Thank you for your reply.
Recording the journal did not produce any new entries after right-clicking and waiting. However, upon issuing the command, I did notice a few error messages in the terminal. I will write the output below:
[kenshiwara@tornado ~]$ journalctl -f
Mar 05 15:23:35 tornado dolphin[11159]: libpng warning: iCCP: known incorrect sRGB profile
Mar 05 15:23:35 tornado kioslave5[11186]: Qt: Session management error: networkIdsList argument is NULL
Mar 05 15:23:41 tornado plasmashell[1424]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Mar 05 15:23:41 tornado systemd[1278]: Started Konsole - Terminal.
Mar 05 15:23:41 tornado kwin_x11[1346]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17961, resource id: 14680186, major code: 3 (GetWindowAttributes), minor code: 0
Mar 05 15:23:41 tornado kwin_x11[1346]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 17962, resource id: 14680186, major code: 14 (GetGeometry), minor code: 0
Mar 05 15:23:49 tornado kwin_x11[1346]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18980, resource id: 73400343, major code: 18 (ChangeProperty), minor code: 0
Mar 05 15:23:49 tornado kwin_x11[1346]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18984, resource id: 31457453, major code: 18 (ChangeProperty), minor code: 0
Mar 05 15:23:52 tornado kioslave5[11248]: Qt: Session management error: networkIdsList argument is NULL
Mar 05 15:23:54 tornado systemd[1278]: Started Konsole - Terminal.
Update: I have tried the method again but this time, I tried to replicate the issue using the settings panel since it is also freezing when trying to view the custom keyboard shortcuts. The output is as follows:
Mar 05 15:31:29 tornado systemd[1278]: Started System Settings - System Settings.
Mar 05 15:31:30 tornado kwin_x11[1346]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31130, resource id: 14680236, major code:
Mar 05 15:31:30 tornado kwin_x11[1346]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 31131, resource id: 14680236, major cod
Mar 05 15:31:30 tornado systemsettings[11537]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Mar 05 15:31:30 tornado systemsettings[11537]: file:///usr/share/kpackage/kcms/kcm_landingpage/contents/ui/main.qml:130:9: QML FormLayout (parent
or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredHeight"
Mar 05 15:31:30 tornado systemsettings[11537]: file:///usr/share/kpackage/kcms/kcm_landingpage/contents/ui/main.qml:20:9: QML FormLayout (parent
Mar 05 15:31:30 tornado kwin_x11[1346]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31247, resource id: 73400329, major code:
Mar 05 15:31:59 tornado systemsettings[11537]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Mar 05 15:31:59 tornado systemsettings[11537]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:219:38: QML FocusScope: Bindi
ng loop detected for property "contentItemMaximumWidth"
Mar 05 15:31:59 tornado systemsettings[11537]: qml: The item SubCategoryPage_QMLTYPE_109(0x5610b72fe490) is already in the PageRow
Mar 05 15:32:02 tornado systemsettings[11537]: qml: The item SubCategoryPage_QMLTYPE_109(0x5610b72fe490) is already in the PageRow
Mar 05 15:32:53 tornado systemsettings[11537]: Unable to start server org.kde.khotkeys (kded module) [ "org.freedesktop.DBus.Error.NoReply" ]: "D
id not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply,
the reply timeout expired, or the network connection was broken."
Your help will be much appreciated!
