Fn+ F8/F9 works to adjust the display brightness level down/up. But they do so in rather large steps. My main issue is at night. Adjusting to the lowest level, the backlight is off. Then, when going one step up, it’s rather bright. I have to use the slider on the battery right-click menu in order to turn the brightness down to a suitable level. Is there a way to make the buttons do smaller steps?
Yeah I have problem with that too! The brightness seem to go down by too much or go up by too much. For example: the lowest brightness seem to make it look like my display is broken
Somewhere there must be some software controlling this. Which means there should be a setting to modify somewhere. I tried installing windows, and there I got a bunch of small steps on the brightness hotkeys. Hopefully someone knows where that setting is.
also hey, we’re both n’s
Hello,
Both have to check from terminal, depending on video graphics model what this command shows:
ls /sys/class/backlight/
Then, depending what backlight utility you installed, then it can be set to have a different steps values for increase or decrease:
https://wiki.archlinux.org/index.php/backlight
There is also a good way to provide information, so we can help you out without guessing, or sending you to the wiki. Here it is:
Once you gathered that information, let us know.
ls /sys/class/backlight/ output:
intel_backlight
inxi:
Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=8b52075a-cc53-4c8c-a229-1e76d00bb873 rw quiet apparmor=1
security=apparmor resume=UUID=134479e5-249b-4711-8ceb-f67b95f02015
udev.log_priority=3
Desktop: MATE 1.24.0 info: mate-panel wm: marco 1.24.0 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20DM000VUS v: ThinkPad S3 Yoga 14
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20DM000VUS v: SDK0E50512 STD serial: <filter>
UEFI: LENOVO v: JGET34WW (1.20 ) date: 12/04/2018
ID-1: BAT0 charge: N/A condition: N/A volts: N/A model: N/A type: Li-ion
serial: <filter> status: Charging
Topology: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26
L2 cache: 3072 KiB
bogomips: 19160
Speed: 798 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
4: 799
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
Device-2: NVIDIA GM108M [GeForce 840M] vendor: Lenovo driver: nvidia
v: 440.100 alternate: nouveau,nvidia_drm bus ID: 04:00.0 chip ID: 10de:1341
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-7:4
chip ID: 04f2:b46a serial: <filter>
Display: x11 server: X.org 1.20.8 compositor: marco v: 1.24.0
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.1.5 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Sound Server: ALSA v: k5.7.15-1-MANJARO
Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel port: efa0
bus ID: 02:00.0 chip ID: 8086:08b2
Local Storage: total: 480.68 GiB used: 14.95 GiB (3.1%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-9WS142 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-2: /dev/sdb vendor: SanDisk model: SSD U110 16GB size: 14.91 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 001 scheme: MBR
ID-1: / raw size: 25.39 GiB size: 24.87 GiB (97.94%) used: 9.82 GiB (39.5%)
fs: ext4 dev: /dev/sda8
ID-2: /home raw size: 125.98 GiB size: 123.50 GiB (98.03%)
used: 5.13 GiB (4.2%) fs: ext4 dev: /dev/sda9
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda7
System Temperatures: cpu: 51.0 C mobo: 40.0 C
Fan Speeds (RPM): cpu: 0
Processes: 215 Uptime: 41m Memory: 7.69 GiB used: 1.67 GiB (21.7%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: 1136 pacman: 1131
lib: 341 flatpak: 5 Shell: Bash v: 5.0.18 running in: mate-terminal
inxi: 3.1.05
Yes, but your laptop has hibrid graphics.
In principle you could make use of this:
https://wiki.archlinux.org/index.php/backlight#xbacklight
ans what follow with the /etc/X11/xorg.conf.d/20-intel.conf file …
Hopefully someone that owns a hybrid GPU Laptop will come by and point you the right direction.
# ls /sys/class/backlight/
intel_backlight
# inxi -Fazy
root=UUID=b71e4128-01e3-4565-97ec-2fa0745987aa rw apparmor=1
security=apparmor resume=UUID=daf0114f-9ff9-4f2e-884d-24924538c92b
udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: SCHENKER product: SCHENKER_VIA_14_SVI14E20 v: N/A
serial: N/A Chassis: Notebook type: 10 serial: N/A
Mobo: SCHENKER model: L140CU serial: N/A UEFI: INSYDE v: 1.07.08
date: 03/27/2020
ID-1: BAT0 charge: 71.8 Wh condition: 74.4/73.9 Wh (101%) volts: 8.6/7.7
model: Notebook BAT type: Li-ion serial: status: Discharging
Topology: Quad Core model: Intel Core i5-10210U socket: BGA1528 (U3E1)
note: check bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 8E (142) stepping: C (12) microcode: D6 L2 cache: 6144 KiB
bogomips: 33615
Speed: 1802 MHz min/max: 400/4200 MHz base/boost: 1485/8300 volts: 0.8 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1786 2: 1705 3: 1748 4: 1763
5: 1779 6: 1717 7: 1705 8: 1782
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: CLEVO/KAPOK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo
bus ID: 1-7:2 chip ID: 04f2:b684 serial:
Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.5
direct render: Yes
Device-1: Intel vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:02c8
Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 3000
bus ID: 00:14.3 chip ID: 8086:02f0
IF: wlp0s20f3 state: up mac:
IF-ID-1: bridge0 state: down mac:
Local Storage: total: 931.51 GiB used: 12.14 GiB (1.3%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M81000G size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: rev: S5Z42105 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Micron model: 2200 MTFDHBA512TCK size: 476.94 GiB
serial: rev: P1MU003
ID-1: / raw size: 9.77 GiB size: 9.55 GiB (97.79%) used: 525.8 MiB (5.4%)
fs: ext4 block size: 4096 B dev: /dev/nvme0n1p3
ID-2: /usr raw size: 11.72 GiB size: 11.47 GiB (97.90%)
used: 7.15 GiB (62.4%) fs: ext4 block size: 4096 B dev: /dev/nvme0n1p5
ID-3: /var raw size: 4.88 GiB size: 4.74 GiB (97.15%) used: 1.76 GiB (37.0%)
fs: ext4 block size: 4096 B dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 25.55 GiB used: 11.5 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 358 Uptime: 1d 21h 49m Memory: 23.23 GiB used: 6.46 GiB (27.8%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1126 lib: 339
flatpak: 0 Shell: Bash (su) v: 5.0.18 running in: xfce4-terminal
inxi: 3.1.05
I don’'t have many configfiles under X11:
# ls /etc/X11/
/etc/X11/:
mhwd.d xinit xorg.conf.d/etc/X11/mhwd.d:
/etc/X11/xinit:
xinitrc xinitrc.d xserverrc/etc/X11/xinit/xinitrc.d:
40-libcanberra-gtk-module.sh 50-systemd-user.sh/etc/X11/xorg.conf.d:
00-keyboard.conf
My system does not have the xbacklight command.
That is what your system is using tho, so you have to install xbacklight package, so the command is available.
For any other issues, as mentioned, this is the way to go:
Since your system only has one GPU, intel, should be a lot more easier. Let us know how it goes.
Does it make sense to install another package for setting the brightness when the problem is not setting the brightness? As the setting works perfectly using the slider, I would guess it’s a keyboard issue. The command sent to the OS when the key is pressed is what I think should be modified.
Try this:
