open a new page Google for instance: hereby a print screen
[1] 17815
[gianmario@swift3 ~]$ GPU at BusId 0x1 doesn't have a supported video decoder
[17815:17815:0130/221451.947198:ERROR:gpu_process_host.cc(969)] GPU process exited unexpectedly: exit_code=136
[17815:17815:0130/221452.374019:ERROR:gpu_process_host.cc(969)] GPU process exited unexpectedly: exit_code=136
[17815:17815:0130/221452.767673:ERROR:gpu_process_host.cc(969)] GPU process exited unexpectedly: exit_code=136
[17815:17815:0130/221453.246018:ERROR:gpu_process_host.cc(969)] GPU process exited unexpectedly: exit_code=136
[17815:17815:0130/221453.731780:ERROR:gpu_process_host.cc(969)] GPU process exited unexpectedly: exit_code=136
[17815:17827:0130/221454.000055:ERROR:mcs_client.cc(706)] Error code: 500 Error message: Cannot parse data.
[17815:17827:0130/221454.000097:ERROR:mcs_client.cc(708)] Failed to log in to GCM, resetting connection.
[17815:17815:0130/221454.127010:ERROR:url_pattern_set.cc(291)] Invalid url pattern: chrome://startpage/
[17815:17815:0130/221454.244619:ERROR:gpu_process_host.cc(969)] GPU process exited unexpectedly: exit_code=136
[18408:18408:0130/221454.252327:ERROR:gpu_init.cc(458)] Passthrough is not supported, GL is disabled, ANGLE is
[17815:17815:0130/221859.659333:ERROR:CONSOLE(547)] "Uncaught (in promise) Error", source: chrome-extension://ebongfbmlegepmkkdjlnlmdcmckedlal/touch_communication.js (547)
Dump-core from Journalctl
journalctl -x -p3 -b1
swift3 systemd-coredump[18277]: [🡕] Process 18264 (opera) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id e4928c61148e651d67ca59cd11805e39c61>
Module libvdpau_nvidia.so.1 with build-id 35b7e61656fe32417b7209e9c735de>
Module libGLX.so.0 with build-id 2a08836c6e6126ce9ff4496b6aacaf29ae9b4e7b
Module libGLdispatch.so.0 with build-id 501765b3a78d668860fa54229b181074>
Module libvdpau.so.1 with build-id 96ac4ef0ce4b2bdbe091782d97eafadd6e4ce>
Module libGL.so.1 with build-id 912ac4f37a9fa2d5abcf7a9088c9983cfe46f12a
Module nvidia_drv_video.so with build-id 5b5feba705dbf4817759d8c58da9e75>
Module libva-drm.so.2 with build-id 5ac46263a883c725bfed65d98ff2e3162fd4>
Module libva-x11.so.2 with build-id e6a0ffef32570ba034a3724e735ba0fa90d3>
Module libva.so.2 with build-id d0042003bbdf0c10b26dbc25c80cb06eb64b4f5c
Module libvk_swiftshader.so with build-id cc1be48694a314c019e595f9167998>
Module libvulkan.so.1 with build-id 72f811d320d9ca65758ef23f3406d5179998>
Module libX11-xcb.so.1 with build-id 0db4f94d8ae31b8dc9a83f825a9171656f1>
Module libEGL.so with build-id 357a9d5f8b9bb2e24ff7f53ca206ac5b79823135
Module libGLESv2.so with build-id 299a7875972702a5b78ff7b6e91be8c79f3939>
Module libgpg-error.so.0 with build-id 3801187d42c4955bd93c605451430cdf1>
Module libgmp.so.10 with build-id e58d34ab389d1b649c24195c2d145e3ff2e582>
Module libhogweed.so.6 with build-id 2d70cff7b1841b4d9ca4e8e7726cd4b944c>
Module libnettle.so.8 with build-id 9a878e513c02007598fcf1e2e286c2203f13>
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e>
Module libp11-kit.so.0 with build-id f97c44b297b54185bbe3eb6ed6dab5d8967>
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619>
Module libcap.so.2 with build-id f56c6cd6ad4d35053340d7ff2f8f954498796739
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d9>
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6d>
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be1>
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f80>
Module librt.so.1 with build-id 75484da2d6f1515189eefa076e0a40328834cd16
Module libblkid.so.1 with build-id 057b6bc8eebd42d1f5cafe4f4ac72646aae1f>
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a>
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8>
Module libkrb5support.so.0 with build-id adf65240a4d2aba772d7a0772b4d015>
Module libcom_err.so.2 with build-id be99503e12b86d78d6ede2f0d1ffb66408a>
Module libk5crypto.so.3 with build-id eb8220b8f36675aac769450be4cb6bb7f9>
Module libkrb5.so.3 with build-id 72d26767c5cb1097db75a5f5bff88860233c90>
Module libunistring.so.2 with build-id 015ac6d6bcb60b7d8bea31a80d1941b06>
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libstdc++.so.6 with build-id 9b5eeeb149bf3c4efe787fb398b44f00507a>
Module libwayland-server.so.0 with build-id 645526447334b85a6f4bf5a8b377>
Module libgnutls.so.30 with build-id 8c87466eacaec0041a370df713d0fd20035>
Module libavahi-client.so.3 with build-id 1858551543958190c653b565cf0eb6>
Module libavahi-common.so.3 with build-id 80fda945459a3476ccd1050783dfd5>
Module libsystemd.so.0 with build-id 69dfd360ef432adc8911dd446411765f192>
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3>
Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc>
Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0>
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8>
Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb>
Module libfontconfig.so.1 with build-id 1103a641395c7d3b42e49b793d3a9ea9>
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83>
Module libharfbuzz.so.0 with build-id 1d9dee49dd99162c3f83eb3259c3c88c6b>
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d236905339527>
Module libfribidi.so.0 with build-id 79124bad061c2aab4ec89f25d067363d5b7>
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5>
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libresolv.so.2 with build-id c915c72668282861a813f7ea3c0780f37b68>
Module libmount.so.1 with build-id 39e178b712b6635a8681182f7a9fbb64e6074>
Module libgmodule-2.0.so.0 with build-id 5da4523e8d6b5c244a0193e27093d1e>
Module libplc4.so with build-id 44dcd42fb72cc8aab586dbf4000293590bb19e67
Module libplds4.so with build-id e915f74a1aff6a20d65b5f03f5ee2e0197153a33
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce527>
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692>
Module libzstd.so.1 with build-id 6214183688018e3fba6d66db10c2c8d0b45e05>
Module libgssapi_krb5.so.2 with build-id e6e098ad51ce7bdd3dbe902d7b0f69a>
Module libcrypto.so.1.1 with build-id 4c926b672d97886b123e03a008387aecf0>
Module libssl.so.1.1 with build-id 1024424ab33a3767da03f4fdb1fc1b02479f1>
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d>
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d3>
Module libnghttp2.so.14 with build-id eca975f5266a67fc4895065727647e98ff>
Module ld-linux-x86-64.so.2 with build-id 040cc3dd10461562f177df39e3be2f>
Module libc.so.6 with build-id 4b406737057708c0e4c642345a703c47a61c73dc
Module libgcc_s.so.1 with build-id 7f8508bb914546ada778809b64b99d234337d>
Module libasound.so.2 with build-id b17fc1317a484842433c772360376623b64e>
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52>
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a949656>
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2eb>
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c>
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce390>
Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
Module libm.so.6 with build-id 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
Module libatspi.so.0 with build-id de251156cf6f2f447c5e2b8721bd913d79995>
Module libgbm.so.1 with build-id 20c4f3d50d078a101a7cc68395bfc979bed083cc
Module libcups.so.2 with build-id 68a2ef2ccefd545e68b78c5acb20bcb2818c50>
Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0>
Module libcairo.so.2 with build-id 06820af9cf79c2deb207d9533a61caf04e67a>
Module libpango-1.0.so.0 with build-id 730a8183a36afae82dd6a5564c0e490fe>
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa0266718>
Module libatk-1.0.so.0 with build-id aacaa40363d304858b654728a893bc212a4>
Module libxkbcommon.so.0 with build-id 1f1bc7527e57c886c3df5803068122e19>
Module libdrm.so.2 with build-id 457a1a1bd25f1d5541a10d3f16c5dc1440d77c7d
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libexpat.so.1 with build-id 64e977cfebfe7539f428dec3b388f5d0498b3>
Module libgio-2.0.so.0 with build-id bce5a3881708e1e885fa1c9c32e2769a644>
Module libnspr4.so with build-id c5d12234f7975d11a11e67646533657d014d9540
Module libsmime3.so with build-id 3999d0802814ac03c37987476ee0b05d2e14e7>
Module libnssutil3.so with build-id 4b6db37071663adf3a3945a4188333ec692a>
Module libnss3.so with build-id 874a009fd052f183e0270e1a1db5fc1ab8b4269c
Module libglib-2.0.so.0 with build-id 220436a4e27f39372710df014d2517c038>
Module libgobject-2.0.so.0 with build-id e67b3a29cecdd98c3d8bd6eb7524a81>
Module libpthread.so.0 with build-id 07c8f95b4f3251d08550217ad8a1f310662>
Module libdl.so.2 with build-id 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Module libcurl.so.4 with build-id 6d8b3894028b18652d982456a34e7b275ed6cc>
Module libffmpeg.so with build-id 53ae6176ab5524e3
Module libgtk3-nocsd.so.0 with build-id a7cd4fe8479511e8d7c67d88c1df3f15>
Module opera with build-id 70d488eaaeaecc18f2e8f343b1f95f3fc8b0cfa2
Stack trace of thread 18264:
#0 0x00007fc9e15b8b27 n/a (nvidia_drv_video.so + 0x3b27)
#1 0x00007fc9e15bb989 n/a (nvidia_drv_video.so + 0x6989)
#2 0x00007fc9e15bbe1f __vaDriverInit_1_10 (nvidia_drv_video.so + 0x6e1f)
#3 0x00007fc9e156dc7f n/a (libva.so.2 + 0x3c7f)
#4 0x00007fc9e157383a vaInitialize (libva.so.2 + 0x983a)
#5 0x000056069e8d35fd n/a (opera + 0x33a45fd)
#6 0x000056069e8cfced n/a (opera + 0x33a0ced)
#7 0x000056069e8d0d92 n/a (opera + 0x33a1d92)
#8 0x000056069e8cf59b n/a (opera + 0x33a059b)
#9 0x00005606a30c511d n/a (opera + 0x7b9611d)
#10 0x00005606a22b61d1 n/a (opera + 0x6d871d1)
#11 0x00005606a30c4c6b n/a (opera + 0x7b95c6b)
#12 0x00005606a0ae1941 n/a (opera + 0x55b2941)
#13 0x00005606a0ae30ef n/a (opera + 0x55b40ef)
#14 0x00005606a0ae0a54 n/a (opera + 0x55b1a54)
#15 0x00005606a0ae145e n/a (opera + 0x55b245e)
#16 0x000056069d62d63d ChromeMain (opera + 0x20fe63d)
#17 0x00007fc9ea64db25 __libc_start_main (libc.so.6 + 0x27b25)
#18 0x000056069d2c83aa _start (opera + 0x1d993aa)
Stack trace of thread 18274:
#0 0x00007fc9eb4dc8ca __futex_abstimed_wait_common64 (libpthread.so.0 +>
#1 0x00007fc9eb4d6270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 +>
#2 0x00007fc9e5ffb6a2 n/a (libvk_swiftshader.so + 0x2226a2)
#3 0x00007fc9e5e8acb8 n/a (libvk_swiftshader.so + 0xb1cb8)
#4 0x00007fc9e5e8a4a1 n/a (libvk_swiftshader.so + 0xb14a1)
#5 0x00007fc9e5e8b28d n/a (libvk_swiftshader.so + 0xb228d)
#6 0x00007fc9eb4d0259 start_thread (libpthread.so.0 + 0x9259)
#7 0x00007fc9ea7245e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 18269:
#3 0x00007fc9e5e9a516 n/a (libvk_swiftshader.so + 0xc1516)
#4 0x00007fc9e5e9cae5 n/a (libvk_swiftshader.so + 0xc3ae5)
#5 0x00007fc9e5e9e940 n/a (libvk_swiftshader.so + 0xc5940)
Stack trace of thread 18270:
Stack trace of thread 18267:
Stack trace of thread 18273:
Stack trace of thread 18271:
Stack trace of thread 18272:
Stack trace of thread 18265:
#1 0x00007fc9eb4d6574 pthread_cond_timedwait@@GLIBC_2.3.2 (libpthread.s>
#2 0x00005606a0bbbf64 n/a (opera + 0x568cf64)
#3 0x00005606a0bbc698 n/a (opera + 0x568d698)
#4 0x00005606a0b3ee0a n/a (opera + 0x560fe0a)
#5 0x00005606a0b84c4d n/a (opera + 0x5655c4d)
#6 0x00005606a0b5c18c n/a (opera + 0x562d18c)
#7 0x00005606a0b9a5c8 n/a (opera + 0x566b5c8)
#8 0x00005606a0b9a752 n/a (opera + 0x566b752)
#9 0x00005606a0bbfbdc n/a (opera + 0x5690bdc)
#10 0x00007fc9eb4d0259 start_thread (libpthread.so.0 + 0x9259)
#11 0x00007fc9ea7245e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 18268:
Stack trace of thread 18266:
░░ Subject: Il processo 18264 (opera) ha generato un dump.
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Il processo 18264 (opera) si è bloccato generando un dump.
░░ Questo di solito capita per un errore di programmazione nell'applicazione e
░░ dovrebbe essere segnalato come bug al vendor.
I followed the CSCS’s advise, i removed the old graphic configuration, and reinstalled the graphic drive with
sudo mhwd -a pci nonfree 300
I rebooted the system, try to upgrade at Opera 82.0 and now finally Opera correctly starts without problems Cpu loads are very low, but I have some problems for the configuration file as “90-mhwd.conf” and “xorg config” It’s better close this tread and open a new specific tread for graphic configuration ?
EDIT 2022-02-06: Through a live Manjaro booted with “non free” option I have copied the correct configuration files and now the installation are right !!
