So I bought a new ASRock B550 Extreme4 that has this ethernet port “Dragon RTL8125BG” which is Dragon 2.5G
Does not work whatsoever.
Hi JoeyJoeJoe26,
Thanks for sharing it does not work, but I guess your asking if there is a solution?
for this we need a little more info.
Ok this is what i got.
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
misobasedir=manjaro misolabel=MANJARO_KDE_2011 quiet systemd.show_status=1
apparmor=1 security=apparmor
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: B550 Extreme4 serial: <filter>
BIOS: American Megatrends v: P1.20 date: 08/13/2020
Device-1: sony_controller_battery_a4:ae:12:3e:ed:4d model: N/A serial: N/A
charge: N/A status: Full
Topology: 8-Core model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 4096 KiB
bogomips: 124630
Speed: 3594 MHz min/max: 2200/3900 MHz boost: enabled Core speeds (MHz):
1: 3593 2: 2053 3: 2049 4: 2047 5: 2196 6: 2190 7: 2191 8: 2189 9: 2055
10: 2052 11: 2197 12: 2196 13: 2196 14: 2194 15: 3593 16: 2047
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Sapphire Limited driver: amdgpu v: kernel bus ID: 0a:00.0
chip ID: 1002:731f
Display: x11 server: X-Org 1.20.9 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting,radeon alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
s-diag: 987mm (38.8")
Monitor-1: DisplayPort-1 res: 3440x1440 hz: 60 dpi: 109
size: 798x335mm (31.4x13.2") diag: 865mm (34.1")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.38.0 5.8.11-1-MANJARO
LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 0a:00.1 chip ID: 1002:ab38
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 0c:00.4 chip ID: 1022:1487
Device-3: Sony DualShock 4 [CUH-ZCT2x] type: USB
driver: snd-usb-audio,sony,usbhid bus ID: 1-7.4:6 chip ID: 054c:09cc
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: N/A modules: r8169
port: f000 bus ID: 06:00.0 chip ID: 10ec:8125
Local Storage: total: 2.76 TiB used: 110.0 MiB (0.0%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 3B6Q scheme: GPT
ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
rev: 4B6Q scheme: GPT
ID-3: /dev/sdc vendor: Western Digital model: WD10EZEX-00BN5A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-4: /dev/sdd type: USB vendor: PNY model: USB 3.0 FD size: 29.53 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: PMAP
scheme: MBR
ID-1: / raw size: N/A size: 23.47 GiB used: 110.0 MiB (0.5%) fs: overlay
source: ERR-102
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 54 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 320 Uptime: 4m Memory: 31.29 GiB used: 923.5 MiB (2.9%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1201 lib: 318
flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
Seems there is no driver loaded.
you could try
sudo insmod /usr/lib/modules/5.8.11-1-MANJARO/kernel/drivers/net/ethernet/realtek/r8169.ko.xz
it says “could not insert, file exists”
Please try:
sudo mhwd -i pci network-r8168
sudo modprobe -r r8169
sudo modprobe r8168
nothing happens, it just says that the modure is not in directory im running manjaro on a live thumb drive at the moment.
Oke the r8169 should support this card (see: here ) could be that it also needs a the firmware file for that you could try.
pamac build realtek-firmware
should provide the correct firmware.
thanks
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
(as that makes our life much easier so you get helped more quickly and efficiently)
Got it
Did that work? If yes, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most :
oh, yeah it did, thank you!
