Hi,
after about a year of running Manjaro XFCE on my Desktop system and two monitors directly connected to the graphics card I also wanted to transition my work notebook to Manjaro. Currently I am running Manjaro 21.0 with a 5.10 linux kernel.
The laptop is a Lenovo Thinkpad P2 Gen. 2 with a Intel i9 with integrated graphics and a dedicated Nvidia Quadro T2000 graphics card.
I am using two 1920x1200@60Hz monitors. With a windows system everything is working and being displayed correctly on both displays.
After connecting the Thunderbolt 3 dock to the notebook with Manjaro everything but the displays is working flawlessly.
Both screens are detected and show up in xrandr and the display manager.
Unfortunately if I have both screens connected they stay black and cycle through sleep mode and black screen within a few seconds without actually showing anything.
If I only connect one screen it works without a problem.
If I downscale the resolution of both displays it again works, but distorted.
I have searched through the forums, reddit and google for a couple of days now only finding similar problems without working solutions, so I thought I just throw the question in here and see if anybody has had similar problems and might point me in the right direction.
System information (without dock as I am not at home):
Kernel: 5.10.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=834325a5-63ab-41cf-8f51-8d631a264331 rw nouveau.modeset=0 quiet
resume=UUID=6b35dd2c-a671-4352-aee7-1bdf30732314 udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel, plank
wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 20QUS2VM00 v: ThinkPad P1 Gen 2
Mobo: LENOVO model: 20QUS2VM00 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: N2OET55W (1.42 )
date: 12/06/2021
ID-1: BAT0 charge: 69.2 Wh (100.0%) condition: 69.2/80.4 Wh (86.1%)
volts: 17.2 min: 15.4 model: Celxpert 5B10V98091 type: Li-poly
serial: <filter> status: Full cycles: 167
RAM: total: 15.28 GiB used: 2.12 GiB (13.9%)
RAM Report:
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 799 high: 800 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 799 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117GLM [Quadro T1000 Mobile] vendor: Lenovo
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1fb9 class-ID: 0300
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 5986:114e class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting gpu: i915 display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: Chi Mei Innolux built: 2016 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.10.105-1-MANJARO running: yes
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 52:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp82s0 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 953.87 GiB used: 82.51 GiB (8.7%)
model: MZVLB1T0HBLR-000L7 size: 953.87 GiB block-size: physical: 512 B
rev: 5M2QEXF7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 150 GiB size: 146.58 GiB (97.72%) used: 27.08 GiB (18.5%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 834325a5-63ab-41cf-8f51-8d631a264331
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
label: NO_LABEL uuid: 1AC0-2A39
ID-3: /home raw-size: 150 GiB size: 146.59 GiB (97.72%)
used: 15.64 GiB (10.7%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
label: N/A uuid: 59cf4459-8777-4ad3-a5b6-4f315d3aa8da
ID-4: /home/<filter>/Data raw-size: 344.73 GiB size: 344.73 GiB (100.00%)
used: 39.79 GiB (11.5%) fs: ntfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: data uuid: 54329F8B329F70AA
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 6b35dd2c-a671-4352-aee7-1bdf30732314
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs
label: Wiederherstellung uuid: 2E7673C2767388FB
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
uuid: 0A73-CBF3
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 300 GiB fs: ntfs label: windows
uuid: 8C1E74871E746BD8
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-2:2 info: MosArt Wireless Mouse 2.4G type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:4106 class-ID: 0301
Device-2: 1-8:3 info: Acer Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:114e
Device-3: 1-9:4 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-4: 1-11:5 info: Alcor Micro AU9540 Smartcard Reader
type: Smart Card driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 50mA chip-ID: 058f:9540 class-ID: 0b00
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.0 C pch: 55.0 C mobo: 40.0 C
Fan Speeds (RPM): cpu: 2475 fan-2: 2171
Processes: 297 Uptime: 18m wakeups: 4 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1120 lib: 308
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.13
- TheKorbi
