Dual monitor issues with AMD GPU
I’m currently experiencing issues with my dual monitor setup. When i connected my second monitor alongside my main monitor, some highly annoying issues appeared. Of course, i can disable the second monitor and all the issues would disappear, but that defeats the purpose of having a second monitor in the first place.
The issues mentioned are as follows:
1 - Minor screen tearing and general choppiness on main monitor
2 - New windows opening on the second monitor instead of the main one, despite the main one being marked as primary.
3 - Blurrier image quality than when used with Windows 10, despite having the same resolution.
Also, i feel that i should mention, i never experienced any of these issues using Windows 10, only the linux OS i have now. I suspect the likely cause for my issues, is the major difference in monitor resolution.
Any help on the matter would be much appreciated. If i somehow discover a solution, i will be sure to update this post.
Here’s da specs:
GPU: AMD Radeon R7 240
Primary monitor: 1920x1080 75hz (HDMI)
Secondary Monitor: 1024x768 60hz (VGA)
OS: Manjaro Linux (Kernal version 5.15.5, KDE Plasma Version 5.24.5)
You forgot to mention your DESKTOP :wink:
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
