Stephane,
Here are the outputs as requested:
inxi -Fza
Kernel: 6.1.29-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2212 quiet
systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7B79 v: 2.0
serial: <superuser required>
Mobo: Micro-Star model: X470 GAMING PLUS (MS-7B79) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.B0
date: 07/04/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2268 high: 3700 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 1790 5: 2200 6: 2200 7: 2200 8: 2200 9: 3700 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 118431
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 530.xx+ status: current (as of 2023-05) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2,DP-3 bus-ID: 27:00.0
chip-ID: 10de:2484 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,left model: Dell SE2417HG
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: right model: BenQ G2420HD
serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
API: OpenGL v: 4.5 Mesa 23.0.3 renderer: llvmpipe (LLVM 15.0.7 256 bits)
direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 27:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: Focusrite-Novation Scarlett 18i20 USB driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4:4
chip-ID: 1235:8201 class-ID: 0103 serial: <filter>
API: ALSA v: k6.1.29-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 6.94 TiB used: 0 KiB (0.0%)
model: MZVLW256HEHP-000H1 size: 238.47 GiB block-size: physical: 512 B
fw-rev: CXB73H1Q temp: 16.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM008-2DM166
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 EVO 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: BB6Q scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-6: /dev/sde maj-min: 8:64 vendor: Kingston model: DT101 II
size: 3.73 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
Message: No partition data found.
System Temperatures: cpu: 36.2 C mobo: N/A
Processes: 316 Uptime: 1m wakeups: 3 Memory: available: 31.29 GiB
used: 1.9 GiB (6.1%) Init: systemd v: 252 default: graphical tool: systemctl
Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1211
libs: 330 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
sudo parted -l
Model: ATA ST4000DM004-2CV1 (scsi)
Disk /dev/sda: 4001GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 3992GB 3992GB ntfs Data msftdata
2 3992GB 4001GB 8590MB linux-swap(v1) swap
Model: ATA ST3000DM008-2DM1 (scsi)
Disk /dev/sdb: 3001GB
Disk Flags:
1 1049kB 3001GB 3001GB ext4 Photos
Model: ATA Samsung SSD 840 (scsi)
Disk /dev/sdc: 120GB
Disk Flags:
1 1049kB 120GB 120GB ntfs Working media msftdata
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sdd: 250GB
Disk Flags:
1 1049kB 249GB 249GB ext4 Home
Model: Kingston DT101 II (scsi)
Disk /dev/sde: 4003MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 3915MB 3919MB 4194kB primary esp
Model: SAMSUNG MZVLW256HEHP-000H1 (nvme)
Disk /dev/nvme0n1: 256GB
Disk Flags:
1 1049kB 473MB 472MB ntfs Basic data partition hidden, diag
2 473MB 578MB 105MB fat32 EFI system partition boot, esp
3 578MB 595MB 16.8MB Microsoft reserved partition msftres
4 595MB 128GB 128GB ntfs Basic data partition msftdata
5 128GB 129GB 549MB ntfs hidden, diag
6 129GB 129GB 524MB fat32 boot, esp
7 129GB 245GB 115GB btrfs
sudo lsblk -fs
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squash 4.0 0 100% /run/miso/sfs/livefs
loop1 squash 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squash 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squash 4.0 0 100% /run/miso/sfs/rootfs
sda1 ntfs Data 3 16617C9C553EA822
└─sda
sda2 swap 1 d6a6be09-236e-4283-bf5e-47391939e1a0
└─sda
sdb1 ext4 1.0 Photos drive 51fa7ba2-a77f-4f23-8709-5f864bb3769c
└─sdb
sdc1 ntfs Working media 63D660E0188C87D7
└─sdc
sdd1 ext4 1.0 Home 2816b89b-ccb5-4b96-a243-33da408a1d51
└─sdd
sde1 iso966 Jolie MANJARO_KDE_2212
2023-05-18-20-31-34-00
└─sde iso966 Jolie MANJARO_KDE_2212
2023-05-18-20-31-34-00 0 100% /run/miso/bootmnt
sde2 vfat FAT12 MISO_EFI 6551-AC40
sr0
nvme0n1p1
ntfs Recovery BA2811C428118095
└─nvme0n1
nvme0n1p2
vfat FAT32 BOOT EFI 1814-70CD
└─nvme0n1
nvme0n1p3
└─nvme0n1
nvme0n1p4
ntfs 869204D19204C81F
└─nvme0n1
nvme0n1p5
ntfs 228CEA538CEA20D1
└─nvme0n1
nvme0n1p6
vfat FAT32 BOOT EFI 6755-0A3D
└─nvme0n1
nvme0n1p7
btrfs root fadf3d18-5a1a-4b9c-9045-a33c9e2d1660
└─nvme0n1
sudo efibootmgr -v
BootCurrent: 0007
Timeout: 1 seconds
BootOrder: 0007,0002,0000,0001,0005,0006
Boot0000* Windows Boot Manager HD(2,GPT,91183d2c-d34e-4f84-a1c9-e7db7839548b,0xe1800,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000034000100000010000000040000007fff0400
dp: 04 01 2a 00 02 00 00 00 00 18 0e 00 00 00 00 00 00 20 03 00 00 00 00 00 2c 3d 18 91 4e d3 84 4f a1 c9 e7 db 78 39 54 8b 02 02 / 04 04 46 00 5c 00 45 00 46 00 49 00 5c 00 4d 00 49 00 43 00 52 00 4f 00 53 00 4f 00 46 00 54 00 5c 00 42 00 4f 00 4f 00 54 00 5c 00 42 00 4f 00 4f 00 54 00 4d 00 47 00 46 00 57 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
data: 57 49 4e 44 4f 57 53 00 01 00 00 00 88 00 00 00 78 00 00 00 42 00 43 00 44 00 4f 00 42 00 4a 00 45 00 43 00 54 00 3d 00 7b 00 39 00 64 00 65 00 61 00 38 00 36 00 32 00 63 00 2d 00 35 00 63 00 64 00 64 00 2d 00 34 00 65 00 37 00 30 00 2d 00 61 00 63 00 63 00 31 00 2d 00 66 00 33 00 32 00 62 00 33 00 34 00 34 00 64 00 34 00 37 00 39 00 35 00 7d 00 00 00 34 00 01 00 00 00 10 00 00 00 04 00 00 00 7f ff 04 00
Boot0001* Manjaro HD(6,GPT,53a994f2-efd0-0744-8fb2-960ca340469d,0xf000000,0xfa000)/File(\EFI\MANJARO\GRUBX64.EFI)
dp: 04 01 2a 00 06 00 00 00 00 00 00 0f 00 00 00 00 00 a0 0f 00 00 00 00 00 f2 94 a9 53 d0 ef 44 07 8f b2 96 0c a3 40 46 9d 02 02 / 04 04 36 00 5c 00 45 00 46 00 49 00 5c 00 4d 00 41 00 4e 00 4a 00 41 00 52 00 4f 00 5c 00 47 00 52 00 55 00 42 00 58 00 36 00 34 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
Boot0002* ubuntu HD(2,GPT,91183d2c-d34e-4f84-a1c9-e7db7839548b,0xe1800,0x32000)/File(\EFI\UBUNTU\SHIMX64.EFI)
dp: 04 01 2a 00 02 00 00 00 00 18 0e 00 00 00 00 00 00 20 03 00 00 00 00 00 2c 3d 18 91 4e d3 84 4f a1 c9 e7 db 78 39 54 8b 02 02 / 04 04 34 00 5c 00 45 00 46 00 49 00 5c 00 55 00 42 00 55 00 4e 00 54 00 55 00 5c 00 53 00 48 00 49 00 4d 00 58 00 36 00 34 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
Boot0005* UEFI OS HD(6,GPT,53a994f2-efd0-0744-8fb2-960ca340469d,0xf000000,0xfa000)/File(\EFI\BOOT\BOOTX64.EFI)0000424f
dp: 04 01 2a 00 06 00 00 00 00 00 00 0f 00 00 00 00 00 a0 0f 00 00 00 00 00 f2 94 a9 53 d0 ef 44 07 8f b2 96 0c a3 40 46 9d 02 02 / 04 04 30 00 5c 00 45 00 46 00 49 00 5c 00 42 00 4f 00 4f 00 54 00 5c 00 42 00 4f 00 4f 00 54 00 58 00 36 00 34 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
data: 00 00 42 4f
Boot0006* UEFI: KingstonDT101 II 1.00 PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(10,0)/CDROM(1,0x74ad44,0x8000)0000424f
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 03 01 / 01 01 06 00 00 00 / 03 05 06 00 0a 00 / 04 02 18 00 01 00 00 00 44 ad 74 00 00 00 00 00 00 80 00 00 00 00 00 00 / 7f ff 04 00
data: 00 00 42 4f
Boot0007* UEFI: KingstonDT101 II 1.00, Partition 2 PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(10,0)/HD(2,MBR,0x0,0x74ad44,0x2000)0000424f
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 03 01 / 01 01 06 00 00 00 / 03 05 06 00 0a 00 / 04 01 2a 00 02 00 00 00 44 ad 74 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 / 7f ff 04 00
data: 00 00 42 4f
