Hi,
The goal is to pick old files from Dropbox to use them in Manjaro.
Installing from Pamac failed, leading to problem with keys.
During the install process the command ”makepkg -Si” (from How to Install Dropbox on Manjaro Linux – Linux Hint) resulted in
” dropbox-lnx.x86-74.4.115.tar.gz … failed (unknown public key FC918B335044912E)
dropbox-lnx.x86_64-74.4.115.tar.gz … failed (unknown public key FC918B335044912E)
==> Error: one or more PGP-signatures could not be verified!”
From the Pacman troubleshooting - Manjaro Linux I tried to remove keys ”sudo rm -r /etc/pacman.d/gnupg”. Reinstalling the keyrings ”sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring” lead to
”(3/3) Controlling the keys in the keyring [###########################################] 100%
WARNING: Public keyring not found; have you run ‘pacman-key –init’?
Error: Required key missing from keyring
Error: Could not start the transaction. (unsuspected error)
Error, no packets upgraded.”
Running 'pacman-key –init’ didn’t help.
From [Manjaro 15.12]error: key "####################" could not be looked up remotely I edited /etc/pacman.conf changing “SigLevel” from “Required DatabaseOptional” to “Never” but a new attempt to install the keyrings failed (changed /etc/pacman.conf back to its original).
I have messed it all up and don’t know how to proceed. I hope to get guidance on how to declutter my system (if needed) and make a fresh install of Dropbox.
Thank you!
When creating this topic I got a hint from “Your topic is similar to …” that “” could present a solution. Following the recommendations however gave the result:
[lars@lars-pc ~]$ sudo pacman-key --refresh-keys -u --keyserver hkps.pool.sks-keyservers.net
gpg: refreshing 1 key from hkp://hkps.pool.sks-keyservers.net
gpg: updating of a key from a keyserver failed: No data
==> Error: A local key could not be updated from the keyserver
[lars@lars-pc ~]$
Inxi -Fxza info:
[lars@lars-pc ~]$ inxi -Fxza
Kernel: 4.19.138-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
root=UUID=3aff4f56-ceff-40d6-958f-4431518a1485 rw quiet
resume=UUID=6559c9a0-b0f0-4a0b-b0ec-32aa8edef95d
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: LENOVO product: 10126 v: Lenovo H515s
serial: <filter>
Mobo: LENOVO model: Kabini CRB v: 31900058 STD serial: <filter>
UEFI: LENOVO v: I9KT36AUS date: 11/04/2013
Topology: Dual Core model: AMD E1-2500 APU with Radeon HD Graphics
bits: 64 type: MCP arch: Jaguar family: 16 (22) model-id: N/A stepping: 1
microcode: 700010F L2 cache: 1024 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 5599
Speed: 800 MHz min/max: 800/1400 MHz Core speeds (MHz): 1: 800 2: 800
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Kabini [Radeon HD 8240 / R3 Series] vendor: Lenovo
driver: radeon v: kernel bus ID: 00:01.0 chip ID: 1002:9838
Display: x11 server: X.Org 1.20.8 driver: ati,radeon unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-dpi: 96 s-size: 338x270mm (13.3x10.6")
s-diag: 433mm (17")
Monitor-1: VGA-0 res: 1280x1024 hz: 60 dpi: 96
size: 337x270mm (13.3x10.6") diag: 432mm (17")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 4.19.138-1-MANJARO LLVM 10.0.1)
v: 4.5 Mesa 20.1.5 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:01.1 chip ID: 1002:9840
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1022:780d
Sound Server: ALSA v: k4.19.138-1-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: e000 bus ID: 01:00.0 chip ID: 10ec:8136
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188EE Wireless Network Adapter vendor: Lenovo
driver: rtl8188ee v: kernel port: d000 bus ID: 02:00.0 chip ID: 10ec:8179
IF: wlp2s0 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 33.13 GiB (7.1%)
ID-1: /dev/sda vendor: Western Digital model: WD5000AAKX-08U6AA0
size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1H19 scheme: GPT
ID-1: / raw size: 143.98 GiB size: 140.72 GiB (97.74%)
used: 33.13 GiB (23.5%) fs: ext4 dev: /dev/sda9
ID-1: swap-1 type: partition size: 2.00 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda8
System Temperatures: cpu: 47.1 C mobo: N/A gpu: radeon temp: 47 C
Processes: 143 Uptime: 7m Memory: 3.31 GiB used: 1.08 GiB (32.6%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1344
lib: 419 flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal
inxi: 3.1.05
[lars@lars-pc ~]$
