jep, i read it ( that was the reason, why my actions did not show up in the first place
inxi
Kernel: 6.8.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.8-x86_64
root=UUID=9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6 rw
resume=UUID=9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6 resume_offset=30074880
apparmor=1 security=apparmor udev.log_priority=3 sysrq_always_enabled=1
nvidia_drm.modeset=1 nvidia_drm.fbdev=1 modprobe.blacklist=nouveau
systemd.setenv=GPUMOD=nvidia nowatchdog intel_iommu=on iommu=pt
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: MSI model: P55-GD55 (MS-7589) v: 1.0
serial: <superuser required> uuid: <superuser required>
BIOS: American Megatrends v: 1.9 date: 03/02/2011
System RAM: total: 8 GiB available: 7.75 GiB used: 3.02 GiB (39.0%)
Array-1: capacity: 8 GiB slots: 4 modules: 4 EC: None
max-module-size: 2 GiB note: est.
Device-1: DIMM1 type: SDRAM detail: synchronous size: 2 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: N/A part-no: N/A serial: N/A
Device-2: DIMM2 type: SDRAM detail: synchronous size: 2 GiB
Device-3: DIMM3 type: SDRAM detail: synchronous size: 2 GiB
Device-4: DIMM4 type: SDRAM detail: synchronous size: 2 GiB
Info: model: Intel Core i7 860 bits: 64 type: MT MCP arch: Nehalem
gen: core 1 level: v2 built: 2008-10 process: Intel 45nm family: 6
model-id: 0x1E (30) stepping: 5 microcode: 0xA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1400 high: 2801 min/max: 1200/2801 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 1200
3: 1203 4: 1200 5: 2801 6: 1200 7: 1200 8: 1200 bogomips: 44923
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti
rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: none off: DVI-I-1 empty: DP-1,DVI-D-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 102 s-size: 478x269mm (18.82x10.59")
s-diag: 548mm (21.59")
Monitor-1: DVI-I-1 note: disabled model: Samsung SyncMaster
serial: <filter> built: 2010 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 970 driver: nvidia v: 550.54.14 device-ID: 10de:13c2
surfaces: xcb,xlib
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Micro-Star MSI 5 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: JMTek LLC. Lioncast_LX60_USB_Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 2-1.1:3 chip-ID: 0c76:1617 class-ID: 0300
serial: <filter>
API: ALSA v: k6.8.1-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d800 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 3.18 TiB used: 269.58 GiB (8.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD103SJ size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 00E4 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HDS5C3020ALA632
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5940 serial: <filter> fw-rev: A580 scheme: MBR
ID-1: / raw-size: 371.09 GiB size: 364.2 GiB (98.14%) used: 64.61 GiB (17.7%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: SSDRoot
uuid: 9dc4ed12-cf8e-41b5-a31c-9de5f50e8dc6
ID-2: /home raw-size: 489.27 GiB size: 480.51 GiB (98.21%)
used: 204.97 GiB (42.7%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: home
uuid: c5fcc6d4-1db5-4ec5-8ede-0f76cd6ee4ab
Kernel: swappiness: 50 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 11 GiB used: 778 MiB (6.9%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System-reserviert
uuid: 583E97273E96FD66
ID-2: /dev/sda2 maj-min: 8:2 size: 199.39 GiB fs: ntfs label: System
uuid: 0A12C25D12C24CFF
ID-3: /dev/sda3 maj-min: 8:3 size: 527 MiB fs: ntfs label: N/A
uuid: 34862028861FE95E
ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sda5 maj-min: 8:5 size: 242.25 GiB fs: ntfs label: Daten
uuid: 7024BEAB24BE73A6
ID-6: /dev/sdb2 maj-min: 8:18 size: 94.66 GiB fs: ext4 label: SSDDaten
uuid: b9358f37-9f4f-4c92-a7e7-034e046fa0f8
ID-7: /dev/sdc1 maj-min: 8:33 size: 1.15 TiB fs: ntfs label: Daten3
uuid: 86E470A6E47099DF
ID-8: /dev/sdc2 maj-min: 8:34 size: 100.18 GiB fs: ext4 label: Backup
uuid: ff56fbe9-6e09-4569-8fa8-8b97d1c923f1
ID-9: /dev/sdc3 maj-min: 8:35 size: 439.45 GiB fs: ext4 label: N/A
uuid: e1875968-aed1-42d3-b90c-be51960c7910
ID-10: /dev/sdc4 maj-min: 8:36 size: 146.48 GiB fs: ext4 label: Testsys
uuid: afafb774-fda7-444d-b5f3-8ded4befe91c
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0020
Device-1: 1-1.5:3 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 2516:0042 class-ID: 0301
Device-2: 1-1.6:4 info: USB OPTICAL MOUSE type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0400 class-ID: 0301
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:3 info: JMTek LLC. Lioncast_LX60_USB_Headset
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 0c76:1617 class-ID: 0300 serial: <filter>
Device-2: 2-1.2:4 info: Logitech F510 Gamepad [DirectInput Mode] type: HID
driver: logitech,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 500mA chip-ID: 046d:c218 class-ID: 0300
Device-3: 2-1.3:5 info: Genesys Logic USB 2.0 Card Reader
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 05e3:070e class-ID: 0806 serial: <filter>
System Temperatures: cpu: 40.0 C mobo: 32.0 C gpu: nvidia temp: 46 C
Fan Speeds (rpm): cpu: 1063 fan-1: 789 fan-3: 863 gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 3.34 vbat: 3.26
Processes: 272 Power: uptime: 10h 28m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.05 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1966 libs: 516 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: yakuake inxi: 3.3.33
Here’s the Error that shows up:
Unfortunately there is nothing in the journal, even with --priority=5.
journalctl --boot=0 --priority=4 --no-pager
~ journalctl --boot=0 --priority=4 --no-pager ✔
Mär 17 11:27:29 alexander-ms7589 kernel: core: CPUID marked event: 'bus cycles' unavailable
Mär 17 11:27:29 alexander-ms7589 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Mär 17 11:27:29 alexander-ms7589 kernel: pnp 00:06: disabling [mem 0x000c0000-0x000cffff] because it overlaps 0000:01:00.0 BAR 6 [mem 0x000c0000-0x000dffff]
Mär 17 11:27:29 alexander-ms7589 kernel: ata3.00: supports DRM functions and may not be fully accessible
Mär 17 11:27:29 alexander-ms7589 kernel: nvidia: loading out-of-tree module taints kernel.
Mär 17 11:27:29 alexander-ms7589 kernel: nvidia: module license 'NVIDIA' taints kernel.
Mär 17 11:27:29 alexander-ms7589 kernel: Disabling lock debugging due to kernel taint
Mär 17 11:27:29 alexander-ms7589 kernel: nvidia: module license taints kernel.
Mär 17 11:27:29 alexander-ms7589 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.54.14 Thu Feb 22 01:44:30 UTC 2024
Mär 17 11:27:29 alexander-ms7589 kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Mär 17 11:27:30 alexander-ms7589 kernel: ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000800-0x000000000000084F (\PMRG) (20230628/utaddress-204)
Mär 17 11:27:30 alexander-ms7589 kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Mär 17 11:27:30 alexander-ms7589 kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Mär 17 11:27:30 alexander-ms7589 kernel: usb 2-1.1: Warning! Unlikely big volume range (=1008), cval->res is probably wrong.
Mär 17 11:27:30 alexander-ms7589 kernel: usb 2-1.1: [49] FU [PCM Playback Volume] ch = 2, val = -16129/-1/16
Mär 17 11:27:30 alexander-ms7589 kernel: usb 2-1.1: Warning! Unlikely big volume range (=496), cval->res is probably wrong.
Mär 17 11:27:30 alexander-ms7589 kernel: usb 2-1.1: [50] FU [Mic Capture Volume] ch = 1, val = 0/7936/16
Mär 17 11:27:30 alexander-ms7589 kernel: kvm_intel: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
Mär 17 11:27:30 alexander-ms7589 (modprobe)[490]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Mär 17 11:27:30 alexander-ms7589 kernel: f71882fg f71882fg.2560: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
Mär 17 11:27:30 alexander-ms7589 avahi-daemon[489]: *** WARNING: Detected another IPv4 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Mär 17 11:27:30 alexander-ms7589 avahi-daemon[489]: *** WARNING: Detected another IPv6 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Mär 17 11:27:33 alexander-ms7589 dbus-broker-launch[486]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Mär 17 11:27:34 alexander-ms7589 dbus-broker-launch[742]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mär 17 11:27:34 alexander-ms7589 dbus-broker-launch[742]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Mär 17 11:27:34 alexander-ms7589 dbus-broker-launch[742]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mär 17 11:27:34 alexander-ms7589 sddm-greeter-qt6[738]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffcbde33070), parent's thread is QThread(0x618084ad14d0), current thread is QThread(0x618084b904a0)
Mär 17 11:27:35 alexander-ms7589 xdg-desktop-por[766]: No skeleton to export
Mär 17 11:27:36 alexander-ms7589 sddm-greeter-qt6[738]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.26'
Mär 17 11:27:36 alexander-ms7589 sddm-greeter-qt6[738]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.27'
Mär 17 11:27:38 alexander-ms7589 kernel: kvm_intel: L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/l1tf.html for details.
Mär 17 11:27:38 alexander-ms7589 libvirtd[593]: Operation schlug fehl: failed to read the PCI VPD data
Mär 17 11:27:49 alexander-ms7589 sddm-greeter-qt6[738]: file:///usr/share/sddm/themes/breeze/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Mär 17 11:27:50 alexander-ms7589 dbus-broker-launch[848]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Mär 17 11:27:50 alexander-ms7589 dbus-broker-launch[848]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Mär 17 11:27:50 alexander-ms7589 dbus-broker-launch[848]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Mär 17 11:27:54 alexander-ms7589 kded6[913]: kf.coreaddons: The plugin "/usr/lib/qt6/plugins/kaccounts/daemonplugins/kaccounts_kio_webdav_plugin.so" explicitly states an Id in the embedded metadata, which is different from the one derived from the filename The Id field from the KPlugin object in the metadata should be removed
Mär 17 11:27:54 alexander-ms7589 plasmashell[930]: kf.svg: The theme "Vivid-Dark-Plasma" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
Mär 17 11:27:54 alexander-ms7589 plasmashell[930]: kf.plasma.core: The theme "Vivid-Dark-Plasma" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
Mär 17 11:27:54 alexander-ms7589 kded6[913]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Mär 17 11:27:54 alexander-ms7589 kded6[913]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Mär 17 11:27:55 alexander-ms7589 plasmashell[930]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Mär 17 11:27:55 alexander-ms7589 plasmashell[930]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Mär 17 11:27:55 alexander-ms7589 plasmashell[930]: qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "stateChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMState
Mär 17 11:27:55 alexander-ms7589 plasmashell[930]: qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "connectivityChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMConnectivityState
Mär 17 11:27:55 alexander-ms7589 plasmashell[930]: qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "deviceTypeChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMDeviceType
Mär 17 11:27:55 alexander-ms7589 plasmashell[930]: qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "meteredChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMMetered
Mär 17 11:27:55 alexander-ms7589 backlighthelper[1041]: org.kde.powerdevil: no kernel backlight interface found
Mär 17 11:27:55 alexander-ms7589 org_kde_powerdevil[975]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Mär 17 11:27:55 alexander-ms7589 kwin_x11[914]: kf.svg: The theme "Vivid-Dark-Plasma" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
Mär 17 11:27:55 alexander-ms7589 kwin_x11[914]: kf.plasma.core: The theme "Vivid-Dark-Plasma" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
Mär 17 11:27:55 alexander-ms7589 org_kde_powerdevil[975]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Mär 17 11:27:56 alexander-ms7589 kded6[913]: kf.coreaddons: "Could not load plugin from /usr/lib/qt6/plugins/plasma5support/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt6/plugins/plasma5support/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden)"
Mär 17 11:27:56 alexander-ms7589 kwin_x11[914]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "qrc:/qt/qml/org/kde/desktop/private/TextFieldContextMenu.qml" and "qrc:/qt/qml/org/kde/desktop/MenuItem.qml"
Mär 17 11:27:56 alexander-ms7589 kded6[913]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Mär 17 11:27:56 alexander-ms7589 kded6[913]: kf.bluezqt: PendingCall Error: "Could not activate remote peer: unit failed."
Mär 17 11:27:56 alexander-ms7589 kded6[913]: kscreen.kded: PowerDevil SuspendSession action not available!
Mär 17 11:27:57 alexander-ms7589 pipewire-media-session[1018]: spa.bluez5: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner
Mär 17 11:27:57 alexander-ms7589 plasmashell[930]: kf.svg: The theme "Vivid-Dark-Plasma" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
Mär 17 11:27:58 alexander-ms7589 plasmashell[930]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Mär 17 11:27:58 alexander-ms7589 org_kde_powerdevil[975]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Mär 17 11:27:58 alexander-ms7589 org_kde_powerdevil[975]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Mär 17 11:27:58 alexander-ms7589 systemd[816]: app-ssh\x2dadd@autostart.service: Failed with result 'exit-code'.
Mär 17 11:27:58 alexander-ms7589 systemd[816]: Failed to start ssh-add.
Mär 17 11:27:58 alexander-ms7589 plasmashell[930]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "qrc:/qt/qml/org/kde/desktop/private/TextFieldContextMenu.qml" and "qrc:/qt/qml/org/kde/desktop/MenuItem.qml"
Mär 17 11:27:59 alexander-ms7589 kdeconnectd[1097]: 2024-03-17T11:27:59 qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "stateChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMState
Mär 17 11:27:59 alexander-ms7589 kdeconnectd[1097]: 2024-03-17T11:27:59 qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "connectivityChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMConnectivityState
Mär 17 11:27:59 alexander-ms7589 kdeconnectd[1097]: 2024-03-17T11:27:59 qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "deviceTypeChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMDeviceType
Mär 17 11:27:59 alexander-ms7589 kdeconnectd[1097]: 2024-03-17T11:27:59 qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "meteredChanged" : Type not registered with QtDBus in parameter list: QNetworkManagerInterface::NMMetered
Mär 17 11:28:00 alexander-ms7589 keepassxc[1099]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Save All" msgid_plural: "" msgctxt: "@action:button"
Mär 17 11:28:00 alexander-ms7589 keepassxc[1099]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&Yes" msgid_plural: "" msgctxt: "@action:button"
Mär 17 11:28:00 alexander-ms7589 keepassxc[1099]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Yes to All" msgid_plural: "" msgctxt: "@action:button"
Mär 17 11:28:00 alexander-ms7589 keepassxc[1099]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&No" msgid_plural: "" msgctxt: "@action:button"
Mär 17 11:28:00 alexander-ms7589 keepassxc[1099]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "No to All" msgid_plural: "" msgctxt: "@action:button"
Mär 17 11:28:00 alexander-ms7589 keepassxc[1099]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Abort" msgid_plural: "" msgctxt: "@action:button"
Mär 17 11:28:00 alexander-ms7589 keepassxc[1099]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Retry" msgid_plural: "" msgctxt: "@action:button"
Mär 17 11:28:00 alexander-ms7589 keepassxc[1099]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Ignore" msgid_plural: "" msgctxt: "@action:button"
Mär 17 11:28:02 alexander-ms7589 kwin_x11[914]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Mär 17 11:28:03 alexander-ms7589 kwin_x11[914]: kf.svg: The theme "Vivid-Dark-Plasma" uses the legacy metadata.desktop. Consider contacting the author and asking them update it to use the newer JSON format.
Mär 17 11:28:03 alexander-ms7589 plasmashell[930]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Mär 17 11:28:04 alexander-ms7589 plasmashell[930]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Mär 17 11:28:04 alexander-ms7589 plasmashell[930]: qt.qml.typeresolution.cycle: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Mär 17 11:28:04 alexander-ms7589 plasmashell[930]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Mär 17 11:28:04 alexander-ms7589 plasmashell[930]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Mär 17 11:28:06 alexander-ms7589 plasmashell[930]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Mär 17 11:28:06 alexander-ms7589 plasmashell[930]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:111:13: QML GridView: Binding loop detected for property "implicitWidth"
Mär 17 11:28:07 alexander-ms7589 plasmashell[930]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:62:17: Unable to assign [undefined] to int
Mär 17 11:28:07 alexander-ms7589 plasmashell[930]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Edit:
Just tryed with a new user…same behavior.
Added from test with clean boot.
