Eject External Hard Drive option gone
Hello, it used to be that you could command ‘eject’ your external hard drive (usb drive), that option doesn’t appear to be available anymore?
It’s handy because it does the ‘umount’ and then ‘eject’ at the same time and it turns off the device completely, until reboot or physical replug USB device.
Linux 5.4.108-1-MANJARO (x86_64)
Any ideas?
Thanks!
We need some more info…
My apologies.
This is my inxi output:
  Kernel: 5.4.108-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=fec8603e-392b-4ab6-9e05-1be859d00151 rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: Compiz 0.8.18
  vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: VivoBook S14 X430UA v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: X430UA v: 1.0 serial: <filter>
  UEFI: American Megatrends v: X430UA.304 date: 05/22/2019
  ID-1: BAT0 charge: 34.1 Wh (96.9%) condition: 35.2/42.0 Wh (83.7%)
  volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Charging cycles: 171
  RAM: total: 7.66 GiB used: 2.55 GiB (33.3%)
  Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: E0 cache: L2: 6 MiB bogomips: 28808
  Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus-ID: 1-6:4 chip-ID: 13d3:56c1 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.10 compositor: compiz v: 0.8.18 driver:
  loaded: modesetting unloaded: intel alternate: fbdev,vesa display-ID: :0.0
  screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
  diag: 355mm (14")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.1
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.4.108-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.24 running: no
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: AzureWave
  driver: rtw_pci v: N/A modules: rtwpci port: e000 bus-ID: 02:00.0
  chip-ID: 10ec:b822 class-ID: 0280
  IF: wlp2s0 state: down mac: <filter>
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
  bus-ID: 2-2:2 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u2 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
  bus-ID: 1-8:5 chip-ID: 13d3:3526 class-ID: e001 serial: <filter>
  Message: No LVM data was found.
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 21 class-ID: 0104
  Local Storage: total: 5.69 TiB used: 200.24 GiB (3.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: A031 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: One Touch HDD
  size: 4.55 TiB block-size: physical: 4096 B logical: 512 B serial: <filter>
  rev: 1707 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
  model: ST1000LM024 HN-M101MBB size: 931.51 GiB block-size: physical: 512 B
  logical: 512 B rotation: 5400 rpm serial: <filter> rev: 0608 scheme: MBR
  ID-1: / raw-size: 238.17 GiB size: 233.43 GiB (98.01%)
  used: 200.24 GiB (85.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: fec8603e-392b-4ab6-9e05-1be859d00151
  used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: DFF3-807C
  ID-1: /dev/sdb1 maj-min: 8:17 size: 200 MiB fs: vfat label: EFI
  uuid: 67E3-17ED
  ID-2: /dev/sdb2 maj-min: 8:18 size: 4.55 TiB fs: ext4 label: backup1
  uuid: 3d8a68ce-6c85-447d-9eaa-9f0fdc7f1b18
  ID-3: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ntfs
  label: Seagate Expansion Drive uuid: EC623E11623DE14E
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-3:2
  info: Seagate RSS LLC USB 3.0 bridge [Portable Expansion Drive]
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
  speed: 480 Mb/s power: 100mA chip-ID: 0bc2:2320 class-ID: 0806
  serial: <filter>
  Device-2: 1-4:3 info: Seagate RSS LLC One Touch HDD type: Mass Storage
  driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
  chip-ID: 0bc2:ab65 class-ID: 0806 serial: <filter>
  Device-3: 1-6:4 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  Device-4: 1-8:5 info: IMC Networks Bluetooth Radio type: Bluetooth
  driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-2:2 info: Realtek RTL8153 Gigabit Ethernet Adapter type: Network
  driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 288mA
  System Temperatures: cpu: 52.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2000
  Processes: 275 Uptime: 1m wakeups: 3 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 alt: 9 clang: 11.1.0 Packages: 1524 pacman: 1498
  lib: 446 flatpak: 15 snap: 11 Shell: Bash v: 5.1.0
  running-in: xfce4-terminal inxi: 3.3.03
This is my dmesg output:
[    0.283674] usbcore: registered new interface driver usbfs
[    0.283674] usbcore: registered new interface driver hub
[    0.283674] usbcore: registered new device driver usb
[    0.446116] usbcore: registered new interface driver usbserial_generic
[    0.446119] usbserial: USB Serial support registered for generic
[    0.676483] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    0.676485] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.676487] usb usb1: Product: xHCI Host Controller
[    0.676488] usb usb1: Manufacturer: Linux 5.4.108-1-MANJARO xhci-hcd
[    0.676489] usb usb1: SerialNumber: 0000:00:14.0
[    0.677787] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    0.677789] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.677790] usb usb2: Product: xHCI Host Controller
[    0.677791] usb usb2: Manufacturer: Linux 5.4.108-1-MANJARO xhci-hcd
[    0.677792] usb usb2: SerialNumber: 0000:00:14.0
[    0.678169] usb: port power management may be unreliable
[    1.008995] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[    1.150032] usb 1-3: New USB device found, idVendor=0bc2, idProduct=2320, bcdDevice= 1.00
[    1.150034] usb 1-3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[    1.150035] usb 1-3: Product: Expansion
[    1.150036] usb 1-3: Manufacturer: Seagate
[    1.150037] usb 1-3: SerialNumber: NA45PWPH
[    1.153289] usb-storage 1-3:1.0: USB Mass Storage device detected
[    1.153347] scsi host3: usb-storage 1-3:1.0
[    1.153400] usbcore: registered new interface driver usb-storage
[    1.154371] usbcore: registered new interface driver uas
[    1.268645] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    1.286725] usb 2-2: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00
[    1.286730] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    1.286733] usb 2-2: Product: USB 10/100/1000 LAN
[    1.286736] usb 2-2: Manufacturer: Realtek
[    1.286739] usb 2-2: SerialNumber: 000001
[    1.408487] usb 1-4: new high-speed USB device number 3 using xhci_hcd
[    1.606454] usb 1-4: New USB device found, idVendor=0bc2, idProduct=ab65, bcdDevice=17.07
[    1.606458] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.606461] usb 1-4: Product: One Touch HDD
[    1.606463] usb 1-4: Manufacturer: Seagate
[    1.606464] usb 1-4: SerialNumber: 00000000NABN43P0
[    1.731729] usb 1-6: new high-speed USB device number 4 using xhci_hcd
[    1.895708] usb 1-6: New USB device found, idVendor=13d3, idProduct=56c1, bcdDevice=18.52
[    1.895710] usb 1-6: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    1.895712] usb 1-6: Product: USB2.0 HD UVC WebCam
[    1.895713] usb 1-6: Manufacturer: Azurewave
[    1.895714] usb 1-6: SerialNumber: 0x0001
[    2.018411] usb 1-8: new full-speed USB device number 5 using xhci_hcd
[    2.159171] usb 1-8: New USB device found, idVendor=13d3, idProduct=3526, bcdDevice= 1.10
[    2.159173] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.159175] usb 1-8: Product: Bluetooth Radio
[    2.159176] usb 1-8: Manufacturer: Realtek
[    2.159177] usb 1-8: SerialNumber: 00e04c000001
[    3.005273] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input19
[    3.005395] usbcore: registered new interface driver uvcvideo
[    4.332597] usbcore: registered new interface driver r8152
[    4.355039] usbcore: registered new interface driver cdc_ether
[    4.402559] usbcore: registered new interface driver btusb
[    4.455476] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
Wanted to add the journalctl, but I was limited by the amount of characters allowed in the post. Is there a way around that?
Thanks!
If I execute the commands below in the terminal, I see that the eject command is in the PATH (echo $PATH) and is provided by the package util-linux. It isn’t clear to me in your text if you are executing the command eject or if you are perhaps selecting “eject” in a GUI, maybe Thunar.
type -a eject
pacman -Fx /bin/eject
I’m a bit newby, so I don’t follow what you are thinking.
This is the thing, from Thunar, the option to eject, shows up sometimes, and sometimes it doesn’t.
When it does show up, from Thunar I click eject, and it will unmount, and then eject.
When it does show up, from Terminal:
[user@user ~]$ sudo eject /run/media/user/Elements
eject: unable to eject
When the option to eject is not available in Thunar, I simply unmount, and then disconnect it physically.
So why does it show the option to eject sometimes? Why can’t I eject from command?
Any thoughts?
Thanks for you help!
In Thunar, the eject icon appears in every mounted drive
https://imgur.com/wDz0QWS.png
If sometimes it doesn’t. kill thunar, and open again. (this happens to me, I just close thunar and reopen)
eject will work, but will not really “finish the job” regarding USB rotating drives.
The best way to unplug a USB external hard-drive, after proper unmounting, is:
udisksctl power-off -b /dev/sdX
or
udisks --detach /dev/sdX
This usually causes the drive to spin down gracefully.
Note: udisksctl might be a more “mainstream” tool, compared to udisks (the former is already installed on my Debian, the latter isn’t).
Is there a GUI plugin/app which does this? It would be convenient.
Thunar or gnome-disks
Install with, pacman -S gnome-disk-utility
This would be useful!
