Hello! I have a usb wifi adapter installed on the RTL8851BU chip, but Manjaro does not have a driver for this chip in the core. I found a driver on GitHub, but it is not being built or installed. Here is the link to the driver: GitHub - kwankiu/rtl8851bu: Linux Driver for USB WiFi Adapters that are based on the RTL8831BU and RTL8851BU Chipsets Please help me with installing the driver. I have Manjaro KDE 6.1.4 installed, the kernel is 6.10.8-1-MANJARO (64-bit).
no, no,
please familiarize yourself with the forum, itβs rules
and all the info it contains
at least provide your system info
inxi -zv8
for instance
I suggest you take one of the existing custom scripts and modify it to your use case
This is a link to a search on AUR for rtll88
β AUR (en) - Packages
Pick one and adapt it - I suggest one of the scripts depending on DKMS
