Hello there,
I’m kind of blocked with my audio, that is just saying : Dummy output. I just installed Manjaro GNOME and I’m a bit frustated with the audio… I checked other post, but I don’t know if their problems are the same as mine…
Newbie here so can you be precise in what do you want exactly please…
Thanks for your help
Hello and welcome to Manjaro forum.
I know that the people here that can help will ask for your inxi Fazy from terminal
https://forum.manjaro.org/t/how-to-provide-good-information/874/9
I personally had Dummy output problem on my laptop which was resolved by updating BIOS.
There is the output from inxi -Fazy :
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=09453bc4-1850-49bd-a8c3-783bd12985e9 rw quiet apparmor=1
security=apparmor resume=UUID=a34db020-883c-4978-a99a-52179f020c61
udev.log_priority=3
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: Dell product: G3 3590 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Dell model: 0XHJ4R v: A05 serial: <filter> UEFI: Dell v: 1.11.1
date: 08/19/2020
ID-1: BAT0 charge: 39.1 Wh condition: 39.1/51.0 Wh (77%) volts: 13.1/11.4
model: BYD DELL M4GWP97 type: Li-poly serial: <filter> status: Full
Topology: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
L2 cache: 8192 KiB
bogomips: 38408
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 801 8: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Dell
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:2191
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 0c45:671f
Display: x11 server: X.org 1.20.8 compositor: gnome-shell
driver: intel,modesetting,nouveau alternate: fbdev,nv,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA TU116 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:1aeb
Sound Server: ALSA v: k5.8.6-1-MANJARO
vendor: Dell driver: r8169 v: kernel port: 3000 bus ID: 03:00.0
chip ID: 10ec:8168
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel port: 3000 bus ID: 04:00.0
chip ID: 168c:0042
IF: wlp4s0 state: up mac: <filter>
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-14:4
chip ID: 0cf3:e009
Local Storage: total: 971.58 GiB used: 6.44 GiB (0.7%)
ID-1: /dev/nvme0n1 model: PC SN520 NVMe WDC 512GB size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
serial: <filter> rev: 20220012 scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD5000LPCX-00VHAT0
size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-3: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0
size: 28.88 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: PMAP scheme: MBR
ID-1: / raw size: 67.91 GiB size: 66.34 GiB (97.69%) used: 6.31 GiB (9.5%)
fs: ext4 dev: /dev/nvme0n1p10
ID-2: /home raw size: 128.00 GiB size: 124.99 GiB (97.65%)
used: 132.1 MiB (0.1%) fs: ext4 dev: /dev/sda3
ID-1: swap-1 type: partition size: 7.45 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p4
System Temperatures: cpu: 60.0 C mobo: N/A gpu: nouveau temp: 49 C
Processes: 305 Uptime: 5m Memory: 7.58 GiB used: 1.67 GiB (22.0%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1115 lib: 300
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
And I have also an other problem, but it will be in an other post (graphic driver) and I have to look other post for this graphic problem…
And thanks for your help, i will check my manufacturer’s recommendations for bios update.
Update : After bios update, still have dummy output
Resolved
Install sof-firmware from the package manager (pamac I think), google it
and then I just follow this guide solution
system
Closed
21 September 2020 19:43
5
