Dolphin Segfault
When using Dolphin and right-clicking on some empty, free space to get the context-menu Dolphin segfaults.
[   88.461628] dolphin[1907]: segfault at 0 ip 00007fa422d60f1c sp 00007ffd03a13220 error 4 in libQt6Core.so.6.11.1[160f1c,7fa422c94000+439000] likely on CPU 9 (core 4, socket 0)
[   88.461670] Code: e8 69 45 12 00 eb 8e ff 15 09 b7 52 00 f3 0f 1e fa 49 89 c4 e9 11 13 f4 ff 90 0f 1f 40 00 f3 0f 1e fa 55 48 89 e5 48 83 ec 20 <48> 8b 36 64 48 8b 04 25 28 00 00 00 48 89 45 f8 31 c0 48 85 f6 74
Please supply you system details. inxi -zv8
I tested on my workstation - could not replicate
 $ kinfo
WARNING: radv is not a conformant Vulkan implementation, testing use only.
KDE Plasma Version: 6.7.2
KDE Frameworks Version: 6.27.0
Qt Version: 6.11.1
Kernel Version: 7.0.14-1-MANJARO (64-bit)
 $ dolphin --version
dolphin 26.04.2
And on my laptop - could not replicate
 $ kinfo
KDE Plasma Version: 6.6.5
Qt Version: 6.11.1
Kernel Version: 6.18.36-1-MANJARO (64-bit)
 $ dolphin --version
dolphin 26.04.2
So I am thinking there is something else going on.
I suggest disabling any additional entries in the Dolphin context menu plugins Settings/Configure Dolphin/Context menu and testing it again (log out and back in may be required). If that doesn’t fix it, disable everything in there and reenable one by one until you find the culprit.
  Kernel: 6.18.36-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=efd94e53-0761-443d-a3a7-50b1cc2ed05b rw rootflags=subvol=@
    quiet splash resume=UUID=5ceb373b-0456-4285-b2b9-ed2cde8df71e
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.27.0
  Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
    Firmware: UEFI vendor: American Megatrends v: 3211 date: 08/10/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  Device-2: hidpp_battery_1 model: Logitech M585/M590 Multi-Device Mouse
    serial: <filter> charge: 10% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 31.25 GiB used: 3.95 GiB (12.6%)
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M378A2K43DB1-CTD serial: <filter>
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
    part-no: M378A2K43CB1-CTD serial: <filter>
  Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 1+
    level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
    model-id: 8 stepping: 2 microcode: 0x800820D
    smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
    desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 1550 min/max: 1550/3400 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 1550 3: 1550
    4: 1550 5: 1550 6: 1550 7: 1550 8: 1550 9: 1550 10: 1550 11: 1550 12: 1550
    bogomips: 81442
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm lbrv
    lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
    popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
    svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 575.64.05 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-580.xx+ status: legacy-active (EOL~2028-09-xx) arch: Pascal
    code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: none off: DVI-D-1,HDMI-A-1 empty: DP-1,DP-2,DP-3
    bus-ID: 08:00.0 chip-ID: 10de:1b82 class-ID: 0300
  Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
    chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.23 with: Xwayland v: 24.1.12
    compositor: kwin_x11 driver: X: loaded: nvidia unloaded: modesetting,nouveau
    alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3840x1355 s-dpi: 92 s-size: 1059x373mm (41.69x14.69")
    s-diag: 1123mm (44.2")
  Monitor-1: DVI-D-1 mapped: DVI-D-0 note: disabled pos: bottom-l
    model: Idek Iiyama PLX2783H serial: <filter> built: 2016 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.333 green: x: 0.318 y: 0.620 blue: x: 0.153 y: 0.055 white:
    x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23") diag: 686mm (27")
    ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x960, 1152x720, 1024x768, 800x600, 640x480
  Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,top-right
    model: EIZO NANAO EV2456 serial: <filter> built: 2019 res: mode: 1920x1200
    hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2 chroma: red: x: 0.663 y: 0.329
    green: x: 0.298 y: 0.612 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
    size: 519x324mm (20.43x12.76") diag: 616mm (24.2") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024,
    1280x800, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 575.64.05
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.4.350 layers: 8 devices: N/A
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 08:00.1 chip-ID: 10de:10f0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK
    bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
  Device-4: C-Media AKG Ara USB Microphone
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0ecb:2057 class-ID: 0300
  API: ALSA v: k6.18.36-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Local Storage: total: 3.23 TiB used: 1.38 TiB (42.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1050MX300SSD1
    size: 978.09 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: R021 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WDS500G2B0A
    tech: SSD serial: <filter> fw-rev: 90WD scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD10JPVX-60JC3T1 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 1A02 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000DM010-2EP102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS55 rev: 1.02
    dev-links: cdrom
  ID-1: / raw-size: 968.99 GiB size: 968.99 GiB (100.00%)
    used: 534.34 GiB (55.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: efd94e53-0761-443d-a3a7-50b1cc2ed05b
    used: 32.4 MiB (10.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 3366-CED0
  ID-3: /home raw-size: 968.99 GiB size: 968.99 GiB (100.00%)
  ID-4: /mnt/fass raw-size: 931.51 GiB size: 931.06 GiB (99.95%)
    used: 877.33 GiB (94.2%) fs: xfs dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: 426a7d8f-0a16-41c0-8eb1-ee4dcaccbd41
  ID-5: /mnt/share raw-size: N/A size: 879.11 GiB used: 796.12 GiB (90.6%)
    fs: cifs dev: /dev/share
  ID-6: /var/cache raw-size: 968.99 GiB size: 968.99 GiB (100.00%)
  ID-7: /var/log raw-size: 968.99 GiB size: 968.99 GiB (100.00%)
    dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: 5ceb373b-0456-4285-b2b9-ed2cde8df71e
  ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sdb2 maj-min: 8:18 size: 464.94 GiB fs: ntfs label: N/A
    uuid: 8CBA5D11BA5CF962
  ID-3: /dev/sdb3 maj-min: 8:19 size: 827 MiB fs: ntfs label: N/A
    uuid: 142CF9DB2CF9B836
  ID-4: /dev/sdd1 maj-min: 8:49 size: 931.51 GiB fs: ntfs label: data
    uuid: 9AA6AFCAA6AFA56B
  Device-1: 1-1:2 info: Logitech C920 HD Pro Webcam type: video,audio
  Hub-4: 3-3:2 info: Hitachi ports: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
  Device-1: 3-3.1:4 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-2: 3-3.2:5 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-3: 3-3.3:6 info: EIZO FlexScan EV2456 type: HID
    lanes: 1 mode: 1.1 chip-ID: 056d:4027 class-ID: 0300
  Device-4: 3-4:3 info: C-Media AKG Ara USB Microphone type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 31.5 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1796 pm: pacman pkgs: 1774 libs: 441 tools: pamac pm: flatpak
    pkgs: 22
    1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    5: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 474
  1: cpu: 100% command: ps pid: 2962 mem: 4.19 MiB (0.0%)
  2: cpu: 31.9% command: syncthing pid: 841 mem: 185.1 MiB (0.5%)
  3: cpu: 31.0% command: firefox pid: 2236 mem: 623.3 MiB (1.9%)
  4: cpu: 14.8% command: firefox pid: 2645 mem: 269.8 MiB (0.8%)
  5: cpu: 12.8% command: dolphin pid: 2075 mem: 169.0 MiB (0.5%)
  Memory top: 5 of 474
  1: mem: 623.3 MiB (1.9%) command: firefox pid: 2236 cpu: 31.0%
  2: mem: 485.5 MiB (1.5%) command: plasmashell pid: 1207 cpu: 4.7%
  3: mem: 269.8 MiB (0.8%) command: firefox pid: 2645 cpu: 14.8%
  4: mem: 239.4 MiB (0.7%) command: nextcloud pid: 1612 cpu: 1.4%
  5: mem: 197.3 MiB (0.6%) command: kwin_x11 pid: 1188 cpu: 2.6%
  Processes: 474 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.42 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Zsh v: 5.9.1
    running-in: konsole inxi: 3.3.41
Interestingly enough, today it works…Dolphin is no longer segfaulting!
Hooray :smiley:
Have you done anything, or do we attribute it to lower cosmic ray levels?
a reboot would empty /tmp if using tmpfs.
Or perhaps an update happened and the system hadn’t restarted so had some incompatibility somewhere, restart forced it to use updated something.
I almost always restart as part of my troubleshooting workflow if I run into issues (unless I suspect restarting will result in loss of data).
I noted this from your system info.
It indicates that you may be using hibernation (suspend to disk).
In connection with a Nvidia GPU such suspend to disk may introduce weird behavior.
