Do I have to update my 5.7 Kernel?
When I tried updating thru software updater I got a ton of those errors:
conflicting dependencies:- nvidia-450xx-utils and nvidia-440xx-utils are in conflict
And as far as I understand it its because my Kernel is end of life? Or at least I also have to update it.
My question is. Do I have to update my kernel and if so how should I do it without breaking things I have installed? And, Do I have to update my graphics card drivers, and if so how to do it without breaking anything?
Here is some of my system info:
[john@john-pc ~]$ inxi -F
System:    Host: john-pc Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.19.4 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASRock model: H110M-DVS R3.0 serial: <superuser/root required>
           UEFI [Legacy]: American Megatrends v: P1.20 date: 04/17/2017
CPU:       Topology: Quad Core model: Intel Core i5-7400 bits: 64 type: MCP L2 cache: 6144 KiB
           Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 440.100
           Display: x11 server: X.Org 1.20.8 driver: nvidia resolution: 1920x1080~75Hz
           OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
Audio:     Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
           Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
           Device-3: Corsair Corsair VOID PRO Surround USB Adapter type: USB driver: hid-generic,snd-usb-audio,usbhid
           Device-4: C-Media USB Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid
           Sound Server: ALSA v: k5.7.17-2-MANJARO
Network:   Device-1: Realtek RTL8192CE PCIe Wireless Network Adapter driver: rtl8192ce
           IF: wlp2s0 state: down mac: ae:ec:b2:3d:86:83
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: 70:85:c2:45:72:8b
Drives:    Local Storage: total: 1.40 TiB used: 244.51 GiB (17.1%)
           ID-1: /dev/sda vendor: Silicon Power model: SPCC Solid State Disk size: 476.94 GiB
           ID-2: /dev/sdb vendor: Silicon Power model: SPCC Solid State Disk size: 953.87 GiB
Partition: ID-1: / size: 468.45 GiB used: 244.51 GiB (52.2%) fs: ext4 dev: /dev/sda1
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 31.0 C mobo: N/A gpu: nvidia temp: 40 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Info:      Processes: 238 Uptime: 25m Memory: 15.60 GiB used: 4.96 GiB (31.8%) Shell: Bash inxi: 3.1.05
Hi!
Install kernel 5.8 and if you haven’t another one, install the last lts one, just for backup in case some went wrong. Reboot to use the new kernel, uninstall kernel 5.7, reboot and update the system
Manjaro has a tool for both of these operations.
Simply open Manjaro Settings Manager in the system area of programs, locate Kernel and install the 5.8 kernel.
To install a new graphics driver locate Hardware Configuration in the same menu above and add or remove drivers at your leisure.
Yes it is…
What’s the output of:
mhwd --listinstalled
pamac upgrade
:innocent:
Sorry for late reply, I had a very busy week. Here are the results:
[john@john-pc ~]$ mhwd --listinstalled
> Installed PCI configs:
    video-nvidia-440xx            2019.10.25               false            PCI
and
[john@john-pc ~]$ pamac upgrade
Preparing...
Cloning nodejs-nativefier build files...
Checking nodejs-nativefier dependencies...
Cloning joplin build files...
Checking joplin dependencies...
Cloning ttf-muli build files...
Checking ttf-muli dependencies...
Cloning clion build files...
Checking clion dependencies...
Cloning zoom build files...
Checking zoom dependencies...
Cloning spotify-dev build files...
Checking spotify-dev dependencies...
Cloning jdk build files...
Checking jdk dependencies...
Cloning teamviewer build files...
Checking teamviewer dependencies...
Cloning tutanota-desktop-bin build files...
Checking tutanota-desktop-bin dependencies...
Cloning simplenote-electron-bin build files...
Checking simplenote-electron-bin dependencies...
Cloning python-pysimplegui build files...
Checking python-pysimplegui dependencies...
Cloning minecraft build files...
Checking minecraft dependencies...
Cloning gitkraken build files...
Checking gitkraken dependencies...
Cloning jlink-software-and-documentation build files...
Checking jlink-software-and-documentation dependencies...
Authenticating as: john-pc (john)
Password:
Warning: removing nvidia-440xx-utils breaks dependency 'nvidia-440xx-utils' required by lib32-nvidia-440xx-utils
Add lib32-nvidia-440xx-utils to remove
Error: Failed to prepare transaction:
Resolving dependencies...
Checking inter-conflicts...
could not satisfy dependencies:
- unable to satisfy dependency 'nvidia-440xx-utils=440.100' required by linux58-nvidia-440xx
- unable to satisfy dependency 'nvidia-440xx-utils=440.100' required by linux54-nvidia-440xx
- unable to satisfy dependency 'nvidia-440xx-utils=440.100' required by linux57-nvidia-440xx
Edit build files ? [y/N] N
Transaction cancelled.
[john@john-pc ~]$
Yes, you need to update.
How? Use the mhwd-kernel tool:
sudo mhwd-kernel -i linux58
PS
This is the main culprit (to be removed):
Remove what is needed to be removed:
sudo pacman -Rsn lib32-nvidia-440xx-utils
sudo pacman -Rsn nvidia-440xx-utils
Then upgrade again:
pamac upgrade
Im still getting errors:
[john@john-pc ~]$ sudo pacman -Rsn lib32-nvidia-440xx-utils
[sudo] password for john:
checking dependencies...
:: lib32-vulkan-icd-loader optionally requires lib32-vulkan-driver: packaged vulkan driver
:: steam-manjaro optionally requires lib32-vulkan-driver: packaged vulkan driver (32bit)
Packages (1) lib32-nvidia-440xx-utils-440.100-1
Total Removed Size:  96,44 MiB
:: Do you want to remove these packages? [Y/n] y
(1/1) removing lib32-nvidia-440xx-utils        [####################################################################] 100%
xorg configuration symlink valid...
(1/1) Arming ConditionNeedsUpdate...
[john@john-pc ~]$ sudo pacman -Rsn nvidia-440xx-utils
:: removing nvidia-440xx-utils breaks dependency 'nvidia-utils' required by cuda
:: removing nvidia-440xx-utils breaks dependency 'nvidia-440xx-utils=440.100' required by linux54-nvidia-440xx
:: removing nvidia-440xx-utils breaks dependency 'nvidia-440xx-utils=440.100' required by linux57-nvidia-440xx
Preparing...
Password:
This seem to be an issue I have no solution for as linux57-nvidia-440xx is your current driver, right?
I think so
OK, then you could remove it:
sudo pacman -Rsn cuda linux54-nvidia-440xx linux57-nvidia-440xx
If upgrading works you could reinstall cuda and hopefully nvidia-450xx, after a reboot.
Thats what I got
[john@john-pc ~]$ sudo pacman -Rsn cuda linux54-nvidia-440xx linux57-nvidia-440xx
:: removing linux57-nvidia-440xx breaks dependency 'linux57-nvidia-440xx' required by linux-latest-nvidia-440xx
It’s simple, look what is written behind required by.
So you have to remove even more::
sudo pacman -Rsn linux-latest-nvidia-440xx
It’s nice to see something that doesn’t spam warning and errors.
[john@john-pc ~]$ sudo pacman -Rsn linux-latest-nvidia-440xx
Packages (2) linux57-nvidia-440xx-440.100-15  linux-latest-nvidia-440xx-5.7-2
Total Removed Size:  14,29 MiB
(1/2) removing linux-latest-nvidia-440xx        [####################################################################] 100%
(2/2) removing linux57-nvidia-440xx        [####################################################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating module dependencies...
Now pamac upgrade right?
I think there is something else to delete?
Preparing...
Password:
OK you are on a good way, then again remove the linuxxx-nvidia drivers by:
sudo pacman -Rsn linux54-nvidia-440xx linux54-nvidia-440xx cuda
Afterwards remove the utils files by:
sudo pacman -Rsn nvidia-440xx-utils lib32-nvidia-440xx-utils
Then try to upgrade and install the 5.8 kernel.
Sorry, i didnt see that second line somehow. After the first one I executed pamac upgrade and it worked:
Packages (1) linux54-nvidia-440xx-440.100-14
Total Removed Size:  14,30 MiB
:: Do you want to remove these packages? [Y/n] Y
(1/1) removing linux54-nvidia-440xx        [####################################################################] 100%
I think it is going to remove utils itself?
Preparing...
Password:
To upgrade (322):
  yarn                                  1.22.5-1                  (1.22.4-1)                      community  975,2 kB
  yakuake                               20.08.1-1                 (20.08.0-1)                     extra      399,7 kB
  wine                                  5.16-1                    (5.15-1)                        multilib   148,3 MB
  w3m                                   0.5.3.git20200507-2       (0.5.3.git20200507-1)           extra      990,2 kB
  virtualbox-guest-iso                  6.1.14-1                  (6.1.12-1)                      community  43,5 MB
  virtualbox-ext-vnc                    6.1.14-1                  (6.1.12-3)                      community  78,7 kB
  virtualbox                            6.1.14-1                  (6.1.12-3)                      community  37,1 MB
  vim-runtime                           8.2.1634-1                (8.2.1490-0.1)                  extra      6,7 MB
  user-manager                          5.19.5-1                  (5.19.4-1)                      extra      9,9 MB
  transcode                             1.1.7-34                  (1.1.7-33)                      community  1,1 MB
  thunderbird                           68.12.0-1                 (68.11.0-1)                     extra      41,3 MB
  texstudio                             3.0.1-1                   (2.12.22-1)                     community  19,9 MB
  texlive-bin                           2020.54586-5              (2020.54586-4)                  extra      14,4 MB
  telegram-desktop                      2.3.2-2                   (2.3.0-2)                       community  24,5 MB
  systemd-sysvcompat                    246.4-1                   (246.3-2)                       core       8,7 kB
  steam-manjaro                         1.0.0.66-1                (1.0.0.64-1)                    multilib   3,0 MB
  spirv-tools                           2020.4-1                  (2020.2-1)                      extra      1,5 MB
  spectacle                             20.08.1-1                 (20.08.0-1)                     extra      1,3 MB
  smartmontools                         7.1-3                     (7.1-1)                         extra      546,8 kB
  sddm-kcm                              5.19.5-1                  (5.19.4-1)                      extra      105,0 kB
  s-nail                                14.9.19-2                 (14.9.19-1)                     core       539,0 kB
  qtcreator                             4.13.0-1                  (4.12.4-2)                      extra      44,6 MB
  qbs                                   1.17.0-1                  (1.16.0-1)                      extra      2,4 MB
  python-sip                            4.19.24-1                 (4.19.23-1)                     extra      80,6 kB
  python-reportlab                      3.5.49-1                  (3.5.48-1)                      community  2,4 MB
  python-pyqt5-sip                      12.8.1-1                  (12.8.0-1)                      extra      59,1 kB
  python-pycurl                         7.43.0.6-1                (7.43.0.5-1)                    extra      98,9 kB
  python-more-itertools                 8.5.0-1                   (8.4.0-1)                       community  58,4 kB
  python-dulwich                        0.20.6-1                  (0.20.5-1)                      community  663,3 kB
  python-attrs                          20.2.0-1                  (19.3.0-4)                      extra      72,7 kB
  pycharm-community-edition             2020.2.1-1                (2020.1.4-1)                    community  138,1 MB
  python2                               2.7.18-2                  (2.7.18-1)                      extra      14,5 MB
  print-manager                         20.08.1-1                 (20.08.0-1)                     extra      448,0 kB
  powerdevil                            5.19.5-1                  (5.19.4-1)                      extra      817,4 kB
  postgresql                            12.4-1                    (12.3-2)                        extra      17,5 MB
  postfix                               3.5.6-2                   (3.5.6-1)                       extra      1,5 MB
  postgresql-libs                       12.4-1                    (12.3-2)                        extra      1,4 MB
  plasma-workspace-wallpapers           5.19.5-1                  (5.19.4-1)                      extra      41,8 MB
  plasma-pa                             5.19.5-1                  (5.19.4-1)                      extra      210,7 kB
  plasma-nm                             5.19.5-1.1                (5.19.4-1.1)                    extra      1,4 MB
  zeromq                                4.3.2-3                   (4.3.2-2)                       community  618,7 kB
  plasma-desktop                        5.19.5-1                  (5.19.4-1)                      extra      11,5 MB
  polkit-kde-agent                      5.19.5-1                  (5.19.4-1)                      extra      62,6 kB
  php                                   7.4.10-1                  (7.4.9-2)                       extra      3,9 MB
  perl-path-tiny                        0.114-1                   (0.112-2)                       community  43,5 kB
  pepper-flash                          32.0.0.433-1              (32.0.0.414-1)                  extra      8,5 MB
  pamac-tray-appindicator               9.5.10-1                  (9.5.8-1)                       extra      11,0 kB
  pamac-snap-plugin                     9.5.10-1                  (9.5.8-1)                       extra      25,3 kB
  snapd                                 2.46-1                    (2.45.2-1)                      extra      11,3 MB
  pamac-gtk                             9.5.10-1                  (9.5.8-1)                       extra      144,7 kB
  pamac-flatpak-plugin                  9.5.10-1                  (9.5.8-1)                       extra      29,3 kB
  xdg-desktop-portal-kde                5.19.5-1                  (5.19.4-1)                      extra      176,3 kB
  pipewire                              0.3.10-1                  (0.3.8-2)                       extra      1,1 MB
  pamac-cli                             9.5.10-1                  (9.5.8-1)                       extra      52,3 kB
  pamac-common                          9.5.10-1                  (9.5.8-1)                       extra      550,2 kB
  oxygen                                5.19.5-1                  (5.19.4-1)                      extra      4,8 MB
  opera-ffmpeg-codecs                   84.0.4147.135-1           (84.0.4147.105-1)               community  1,7 MB
  okular                                20.08.1-1                 (20.08.0-1)                     extra      6,9 MB
  ntfs-3g                               2017.3.23-5               (2017.3.23-4)                   extra      564,5 kB
  nano                                  5.2-1                     (5.1-1)                         core       575,6 kB
  mpd                                   0.21.25-3                 (0.21.25-1)                     extra      813,6 kB
  wildmidi                              0.4.3-3                   (0.4.3-2)                       extra      92,1 kB
  mhwd                                  0.6.5-1                   (0.6.4-3)                       core       83,6 kB
  perl-html-parser                      3.73-1                    (3.72-10)                       extra      83,1 kB
  mercurial                             5.5.1-1                   (5.5-1)                         extra      4,9 MB
  mathjax2                              2.7.9-1                   (2.7.8-1)                       community  6,3 MB
  manjaro-release                       20.1-1                    (20.1-0)                        core       15,3 kB
  manjaro-hello                         0.6.5-15                  (0.6.5-11)                      extra      116,1 kB
  llvm                                  10.0.1-2                  (10.0.1-1)                      extra      40,4 MB
  linux57-virtualbox-host-modules       6.1.14-1                  (6.1.12-10)                     extra      180,3 kB
  linux57-headers                       5.7.19-2                  (5.7.17-2)                      core       10,1 MB
  linux57                               5.7.19-2                  (5.7.17-2)                      core       88,5 MB
  linux56-rt-virtualbox-host-modules    6.1.14-1                  (6.1.12-3)                      community  179,3 kB
  linux54-virtualbox-host-modules       6.1.14-2                  (6.1.12-10)                     extra      178,2 kB
  linux54-headers                       5.4.64-1                  (5.4.60-2)                      core       9,9 MB
  linux54                               5.4.64-1                  (5.4.60-2)                      core       86,3 MB
  linux-latest-virtualbox-host-modules  5.8-1                     (5.7-2)                         community  14,9 kB
  linux-latest-headers                  5.8-1                     (5.7-2)                         community  14,9 kB
  linux-latest                          5.8-1                     (5.7-2)                         community  14,8 kB
  mkinitcpio-busybox                    1.31.1-2                  (1.31.1-1)                      core       276,8 kB
  linux-firmware                        20200901.r1699.d5f9eea-1  (20200817.r1695.7a30af1-1)      core       127,5 MB
  libsynctex                            2020.54586-5              (2020.54586-4)                  extra      54,1 kB
  libspiro                              1:20200505-2              (1:20200505-1)                  extra      17,2 kB
  libreoffice-still                     6.4.6-2                   (6.4.6-1)                       extra      137,6 MB
  libwps                                0.4.12-1                  (0.4.11-1)                      extra      1,8 MB
  libqmi                                1.26.4-1                  (1.26.2-1)                      extra      1,8 MB
  libpgm                                5.3.128-1                 (5.2.122-5)                     community  197,0 kB
  libmpdclient                          2.19-3                    (2.19-1)                        extra      78,3 kB
  libheif                               1.8.0-1                   (1.7.0-2)                       extra      237,9 kB
  libde265                              1.0.6-1                   (1.0.5-2)                       extra      360,3 kB
  libao                                 1.2.2-5                   (1.2.2-3)                       extra      57,1 kB
  lib32-vulkan-icd-loader               1.2.151-1                 (1.2.148-1)                     multilib   123,9 kB
  lib32-sqlite                          3.33.0-1                  (3.32.3-1)                      multilib   540,1 kB
  lib32-libva-mesa-driver               20.1.7-1                  (20.1.6-1)                      multilib   2,8 MB
  lib32-harfbuzz                        2.7.2-1                   (2.7.1-1)                       multilib   565,6 kB
  lib32-util-linux                      2.36-1                    (2.35.2-1)                      multilib   450,3 kB
  lib32-gnutls                          3.6.15-1                  (3.6.14-1)                      multilib   759,3 kB
  lib32-gettext                         0.21-1                    (0.20.2-1)                      multilib   1,1 MB
  lib32-faudio                          20.09-1                   (20.08-1)                       multilib   111,0 kB
  lib32-mesa                            20.1.7-1                  (20.1.6-1)                      multilib   13,0 MB
  lib32-libx11                          1.6.12-1                  (1.6.11-1)                      multilib   664,3 kB
  lib32-systemd                         246.4-1                   (246.2-1)                       multilib   540,0 kB
  lib32-libcap                          2.43-1                    (2.38-1)                        multilib   20,2 kB
  lib32-gcc-libs                        10.2.0-2                  (10.2.0-1)                      core       28,7 MB
  lib32-glibc                           2.32-3                    (2.32-2)                        core       3,7 MB
  kwrited                               5.19.5-1                  (5.19.4-1)                      extra      17,4 kB
  kwayland-integration                  5.19.5-1                  (5.19.4-1)                      extra      32,5 kB
  kwalletmanager                        20.08.1-1                 (20.08.0-1)                     extra      954,6 kB
  kwallet-pam                           5.19.5-1                  (5.19.4-1)                      extra      12,5 kB
  socat                                 1.7.3.4-2                 (1.7.3.4-1)                     extra      187,3 kB
  ksystemlog                            20.08.1-1                 (20.08.0-1)                     extra      2,1 MB
  ksysguard                             5.19.5-1                  (5.19.4-1)                      extra      847,9 kB
  ksshaskpass                           5.19.5-1                  (5.19.4-1)                      extra      28,4 kB
  kscreen                               5.19.5-1                  (5.19.4-1)                      extra      230,0 kB
  krita-plugin-gmic                     2.9.2-2                   (2.9.1-3)                       community  700,3 kB
  kontact                               20.08.1-1                 (20.08.0-1)                     extra      798,4 kB
  konsole                               20.08.1-1                 (20.08.0-1)                     extra      1,4 MB
  kolourpaint                           20.08.1-1                 (20.08.0-1)                     extra      5,9 MB
  libksane                              20.08.1-1                 (20.08.0-1)                     extra      176,6 kB
  sane                                  1.0.31-1                  (1.0.30-1)                      extra      4,1 MB
  knetattach                            5.19.5-1                  (5.19.4-1)                      extra      26,4 kB
  kmenuedit                             5.19.5-1                  (5.19.4-1)                      extra      1,1 MB
  kmail                                 20.08.1-1                 (20.08.0-1)                     extra      5,2 MB
  pim-sieve-editor                      20.08.1-1                 (20.08.0-1)                     extra      546,2 kB
  pim-data-exporter                     20.08.1-1                 (20.08.0-1)                     extra      476,2 kB
  mbox-importer                         20.08.1-1                 (20.08.0-1)                     extra      35,4 kB
  kmail-account-wizard                  20.08.1-1                 (20.08.0-1)                     extra      481,0 kB
  kleopatra                             20.08.1-1                 (20.08.0-1)                     extra      2,9 MB
  kinfocenter                           5.19.5-1                  (5.19.4-1)                      extra      1,7 MB
  systemsettings                        5.19.5-1                  (5.19.4-1)                      extra      336,9 kB
  khotkeys                              5.19.5-1                  (5.19.4-1)                      extra      2,0 MB
  khelpcenter                           20.08.1-1                 (20.08.0-1)                     extra      4,9 MB
  kget                                  20.08.1-1                 (20.08.0-1)                     extra      5,9 MB
  kgamma5                               5.19.5-1                  (5.19.4-1)                      extra      156,4 kB
  kfind                                 20.08.1-1                 (20.08.0-1)                     extra      432,3 kB
  keditbookmarks                        20.08.1-1                 (20.08.0-1)                     extra      314,9 kB
  kdialog                               20.08.1-1                 (20.08.0-1)                     extra      120,9 kB
  kdeplasma-addons                      5.19.5-1                  (5.19.4-1)                      extra      956,4 kB
  plasma-workspace                      5.19.5-1.1                (5.19.4-1.1)                    extra      7,4 MB
  libkscreen                            5.19.5-1                  (5.19.4-1)                      extra      359,9 kB
  plasma-integration                    5.19.5-1                  (5.19.4-1)                      extra      124,1 kB
  qqc2-desktop-style                    5.73.0-2                  (5.73.0-1)                      extra      72,8 kB
  kwin                                  5.19.5-1                  (5.19.4-1)                      extra      6,7 MB
  kwayland-server                       5.19.5-1                  (5.19.4-2)                      extra      1,2 MB
  kscreenlocker                         5.19.5-1                  (5.19.4-1)                      extra      195,1 kB
  milou                                 5.19.5-1                  (5.19.4-1)                      extra      98,3 kB
  libksysguard                          5.19.5-1                  (5.19.4-1)                      extra      895,0 kB
  kdepim-runtime                        20.08.1-1                 (20.08.0-1)                     extra      3,2 MB
  kdepim-addons                         20.08.1-1                 (20.08.0-1)                     extra      1,5 MB
  kontactinterface                      20.08.1-1                 (20.08.0-1)                     extra      56,6 kB
  kitinerary                            20.08.1-1                 (20.08.0-1)                     extra      1,1 MB
  zxing-cpp                             1.1.0-3                   (1.1.0-1)                       extra      708,2 kB
  kpkpass                               20.08.1-1                 (20.08.0-1)                     extra      32,4 kB
  libksieve                             20.08.1-1                 (20.08.0-1)                     extra      825,5 kB
  ktnef                                 20.08.1-1                 (20.08.0-1)                     extra      132,9 kB
  kdenlive                              20.08.1-1                 (20.08.0-1)                     extra      13,0 MB
  mlt                                   6.22.1-3                  (6.22.1-2)                      extra      826,5 kB
  kdenetwork-filesharing                20.08.1-1                 (20.08.0-1)                     extra      52,8 kB
  kdegraphics-thumbnailers              20.08.1-1                 (20.08.0-1)                     extra      41,2 kB
  libkexiv2                             20.08.1-1                 (20.08.0-1)                     extra      154,7 kB
  kdeconnect                            20.08.1-1                 (20.08.0-1)                     extra      831,8 kB
  kde-gtk-config                        5.19.5-1                  (5.19.4-1)                      extra      49,2 kB
  kde-cli-tools                         5.19.5-1                  (5.19.4-1)                      extra      928,8 kB
  kcalc                                 20.08.1-1                 (20.08.0-1)                     extra      614,8 kB
  kate                                  20.08.1-1                 (20.08.0-1)                     extra      7,0 MB
  kamera                                20.08.1-1                 (20.08.0-1)                     extra      162,3 kB
  kalarmcal                             20.08.1-1                 (20.08.0-1)                     extra      287,0 kB
  kactivitymanagerd                     5.19.5-1                  (5.19.4-1)                      extra      185,2 kB
  kaccounts-providers                   20.08.1-1                 (20.08.0-1)                     extra      52,3 kB
  k3b                                   1:20.08.1-1               (1:20.08.0-1)                   extra      11,5 MB
  libkcddb                              20.08.1-1                 (20.08.0-1)                     extra      532,6 kB
  jq                                    1.6-4                     (1.6-3)                         community  231,8 kB
  node-gyp                              7.1.0-1                   (7.0.0-2)                       community  1,3 MB
  iw                                    5.8-1                     (5.4-1)                         core       103,1 kB
  ipython                               7.18.1-1                  (7.17.0-1)                      community  1,1 MB
  python-jedi                           0.17.2-1                  (0.17.0-1)                      community  992,9 kB
  python-parso                          1:0.7.1-1                 (0.8.0-1)                       community  163,6 kB
  python-prompt_toolkit                 3.0.7-1                   (3.0.6-1)                       community  545,8 kB
  inkscape                              1.0-6                     (1.0-5)                         extra      18,7 MB
  poppler-glib                          20.09.0-1                 (0.90.1-1)                      extra      261,0 kB
  libmagick6                            6.9.11.28-1               (6.9.11.27-1)                   extra      2,4 MB
  incidenceeditor                       20.08.1-1                 (20.08.0-1)                     extra      613,2 kB
  htop                                  3.0.1-1                   (2.2.0-3)                       extra      93,2 kB
  harfbuzz-icu                          2.7.2-1                   (2.7.1-1)                       extra      7,7 kB
  hardcode-fixer                        1:r543.0321910-1          (1:r539.f812186-5)              community  18,3 kB
  gwenview                              20.08.1-1                 (20.08.0-1)                     extra      7,0 MB
  libkdcraw                             20.08.1-1                 (20.08.0-1)                     extra      42,5 kB
  libkipi                               20.08.1-1                 (20.08.0-1)                     extra      105,1 kB
  grilo                                 0.3.13-1                  (0.3.12-1)                      extra      338,3 kB
  graphviz                              2.44.1-4                  (2.44.1-3)                      extra      8,1 MB
  gnome-desktop                         1:3.36.6-1                (1:3.36.5-1)                    extra      555,7 kB
  gmic                                  2.9.2-2                   (2.9.1-3)                       community  6,5 MB
  gitlab                                13.3.5-1                  (13.2.6-1)                      community  310,0 MB
  gitlab-shell                          2:13.7.0-1                (2:13.4.0-1)                    community  11,1 MB
  nodejs                                14.10.0-1                 (14.8.0-1)                      community  8,1 MB
  libuv                                 1.39.0-1                  (1.38.1-1)                      extra      229,6 kB
  redis                                 6.0.7-1                   (6.0.6-1)                       community  847,3 kB
  gitlab-gitaly                         13.3.3-1                  (13.2.3-1)                      community  129,9 MB
  gitlab-workhorse                      8.43.0-1                  (8.37.0-1)                      community  10,4 MB
  ruby                                  2.7.1-3                   (2.7.1-2)                       extra      3,5 MB
  geogebra                              6.0.603.0-1               (6.0.596.0-2)                   community  16,8 MB
  fwupd                                 1.4.6-1                   (1.4.5-2)                       community  3,0 MB
  firefox                               80.0.1-1                  (79.0-1)                        extra      60,2 MB
  filelight                             20.08.1-1                 (20.08.0-1)                     extra      766,7 kB
  ffmpegthumbs                          20.08.1-1                 (20.08.0-1)                     extra      30,4 kB
  feh                                   3.5-1                     (3.4.1-1)                       extra      191,4 kB
  faudio                                20.09-1                   (20.08-2)                       community  125,3 kB
  f2fs-tools                            1.14.0-1                  (1.13.0-2)                      extra      191,9 kB
  eventviews                            20.08.1-1                 (20.08.0-1)                     extra      659,5 kB
  etcher                                1.5.108-1                 (1.5.104-1)                     community  68,7 MB
  efibootmgr                            17-2                      (17-1)                          core       28,1 kB
  editorconfig-core-c                   0.12.4-1                  (0.12.3-2)                      extra      31,1 kB
  dolphin-plugins                       20.08.1-1                 (20.08.0-1)                     extra      362,1 kB
  dolphin                               20.08.1-1                 (20.08.0-1)                     extra      4,1 MB
  kio-extras                            20.08.1-1                 (20.08.0-1)                     extra      1,2 MB
  talloc                                2.3.1-3                   (2.3.1-2)                       extra      50,9 kB
  discount                              2.2.7-1                   (2.2.6-2)                       extra      77,4 kB
  dhcpcd                                9.2.0-1                   (9.1.4-2)                       core       210,1 kB
  cups-filters                          1.28.1-1                  (1.27.5-1)                      extra      901,2 kB
  liblouis                              3.15.0-1                  (3.14.0-2)                      extra      2,1 MB
  imagemagick                           7.0.10.29-1               (7.0.10.26-1)                   extra      2,6 MB
  cuda                                  11.0.3-1                  (11.0.2-1)                      community  2,1 GB
  code                                  1.48.2-1                  (1.48.0-1)                      community  10,4 MB
  chromium                              85.0.4183.102-1           (84.0.4147.135-1)               extra      67,1 MB
  chromaprint                           1.5.0-2                   (1.5.0-1)                       extra      51,9 kB
  cfitsio                               1:3.49-1                  (1:3.48-1)                      extra      608,3 kB
  catimg                                2.7.0-1                   (2.6.0-2)                       community  43,6 kB
  calibre-common                        4.23.0-2                  (4.23.0-1)                      community  25,4 MB
  mathjax                               3.1.0-1                   (3.0.5-1)                       community  1,3 MB
  calendarsupport                       20.08.1-1                 (20.08.0-1)                     extra      627,0 kB
  c-ares                                1.16.1-2                  (1.16.1-1)                      extra      120,4 kB
  breeze                                5.19.5-1                  (5.19.4-1)                      extra      20,9 MB
  kdecoration                           5.19.5-1                  (5.19.4-1)                      extra      73,2 kB
  blender                               17:2.90.0-3               (17:2.83.5-2)                   community  57,4 MB
  openssh                               8.3p1-4                   (8.3p1-3)                       core       914,1 kB
  openshadinglanguage                   1.11.7.3-1                (1.10.13-1)                     community  2,2 MB
  gcc                                   10.2.0-2                  (10.2.0-1)                      core       33,1 MB
  openimageio                           2.2.6.1-1                 (2.1.18.1-2)                    community  3,9 MB
  jasper                                2.0.19-1                  (2.0.17-1)                      extra      274,3 kB
  baloo-widgets                         20.08.1-1                 (20.08.0-1)                     extra      117,3 kB
  poppler-qt5                           20.09.0-1                 (0.90.1-1)                      extra      187,9 kB
  poppler                               20.09.0-1                 (0.90.1-1)                      extra      1,4 MB
  exiv2                                 0.27.3-1                  (0.27.2-2)                      extra      2,1 MB
  gettext                               0.21-1                    (0.20.2-1)                      core       2,2 MB
  avr-binutils                          2.35-1                    (2.34-2)                        community  2,0 MB
  binutils                              2.35-2                    (2.35-1)                        core       5,6 MB
  ark                                   20.08.1-1                 (20.08.0-1)                     extra      1,4 MB
  apr-util                              1.6.1-8                   (1.6.1-7)                       extra      175,0 kB
  appstream-glib                        0.7.18-1                  (0.7.17-1)                      extra      499,3 kB
  python-setuptools                     1:50.3.0-1                (1:49.6.0-1)                    extra      574,9 kB
  gtk3                                  1:3.24.23-1               (1:3.24.22-1)                   extra      11,8 MB
  at-spi2-core                          2.36.1-1                  (2.36.0-1)                      extra      259,1 kB
  gtk-update-icon-cache                 1:3.24.23-1               (1:3.24.22-1)                   extra      15,7 kB
  akonadi-notes                         20.08.1-1                 (20.08.0-1)                     extra      34,5 kB
  akonadi-import-wizard                 20.08.1-1                 (20.08.0-1)                     extra      722,5 kB
  mailcommon                            20.08.1-1                 (20.08.0-1)                     extra      845,8 kB
  messagelib                            20.08.1-1                 (20.08.0-1)                     extra      6,5 MB
  kmbox                                 20.08.1-1                 (20.08.0-1)                     extra      29,9 kB
  libgravatar                           20.08.1-1                 (20.08.0-1)                     extra      51,6 kB
  kdepim-apps-libs                      20.08.1-1                 (20.08.0-1)                     extra      112,5 kB
  grantleetheme                         20.08.1-1                 (20.08.0-1)                     extra      62,8 kB
  libkleo                               20.08.1-1                 (20.08.0-1)                     extra      614,9 kB
  mailimporter                          20.08.1-1                 (20.08.0-1)                     extra      234,2 kB
  pimcommon                             20.08.1-1                 (20.08.0-1)                     extra      569,0 kB
  akonadi-search                        20.08.1-1                 (20.08.0-1)                     extra      261,7 kB
  xapian-core                           1:1.4.17-2                (1:1.4.16-1)                    extra      2,4 MB
  kldap                                 20.08.1-1                 (20.08.0-1)                     extra      212,4 kB
  kimap                                 20.08.1-1                 (20.08.0-1)                     extra      244,4 kB
  libkdepim                             20.08.1-1                 (20.08.0-1)                     extra      131,6 kB
  akonadi-calendar                      20.08.1-1                 (20.08.0-1)                     extra      500,8 kB
  akonadi-contacts                      20.08.1-1                 (20.08.0-1)                     extra      570,6 kB
  qrencode                              4.1.0-1                   (4.0.2-2)                       extra      41,0 kB
  kcalutils                             20.08.1-1                 (20.08.0-1)                     extra      306,5 kB
  kidentitymanagement                   20.08.1-1                 (20.08.0-1)                     extra      113,3 kB
  kpimtextedit                          20.08.1-1                 (20.08.0-1)                     extra      361,8 kB
  kmailtransport                        20.08.1-1                 (20.08.0-1)                     extra      256,9 kB
  libkgapi                              20.08.1-1                 (20.08.0-1)                     extra      504,1 kB
  ksmtp                                 20.08.1-1                 (20.08.0-1)                     extra      60,9 kB
  akonadi-mime                          20.08.1-1                 (20.08.0-1)                     extra      188,1 kB
  kmime                                 20.08.1-1                 (20.08.0-1)                     extra      173,6 kB
  akonadi                               20.08.1-1                 (20.08.0-1)                     extra      859,4 kB
  libakonadi                            20.08.1-1                 (20.08.0-1)                     extra      1,9 MB
  kaccounts-integration                 20.08.1-1                 (20.08.0-1)                     extra      118,4 kB
  vmaf                                  1.5.3-1                   (1.5.2-1)                       community  831,5 kB
  libssh                                0.9.4-2                   (0.9.4-1)                       extra      199,9 kB
  snappy                                1.1.8-2                   (1.1.8-1)                       extra      25,5 kB
  python                                3.8.5-2                   (3.8.5-1)                       extra      31,5 MB
  signon-kwallet-extension              20.08.1-1                 (20.08.0-1)                     extra      12,9 kB
  gnupg                                 2.2.23-1                  (2.2.21-1)                      core       2,5 MB
  libksba                               1.4.0-2                   (1.4.0-1)                       core       138,6 kB
  accountsservice                       0.6.55-3                  (0.6.55-2)                      extra      173,7 kB
  accounts-qml-module                   0.7-3                     (0.7-2)                         extra      57,9 kB
  qt5-declarative                       5.15.0-2                  (5.15.0-1)                      extra      5,1 MB
  qt5-base                              5.15.0-5                  (5.15.0-4)                      extra      13,5 MB
  gnutls                                3.6.15-1                  (3.6.14-2)                      core       2,9 MB
  md4c                                  0.4.5-1                   (0.4.4-1)                       extra      82,5 kB
  libxkbcommon-x11                      1.0.0-1                   (0.10.0-1)                      extra      22,1 kB
  libxkbcommon                          1.0.0-1                   (0.10.0-1)                      extra      199,4 kB
  mesa                                  20.1.7-1                  (20.1.6-1)                      extra      14,8 MB
  libx11                                1.6.12-1                  (1.6.11-1)                      extra      2,2 MB
  libwacom                              1.5-1                     (1.4.1-1)                       extra      90,9 kB
  systemd                               246.4-1                   (246.3-2)                       core       6,2 MB
  libpsl                                0.21.1-1                  (0.21.0-2)                      core       81,5 kB
  util-linux                            2.36-3                    (2.36-2)                        core       2,6 MB
  shadow                                4.8.1-4                   (4.8.1-3)                       core       1,2 MB
  libxcrypt                             4.4.17-1                  (4.4.16-3)                      core       91,8 kB
  kmod                                  27-2                      (27-1)                          core       107,1 kB
  harfbuzz                              2.7.2-1                   (2.7.1-1)                       extra      826,9 kB
  libutil-linux                         2.36-3                    (2.36-2)                        core       426,6 kB
  libcap-ng                             0.7.11-2                  (0.7.10-1)                      core       38,5 kB
  systemd-libs                          246.4-1                   (246.3-2)                       core       519,6 kB
  libgpg-error                          1.39-1                    (1.38-1)                        core       237,0 kB
  libcap                                2.43-1                    (2.42-1)                        core       59,4 kB
  vulkan-icd-loader                     1.2.151-1                 (1.2.148-1)                     extra      116,2 kB
  llvm-libs                             10.0.1-2                  (10.0.1-1)                      extra      22,3 MB
  libedit                               20191231_3.1-2            (20191231_3.1-1)                core       109,8 kB
  sqlite                                3.33.0-2                  (3.33.0-1)                      core       1,8 MB
  gcc-libs                              10.2.0-2                  (10.2.0-1)                      core       33,1 MB
  glibc                                 2.32-4                    (2.32-2)                        core       10,3 MB
  iana-etc                              20200905-1                (20200812-1)                    core       398,8 kB
  linux-api-headers                     5.8-1                     (5.7-1)                         core       1,1 MB
  libjpeg-turbo                         2.0.5-2                   (2.0.5-1)                       extra      460,1 kB
To install (12):
  xapp                                  1.8.10-1                  (Replaces: xapps)               community  159,4 kB
  linux54-rt-virtualbox-host-modules    6.1.14-1                                                  community  177,0 kB
  linux54-rt                            5.4.61_rt37-1                                             community  92,2 MB
  libsidplayfp                          2.0.2-1                                                   community  143,1 kB
  linux58-virtualbox-host-modules       6.1.14-0                                                  extra      182,3 kB
  linux58-headers                       5.8.6-1                                                   core       10,2 MB
  linux58                               5.8.6-1                                                   core       89,9 MB
  lib32-libxcrypt                       4.4.17-1                                                  multilib   81,1 kB
  pybind11                              2.5.0-1                                                   community  218,0 kB
  pugixml                               1.10-2                                                    community  100,4 kB
  fmt                                   7.0.3-1                                                   extra      415,9 kB
  nvidia-450xx-utils                    450.66-1                  (Replaces: nvidia-libgl)        extra      90,4 MB
To build (15):
  zoom                                  5.3.465578.0920-1         (5.1.418436.0628-1)             AUR
  tutanota-desktop-bin                  3.76.9-1                  (3.74.2-1)                      AUR
  ttf-muli                              3.000-2                   (3.000-1)                       AUR
  teamviewer                            15.10.5-1                 (15.9.5-1)                      AUR
  spotify-dev                           1.1.42.622-1              (1.1.26.501-1)                  AUR
  simplenote-electron-bin               1.21.1-1                  (1.19.0-1)                      AUR
  python-pysimplegui                    4.29.0-1                  (4.22.0-1)                      AUR
  nodejs-nativefier                     10.1.0-1                  (9.0.0-2)                       AUR
  minecraft                             2.1.16102-2               (2.1.15166-1)                   AUR
  joplin                                1.1.4-1                   (1.0.233-1)                     AUR
  jlink-software-and-documentation      30:6.86-1                 (29:6.84-1)                     AUR
  jdk                                   15-1                      (14.0.2-1)                      AUR
  jre                                   15-1                      (14.0.2-1)                      AUR
  gitkraken                             7.3.2-1                   (7.3.0-1)                       AUR
  clion                                 1:2020.2.3-1              (1:2020.2.1-1)                  AUR
To remove (2):
  nvidia-440xx-utils                    440.100-1                 (Conflicts With: nvidia-libgl)  extra
  xapps                                 1.8.9-3                   (Conflicts With: xapp)
Total download size: 4,9 GB
Total installed size: 859,8 MB
Total removed size: 307,5 MB
Apply transaction ? [y/N] y
Enter: y
i did :slight_smile:, my internet here is pretty bad, it says it will complete in about 60 minutes, I will post how it went when it completes or fails :smiley:
OK, that’s long.
Next time I would rather update using pacman as there is an option (the “w”) first to download all packages:
sudo pacman -Syuw
After download is complete immediately run
sudo pacman -Su
