System Information
- Branch: Stable
- DE / WM: xfce
- CPU: Intel i9
- GPU: GEFORCE RTX 4070 Ti SUPER
- GPU Driver: video-nvidia 2024.05.03
- Kernel: 6.9.12-3-MANJARO
- Bootloader: GRUB
- Architecture: x86_64
Monitor Information
- Primary Monitor (connected to GPU): Samsung UN32J4000AF (32-inch HD TV)
- Secondary Monitor (connected to motherboard): ASUS PB278Q (27-inch WQHD IPS)
Issue Description
I’m trying to set up a dual monitor configuration using two displays with HDMI inputs. My GPU (GEFORCE RTX 4070 Ti SUPER) has one HDMI port, which is currently connected to the Samsung UN32J4000AF (a 32-inch HD TV) and working fine. I’ve connected the ASUS PB278Q monitor to the motherboard’s HDMI port, hoping to use it as a secondary display.
Both displays show output during POST, but only the Samsung TV (connected to the GPU) functions after that. The ASUS monitor (connected to the motherboard) is not detected by the OS.
What I’ve Tried
- Checked BIOS settings, but couldn’t find any obvious options for enabling the second monitor or integrated graphics.
- Verified that both displays work when connected to the GPU’s HDMI port individually.
Additional Information
Output of
lspci | grep -E "VGA|3D":*-display description: VGA compatible controller product: AD103 [GeForce RTX 4070 Ti SUPER] vendor: NVIDIA Corporation physical id: 0 bus info: pci@0000:01:00.0 logical name: /dev/fb0 logical name: /dev/fb1 version: a1 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress vga_controller bus_master cap_list rom fb configuration: depth=32 driver=nvidia latency=0 mode=2560x1440 resolution=1366,768 visual=truecolor xres=2560 yres=1440 resources: iomemory:600-5ff iomemory:640-63f irq:178 memory:81000000-81ffffff memory:6000000000-63ffffffff memory:6400000000-6401ffffff ioport:4000(size=128) memory:82000000-8207ffff *-display description: Display controller product: Raptor Lake-S GT1 [UHD Graphics 770] vendor: Intel Corporation physical id: 2 bus info: pci@0000:00:02.0 logical name: /dev/fb1 version: 04 width: 64 bits clock: 33MHz capabilities: pciexpress msi pm bus_master cap_list fb configuration: depth=32 driver=i915 latency=0 resolution=2560,1440 resources: iomemory:640-63f iomemory:400-3ff irq:153 memory:6402000000-6402ffffff memory:4000000000-400fffffff ioport:5000(size=64) memory:4010000000-4016ffffff memory:4020000000-40ffffffff -
Output of
xrandr:Screen 0: minimum 8 x 8, current 1366 x 768, maximum 32767 x 32767 HDMI-0 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 609mm x 347mm 1366x768 59.79*+ 1920x1080 59.94 50.00 29.97 25.00 23.98 1280x720 60.00 59.94 50.00 1024x768 75.03 70.07 60.00 800x600 75.00 72.19 60.32 720x576 50.00 720x480 59.94 640x480 75.00 72.81 59.94 DP-0 disconnected (normal left inverted right x axis y axis) DP-1 disconnected (normal left inverted right x axis y axis) DP-2 disconnected (normal left inverted right x axis y axis) DP-3 disconnected (normal left inverted right x axis y axis) DP-4 disconnected (normal left inverted right x axis y axis) DP-5 disconnected (normal left inverted right x axis y axis) -
Output of
lsmod | grep -E "nvidia|intel"(condensed for sake of relevance):nvidia_uvm 6701056 2 nvidia_drm 126976 10 nvidia_modeset 1605632 10 nvidia_drm nvidia 60583936 213 nvidia_uvm,nvidia_modeset intel_rapl_msr 20480 0 intel_rapl_common 40960 1 intel_rapl_msr intel_uncore_frequency 12288 0 intel_uncore_frequency_common 16384 1 intel_uncore_frequency intel_tcc_cooling 12288 0 intel_powerclamp 20480 0 kvm_intel 430080 0 intel_cstate 20480 0 intel_uncore 266240 0 intel_pmc_core 122880 0
Questions
- Why isn’t my ASUS monitor (connected to the motherboard) being detected, even though both the NVIDIA GPU and Intel integrated graphics are recognized by the system?
- Are there specific BIOS settings I should look for to enable using both the dedicated GPU and integrated graphics simultaneously?
- Do I need to create a custom Xorg configuration to use both the NVIDIA GPU and Intel integrated graphics?
- Is it possible that using a TV (Samsung UN32J4000AF) as my primary display is affecting the dual monitor setup?
- The
xrandroutput only shows HDMI and DP connections. Is there a way to enable or detect the HDMI port on the motherboard? - Are there any additional troubleshooting steps you’d recommend given this information?
I appreciate any guidance on this. Thanks to everyone for your time and attention.
