I get this annoying issue with Dolphin where it seg faults whenever I try to move a folder with files into another with the same name.
The valgrind log is below. What I am doing is moving some wine prefix folders and files from the users folder steamuser folder as I’m restoring settings/saves after rebuilding a prefix.
This issue however happens anywhere I try to copy folders with files into another that already has said folders. Never had this issue before in non-manjaro kde distro’s
I can’t reproduce your issue, and that leads me to say it might be something on your end. Have you tried to copy the files/folders and once overwritten to delete those you don’t want anymore?
Please don’t do that, and now i have to ask if you had mixed packages from stable KDE Plasma and the GIT version ? (as we provide both), and that in combination with AUR packages related to KDE Plasma might lead to an unstable system.
Delete ~/.config/dolphinrc and also everything from ~/.cache
Run this command from terminal:
I thought maybe the crash was due to QT_QPA_PLATFORMTHEME=qt5ct not being set, but after configuring .profile to load in bash_profile correctly (otherwise it won’t load .profile), and setting that export QT_QPA_PLATFORMTHEME=qt5ct, and confirming with qt5ct and env in bash, the problem remains. Unless the setting qt5ct is causing the crash (may be default behavior also).
Another pastebin for good measure, took longer to do this time, maybe qt5ct was doing more work, basically did this with very low fps and response, but I got the crash still. (marked action start point)
I think the problem has been fixed in mainline dep, because issue does not occur for me anymore. Dolphin 20.12.2
I did create a whole new user account and folder recently… not sure if that had anything to do with it. Worth a try if you still have this issue, create a new fresh account and test.
