Dolphin /smb: folder stuck
The network folder feature on Dolphin has been extremely useful in sharing files between my Windows PC and my Linux PC. Up until recently, this worked really well, but has stopped working. Not sure what’s caused this, but essentially when I try to access the /smb: folder, it just gets stuck on “Loading…” forever. Don’t really know what kind of logs are relevant here, so unfortunately that’s all the information I have.
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. The output to
    smbclient --list=MYMODEM --no-pass --debuglevel=3
    would be helpful as well.
:+1:
P.S. If you want to notify me that you did provide this information, please :heart: this message and I’ll come back and have another look.
Ah, thank you. Here’s the outputs for both.
  Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=393dc682-2441-491e-b326-6055abbbce5c rw quiet
  resume=UUID=5265f823-d6dc-42ca-a845-4d14e5e2b7cf udev.log_priority=3
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Dell product: G3 3500 v: N/A serial: <filter> Chassis:
  type: 10 serial: <filter>
  Mobo: Dell model: 028HKV v: A02 serial: <filter> UEFI: Dell v: 1.5.3
  date: 10/23/2020
  ID-1: BAT0 charge: 47.1 Wh (100.0%) condition: 47.1/51.0 Wh (92.4%)
  volts: 12.8 min: 11.4 model: LGC-LGC4.474 DELL 415CG09 type: Li-ion
  serial: <filter> status: Full
  RAM: total: 7.57 GiB used: 5.07 GiB (67.0%)
  Info: Quad Core model: Intel Core i5-10300H bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: EA
  cache: L2: 8 MiB bogomips: 40009
  Speed: 1943 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 900 2: 900
  3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
  smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
  tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
  xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU117M vendor: Dell driver: nvidia v: 470.63.01
  alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f99
  class-ID: 0300
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-5:2 chip-ID: 0c45:671f class-ID: 0e02
  loaded: modesetting display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.1
  direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: sof-audio-pci
  alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  chip-ID: 8086:06c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.34 running: yes
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  port: 6000 bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0
  IF: enp4s0 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
  Local Storage: total: 1.14 TiB used: 65.01 GiB (5.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: IM2P33F3A NVMe 256GB
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: 92011031 temp: 33.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
  type: HDD rpm: 5400 serial: <filter> rev: 01 scheme: MBR
  ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
  used: 57.1 GiB (25.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  label: N/A uuid: 393dc682-2441-491e-b326-6055abbbce5c
  label: NO_LABEL uuid: F2CC-7566
  ID-3: /home/<filter>/Games raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
  used: 7.12 GiB (0.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: d8101a36-94a3-4bd7-9169-7a52da7b9784
  ID-1: swap-1 type: partition size: 8.8 GiB used: 807.2 MiB (9.0%)
  priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
  uuid: 5265f823-d6dc-42ca-a845-4d14e5e2b7cf
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-5:2 info: Microdia Integrated_Webcam_HD type: Video
  Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 48.0 C mobo: N/A
  Processes: 287 Uptime: 1d 10h 31m wakeups: 45284 Init: systemd v: 249
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1377 lib: 386
  Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
lp_load_ex: refreshing parameters
Initialising global parameters
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
Processing section "[global]"
added interface wlp0s20f3 ip=2407:7000:9a54:5c00:a730:6232:fea7:e919 bcast= netmask=ffff:ffff:ffff:ffff::
added interface wlp0s20f3 ip=192.168.1.15 bcast=192.168.1.255 netmask=255.255.255.0
Client started (version 4.14.7).
tdb(/var/cache/samba/gencache.tdb): tdb_open_ex: could not open file /var/cache/samba/gencache.tdb: Permission denied
resolve_lmhosts: Attempting lmhosts lookup for name MYMODEM<0x20>
name_resolve_bcast: Attempting broadcast lookup for name MYMODEM<0x20>
resolve_hosts: Attempting host lookup for name MYMODEM<0x20>
resolve_hosts: getaddrinfo failed for name MYMODEM [Name or service not known]
resolve_wins: WINS server resolution selected and no WINS servers listed.
do_connect: Connection to MYMODEM failed (Error NT_STATUS_INVALID_PARAMETER)
Please post your /etc/samba/smb.conf as well
Does your Windows machine use IPV6 as well? If not, disable on Manjaro too.
:thinking:
[global]
   workgroup = WORKGROUP
   dns proxy = no
   log file = /var/log/samba/%m.log
   max log size = 1000
   client min protocol = SMB2
   server role = standalone server
   passdb backend = tdbsam
   obey pam restrictions = yes
   unix password sync = yes
   passwd program = /usr/bin/passwd %u
   passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
   pam password change = yes
   map to guest = Bad Password
   usershare allow guests = yes
   name resolve order = lmhosts bcast host wins
   security = user
   guest account = nobody
   usershare path = /var/lib/samba/usershare
   usershare max shares = 100
   usershare owner only = yes
   force create mode = 0070
   force directory mode = 0070
[homes]
   comment = Home Directories
   browseable = no
   read only = yes
   create mask = 0700
   directory mask = 0700
   valid users = %S
[printers]
   comment = All Printers
   browseable = no
   path = /var/spool/samba
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
My windows PC does use IPV6 as it happens. But the problem is with accessing the smb folder in Network at all. It’s just stuck loading forever any time I try to access it. I guess I could disable IPV6 on my PC as well if that’d help with this? I just don’t see how it’d be a problem if I’ve already connected to it successfully in the past. Thanks for taking the time to help with this.
Can you access the the computer with manjaro installed from the win computer.If it was working before and not now something had to change as in an update from win or manjaro. Is the firewall or samba running.
try setting that to NT1
Disable IPV6 on the router, reboot both Windows and Manjaro and try again.
If that doesn’t help, provide the output to:
mount
Tried both of these. Since I didn’t have access to my home network for a little while, I tried to access the folder on another network. Interestingly enough, I can access the folder just fine. It seems to only happen on my home work. I also noticed that my default IP on the other networks were always my IPV4 address, as opposed to my home address being IPV6, so I figured you might be right, but unfortunately, it didn’t solve the issue.
Anyhow, output to mount:
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=3957028k,nr_inodes=989257,mode=755,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
/dev/nvme0n1p2 on / type ext4 (rw,noatime)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=17699)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
/dev/nvme0n1p1 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,nr_inodes=409600,inode64)
/dev/sda1 on /home/rydersj/Games type ext4 (rw,noatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=793380k,nr_inodes=198345,mode=700,uid=1000,gid=1000,inode64)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
Your folder is nowhere to be found, so last-ditch effort:
try connecting to IPaddress/sharename of MYMODEM instead of the name/sharename…
If even that doesn’t work, what’s the output of:
ls -al /var/cache/samba/gencache.tdb
:thinking:
No idea what changed, but it seems to be working now. I saw an update for samba recently so that might have fixed it. Either way, I appreciate that you took the time to help me with this, so thanks!
