retry with sudo :
sudo /boot/efi/EFI
sudo rm -r /boot/efi/EFI/Ubuntu
retry with sudo :
sudo /boot/efi/EFI
sudo rm -r /mnt/boot/efi/EFI/Ubuntu appears to have worked!
Now proceeding with the rest of the commands.
I’m sure I’ll be back soon.
Filesystem Type Size Used Avail Use% Mounted on
/dev/nvme0n1p2 vfat 96M 27M 70M 28% /mnt/boot/efi
sudo unmount /mnt/boot/efi
sudo: unmount: command not found
Just a query… is this:
/mnt/boot/efi/EFI/Boot/
…how the path should read now? Seems we’ve got 2 levels of boot, and 2 levels of efi.
this is umount not unmount
Gah!
Sorry.
Yes, that worked.
But then:
sudo efiboomgr -b 0002 -B
sudo: efiboomgr: command not found
We’ll get there eventually!
Ah, I think we were just missing a ‘t’!
BootCurrent: 0007
Timeout: 1 seconds
BootOrder: 0007,0000,0001,0005,0006
Boot0000* Windows Boot Manager HD(2,GPT,91183d2c-d34e-4f84-a1c9-e7db7839548b,0xe1800,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000034000100000010000000040000007fff0400
Boot0001* Manjaro HD(6,GPT,53a994f2-efd0-0744-8fb2-960ca340469d,0xf000000,0xfa000)/File(\EFI\MANJARO\GRUBX64.EFI)
Boot0005* UEFI OS HD(6,GPT,53a994f2-efd0-0744-8fb2-960ca340469d,0xf000000,0xfa000)/File(\EFI\BOOT\BOOTX64.EFI)0000424f
Boot0006* UEFI: KingstonDT101 II 1.00 PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(10,0)/CDROM(1,0x74ad44,0x8000)0000424f
Boot0007* UEFI: KingstonDT101 II 1.00, Partition 2 PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(10,0)/HD(2,MBR,0x0,0x74ad44,0x2000)0000424f
Next step:
sudo manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sde1. Check your device.map.
==> ERROR: No Linux partitions detected!
recheck
sudo parted -l
sudo lsblk -fs
sudo parted -l
Model: ATA ST4000DM004-2CV1 (scsi)
Disk /dev/sda: 4001GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 3992GB 3992GB ntfs Data msftdata
2 3992GB 4001GB 8590MB linux-swap(v1) swap
Model: ATA ST3000DM008-2DM1 (scsi)
Disk /dev/sdb: 3001GB
Disk Flags:
1 1049kB 3001GB 3001GB ext4 Photos
Model: ATA Samsung SSD 840 (scsi)
Disk /dev/sdc: 120GB
Disk Flags:
1 1049kB 120GB 120GB ntfs Working media msftdata
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sdd: 250GB
Disk Flags:
1 1049kB 249GB 249GB ext4 Home
Model: Kingston DT101 II (scsi)
Disk /dev/sde: 4003MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 3915MB 3919MB 4194kB primary esp
Model: SAMSUNG MZVLW256HEHP-000H1 (nvme)
Disk /dev/nvme0n1: 256GB
Disk Flags:
1 1049kB 473MB 472MB ntfs Basic data partition hidden, diag
2 473MB 578MB 105MB fat32 EFI system partition boot, esp
3 578MB 595MB 16.8MB Microsoft reserved partition msftres
4 595MB 128GB 128GB ntfs Basic data partition msftdata
5 128GB 129GB 549MB ntfs hidden, diag
6 129GB 129GB 524MB fat32 boot, esp
7 129GB 245GB 115GB btrfs
sudo lsblk -fs
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda1 ntfs Data 3 16617C9C553EA822 654G 82% /run/media/manjaro/Data 3
└─sda
sda2 swap 1 d6a6be09-236e-4283-bf5e-47391939e1a0
└─sda
sdb1 ext4 1.0 Photos drive 51fa7ba2-a77f-4f23-8709-5f864bb3769c
└─sdb
sdc1 ntfs Working media 63D660E0188C87D7 37.4G 67% /run/media/manjaro/Working media
└─sdc
sdd1 ext4 1.0 Home 2816b89b-ccb5-4b96-a243-33da408a1d51 154.3G 27% /run/media/manjaro/Home
└─sdd
sde1 iso9660 Joliet Extension MANJARO_KDE_2212 2023-05-18-20-31-34-00
└─sde iso9660 Joliet Extension MANJARO_KDE_2212 2023-05-18-20-31-34-00 0 100% /run/miso/bootmnt
sde2 vfat FAT12 MISO_EFI 6551-AC40
sr0
nvme0n1p1 ntfs Recovery BA2811C428118095
└─nvme0n1
nvme0n1p2 vfat FAT32 BOOT EFI 1814-70CD
└─nvme0n1
nvme0n1p3
└─nvme0n1
nvme0n1p4 ntfs 869204D19204C81F 21.7G 82% /run/media/manjaro/869204D19204C81F
└─nvme0n1
nvme0n1p5 ntfs 228CEA538CEA20D1
└─nvme0n1
nvme0n1p6 vfat FAT32 BOOT EFI 6755-0A3D
└─nvme0n1
nvme0n1p7 btrfs root fadf3d18-5a1a-4b9c-9045-a33c9e2d1660 98G 7% /run/media/manjaro/root
└─nvme0n1
have you done something , on p6 or p7 ?
Not that I recall.
I’ve been slowly working my way through all of your instructions from post #5.
And to the best of my recollection, everything I’ve done, I’ve documented here.
i see : you have not removed flag boot &esp from p6 ,
so launch gparted , select nmve , and p6 and remove flags boot & esp → confirm
All done!
retry then
Just out of interest, when I unchecked the flags for boot and efi, gparted automatically ADDED a flag for msftdata (to p6).
