Hi! All the previews have stopped working in Dolphin.
I guess it has happened when I updated the system a couple of days ago.
System information …
inxi --filter --verbosity=8:
Kernel: 6.1.135-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=683125e2-1176-4786-a706-ca0a8836841d rw quiet
resume=UUID=5e31802a-970e-4d5e-83d7-114511d2b96c apparmor=1
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.13.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z390-E GAMING v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 1302 date: 09/02/2019
System RAM: total: 32 GiB available: 31.19 GiB used: 4.55 GiB (14.6%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 16 GiB
speed: 2133 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CMK32GX4M2D3000C16 serial: N/A
Device-2: ChannelA-DIMM2 type: no module installed
Device-3: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 16 GiB
Device-4: ChannelB-DIMM2 type: no module installed
Info: model: Intel Core i9-9900 bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0x102
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 99237
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tsc tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: retbleed mitigation: Enhanced IBRS
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: DP-1,HDMI-A-2 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e98 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1015x571mm (39.96x22.48")
s-diag: 1165mm (45.85")
Monitor-1: DP-1 pos: primary model: LG (GoldStar) HDR 4K serial: <filter>
built: 2022 res: mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 140 gamma: 1.2
chroma: red: x: 0.682 y: 0.310 green: x: 0.267 y: 0.663 blue: x: 0.149
y: 0.047 white: x: 0.314 y: 0.329 size: 697x392mm (27.44x15.43")
diag: 806mm (31.7") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080,
1280x720, 1024x768, 800x600, 720x480, 640x480
Monitor-2: HDMI-A-2 mapped: HDMI-2 model: LG (GoldStar) TV SSCR2
serial: <filter> built: 2024 res: mode: 3840x2160 hz: 30 scale: 100% (1)
dpi: 61 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9
modes: 3840x2160, 4096x2160, 1920x1080, 1920x1080i, 1280x1024, 1360x768,
1280x720, 1024x768, 800x600, 720x576, 720x576i, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 95 2: parse_edid:
unhandled CEA mode 93 3: parse_edid: unhandled CEA mode 94 4: parse_edid:
unhandled CEA mode 98 5: parse_edid: unhandled CEA mode 99 6: parse_edid:
unhandled CEA mode 100
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e98 memory: 15.23 GiB unified: yes
API: Vulkan v: 1.4.309 layers: N/A device: 0 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel v: 25.0.4-arch1.1
device-ID: 8086:3e98 surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
API: ALSA v: k6.1.135-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: down mac: <filter>
IF-ID-1: surfshark_ipv6 state: unknown speed: N/A duplex: N/A
mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
IF-ID-2: surfshark_wg state: unknown speed: N/A duplex: N/A mac: N/A
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3
Local Storage: total: 32.4 TiB used: 26.79 TiB (82.7%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Kingston model: SNV3S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: ERFK1N.3 temp: 29.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WUH721414ALE6L4 size: 12.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: W07G scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST12000DM0007-2GR116
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: DN01 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Hitachi model: HDS5C4040ALE630
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5700 serial: <filter> fw-rev: A250 scheme: GPT
ID-7: /dev/sde maj-min: 8:64 vendor: Kingston model: DataTraveler 3.0
size: 115.59 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: PMAP scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BDDVDRW GGC-H20L rev: 1.03
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 128 GiB size: 125.43 GiB (97.99%) used: 68.56 GiB (54.7%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: System
uuid: 683125e2-1176-4786-a706-ca0a8836841d
ID-2: /adds raw-size: 32 GiB size: 31.2 GiB (97.50%)
used: 24.38 GiB (78.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: Additions uuid: cd65db9f-63d6-4160-9994-e812f40077dc
ID-3: /apps raw-size: 273.14 GiB size: 267.79 GiB (98.04%)
used: 152.12 GiB (56.8%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: Applications uuid: f2ef4ef4-1603-4e2c-9833-e6a74c7c4dcd
ID-4: /boot/efi raw-size: 640 MiB size: 638.7 MiB (99.80%)
used: 312 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: BE78-6D97
ID-5: /hdd1 raw-size: 12.73 TiB size: 12.63 TiB (99.20%)
used: 12.14 TiB (96.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: HDD1
uuid: 04170d4f-491e-42be-aec1-f86fe19b7b09
ID-6: /hdd2 raw-size: 10.91 TiB size: 10.83 TiB (99.20%)
used: 10.08 TiB (93.1%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: HDD2
uuid: d61c8d60-2d43-4034-b61c-ed695c1361db
ID-7: /hdd3 raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 3.34 TiB (93.3%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: HDD3
uuid: da887262-1011-44ce-8a80-d096e0c4281f
ID-8: /htpc raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 941.36 GiB (25.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: HTPC
uuid: bbb9996a-6e05-430e-9221-48881bd95ddf
ID-9: /htpc/video raw-size: N/A size: 27.04 TiB used: 25.56 TiB (94.5%)
fs: fuse.mhddfs source: ERR-102
ID-10: /run/media/knight/USB3_128GB raw-size: 115.59 GiB
size: 115.59 GiB (100.00%) used: 68.71 GiB (59.4%) fs: ntfs dev: /dev/sde1
maj-min: 8:65 label: USB3_128GB uuid: 06D28729671CE38F
ID-1: swap-1 type: partition size: 32 GiB used: 15.5 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: Swap
uuid: 5e31802a-970e-4d5e-83d7-114511d2b96c
ID-1: /dev/nvme1n1p1 maj-min: 259:7 size: 100 MiB fs: vfat label: N/A
uuid: 6A37-B545
ID-2: /dev/nvme1n1p2 maj-min: 259:8 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:9 size: 930.77 GiB fs: ntfs label: N/A
uuid: C03A398D3A398208
ID-4: /dev/nvme1n1p4 maj-min: 259:10 size: 642 MiB fs: ntfs label: N/A
uuid: DA904A009049E41B
Hub-2: 1-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-6.1:4 info: Logitech Logi Bolt Receiver
type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-2: 1-6.2:5 info: Logitech Logi Bolt Receiver
Device-3: 1-6.4:6 info: ASUSTek AURA MOTHERBOARD type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:18a3 class-ID: 0300
serial: <filter>
Device-4: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Device-1: 2-8:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 Kyson
type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 504mA
chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 30.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1698 libs: 444 tools: pamac,yay
1: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
2: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
5: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
6: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
7: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
8: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 335
1: cpu: 16.9% command: chrome pid: 2772 mem: 231.7 MiB (0.7%)
2: cpu: 12.8% command: konsole pid: 3966 mem: 219.5 MiB (0.6%)
3: cpu: 7.4% command: chrome pid: 2721 mem: 457.5 MiB (1.4%)
4: cpu: 3.4% command: Xorg pid: 1471 mem: 94.4 MiB (0.2%)
5: cpu: 3.1% command: kwin_x11 pid: 1935 mem: 209.4 MiB (0.6%)
Memory top: 5 of 335
1: mem: 546.6 MiB (1.7%) command: plasmashell pid: 1964 cpu: 0.3%
2: mem: 457.5 MiB (1.4%) command: chrome pid: 2721 cpu: 7.4%
3: mem: 311.7 MiB (0.9%) command: surfshark pid: 2323 cpu: 0.7%
4: mem: 306.7 MiB (0.9%) command: tutanota-desktop pid: 2324 cpu: 0.4%
5: mem: 239.4 MiB (0.7%) command: chrome pid: 3741 cpu: 0.7%
Processes: 335 Power: uptime: 37m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,upowerd
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.38
ls -la ~/.cache/thumbnails
returns …
total 24
drwxr-xr-x 6 knight knight 4096 may 10 00:17 .
drwxr-xr-x 19 knight knight 4096 may 10 15:27 ..
drwx------ 2 knight knight 4096 may 10 00:17 large
drwx------ 2 knight knight 4096 may 10 15:36 normal
drwx------ 2 knight knight 4096 may 10 00:17 x-large
drwx------ 2 knight knight 4096 may 10 00:17 xx-large
Dolphin configuration:
· Interface > Previews:
- Show previews in the view for: Everything checked
- Local storage > Show previews for: files below 128 MiB
- Remote storage > Show previews for: files below 64 MiB
- Show previews for folders: checked
I have no addons installed for Dolphin.
Is there any other information that might be useful?
Thanks in advance!
(Sorry if my English is not good enough)
Mod edit:- System information has been transplanted to first post.
