I’m using a freshly installed Manjaro with all the latest updates. When running the command echo $SHELL, it returns /bin/bash. However, I’m pretty sure the shell I’m running is zsh and not bash. For instance, if I type some gibberish command it would say:
$ frenerivnreo
zsh: command not found: frenerivnreo
Stupid question from my side, but isn’t the look and feel of a zsh shell so fundamentally different from BASH that there should be hardly a chance to mix them up?
What shell is getting identified by
Yochanan is there a reason you have been chopping up my comment into segments that are bar of any content?
I have suggested a different way to check for the shell, not just simply asked “What Shell”
