It finished, it failed to build minecraft at the end for some reason tho. What should I do now?
Post the log with error message.
I couldnt scroll high enough to include everything:
> joplin@1.0.168 postinstall /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/CliClient
> npm run build && patch-package --patch-dir ../patches
> joplin@1.0.168 build /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/CliClient
> gulp build
[22:00:47] Using gulpfile /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/CliClient/gulpfile.js
[22:00:47] Starting 'build'...
[22:00:47] Starting 'prepareBuild'...
[22:00:48] Finished 'prepareBuild' after 638 ms
[22:00:48] Starting 'compileExtensions'...
[22:00:48] Finished 'compileExtensions' after 859 ฮผs
[22:00:48] Starting 'copyLib'...
[22:00:48] Finished 'copyLib' after 164 ms
[22:00:48] Finished 'build' after 805 ms
patch-package 6.2.2
Applying patches...
htmlparser2@4.1.0 โ
sax@1.2.4 โ
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
added 825 packages from 857 contributors and audited 902 packages in 78.425s
3 packages are looking for funding
run `npm fund` for details
found 10 vulnerabilities (8 low, 2 high)
run `npm audit fix` to fix them, or `npm audit` for details
[22:00:49] Using gulpfile /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/gulpfile.js
[22:00:49] Starting 'build'...
[22:00:49] Starting 'copyLib'...
[22:00:50] Finished 'copyLib' after 184 ms
[22:00:50] Starting 'tsc'...
[22:00:54] Finished 'tsc' after 4.08 s
[22:00:54] Starting 'updateIgnoredTypeScriptBuild'...
[22:00:54] Finished 'updateIgnoredTypeScriptBuild' after 439 ms
[22:00:54] Finished 'build' after 4.7 s
npm WARN @typescript-eslint/eslint-plugin@2.10.0 requires a peer of eslint@^5.0.0 || ^6.0.0 but none is installed. You must install peer dependencies yourself.
npm WARN @typescript-eslint/parser@2.10.0 requires a peer of eslint@^5.0.0 || ^6.0.0 but none is installed. You must install peer dependencies yourself.
npm WARN eslint-plugin-import@2.20.2 requires a peer of eslint@2.x - 6.x but none is installed. You must install peer dependencies yourself.
npm WARN eslint-plugin-react@7.18.0 requires a peer of eslint@^3.0.0 || ^4.0.0 || ^5.0.0 || ^6.0.0 but none is installed. You must install peer dependencies yourself.
npm WARN eslint-plugin-react-hooks@2.4.0 requires a peer of eslint@^3.0.0 || ^4.0.0 || ^5.0.0 || ^6.0.0 but none is installed. You must install peer dependencies yourself.
audited 827 packages in 488.959s
29 packages are looking for funding
found 4 low severity vulnerabilities
โญโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโฎ
โ โ
โ New patch version of npm available! 6.14.7 โ 6.14.8 โ
โ Changelog: https://github.com/npm/cli/releases/tag/v6.14.8 โ
โ Run npm install -g npm to update! โ
โ โ
โฐโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโฏ
> gulp build
[22:00:59] Using gulpfile /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/CliClient/gulpfile.js
[22:00:59] Starting 'build'...
[22:00:59] Starting 'prepareBuild'...
[22:00:59] Finished 'prepareBuild' after 700 ms
[22:00:59] Starting 'compileExtensions'...
[22:00:59] Finished 'compileExtensions' after 3.23 ms
[22:00:59] Starting 'copyLib'...
[22:00:59] Finished 'copyLib' after 215 ms
[22:00:59] Finished 'build' after 922 ms
patch-package 6.2.2
Applying patches...
htmlparser2@4.1.0 โ
sax@1.2.4 โ
audited 902 packages in 4.892s
4 packages are looking for funding
> Joplin@1.1.4 postinstall /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/ElectronClient
> npm run build && gulp electronRebuild
> Joplin@1.1.4 build /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/ElectronClient
> patch-package --patch-dir ../patches && gulp build
patch-package 6.2.2
Applying patches...
htmlparser2@4.1.0 โ
sax@1.2.4 โ
[22:01:06] Using gulpfile /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/ElectronClient/gulpfile.js
[22:01:06] Starting 'build'...
[22:01:06] Starting 'compileScripts'...
[22:01:06] Starting 'compilePackageInfo'...
[22:01:06] Starting 'copyPluginAssets'...
[22:01:06] Starting 'copyTinyMceLangs'...
[22:01:06] Starting 'updateIgnoredTypeScriptBuild'...
[22:01:06] Starting 'compileExtensions'...
Copying to /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/ElectronClient/tools/../gui/note-viewer/pluginAssets
Copying /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/ElectronClient/tools/../../Modules/TinyMCE/langs => /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/ElectronClient/tools/../node_modules/tinymce/langs
[22:01:07] Finished 'compileScripts' after 461 ms
[22:01:07] Finished 'compilePackageInfo' after 461 ms
[22:01:07] Finished 'compileExtensions' after 472 ms
[22:01:07] Starting 'copyLib'...
[22:01:07] Finished 'updateIgnoredTypeScriptBuild' after 473 ms
Copying to /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/ElectronClient/tools/../pluginAssets
[22:01:07] Finished 'copyTinyMceLangs' after 524 ms
[22:01:07] Finished 'copyPluginAssets' after 569 ms
[22:01:07] Finished 'copyLib' after 140 ms
[22:01:07] Finished 'build' after 614 ms
[22:01:07] Using gulpfile /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/ElectronClient/gulpfile.js
[22:01:07] Starting 'electronRebuild'...
Running: "/var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/ElectronClient/tools/../node_modules/.bin/electron-rebuild"
[22:01:08] Finished 'electronRebuild' after 647 ms
npm WARN ajv-keywords@3.4.1 requires a peer of ajv@^6.9.1 but none is installed. You must install peer dependencies yourself.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: 7zip-bin-win@2.2.0 (node_modules/7zip-bin-win):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for 7zip-bin-win@2.2.0: wanted {"os":"win32","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: 7zip-bin-mac@1.0.1 (node_modules/7zip-bin-mac):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for 7zip-bin-mac@1.0.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/glob-watcher/node_modules/fsevents):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.0 (node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.0: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/babel-cli/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
added 1 package from 1 contributor and audited 1411 packages in 7.558s
14 packages are looking for funding
found 9 low severity vulnerabilities
> Joplin@1.1.4 dist /var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/ElectronClient
> electron-builder
โข electron-builder version=22.3.2 os=5.7.17-2-MANJARO
โข loaded configuration file=package.json ("build" field)
โข electron-rebuild not required if you use electron-builder, please consider to remove excess dependency from devDependencies
To ensure your native dependencies are always matched electron version, simply add script `"postinstall": "electron-builder install-app-deps" to your `package.json`
โข writing effective config file=dist/builder-effective-config.yaml
โข skipped dependencies rebuild reason=npmRebuild is set to false
โข packaging platform=linux arch=x64 electron=8.2.5 appOutDir=dist/linux-unpacked
โข building target=AppImage arch=x64 file=dist/Joplin-1.1.4.AppImage
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
strip: Unable to recognise the format of the input file `./usr/share/joplin/resources/app.asar.unpacked/node_modules/7zip-bin-linux/arm64/7za'
strip: Unable to recognise the format of the input file `./usr/share/joplin/resources/app.asar.unpacked/node_modules/7zip-bin-linux/arm/7za'
-> Compressing man and info pages...
==> Checking for packaging issues...
==> WARNING: Package contains reference to $srcdir
usr/share/joplin-cli/node_modules/stream-shift/package.json
usr/share/joplin-cli/node_modules/ansi-gray/package.json
usr/share/joplin-cli/node_modules/unorm/package.json
usr/share/joplin-cli/node_modules/ansi-styles/package.json
usr/share/joplin-cli/node_modules/diacritics/package.json
usr/share/joplin-cli/node_modules/tr46/package.json
usr/share/joplin-cli/node_modules/tr46/node_modules/punycode/package.json
usr/share/joplin-cli/node_modules/invert-kv/package.json
usr/share/joplin-cli/node_modules/nice-try/package.json
usr/share/joplin-cli/node_modules/jsonfile/package.json
usr/share/joplin-cli/node_modules/for-each-property-deep/package.json
usr/share/joplin-cli/node_modules/get-stdin/package.json
usr/share/joplin-cli/node_modules/abbrev/package.json
usr/share/joplin-cli/node_modules/is-utf8/package.json
usr/share/joplin-cli/node_modules/duplexify/package.json
usr/share/joplin-cli/node_modules/chalk/package.json
usr/share/joplin-cli/node_modules/camelcase/package.json
usr/share/joplin-cli/node_modules/lodash.repeat/package.json
usr/share/joplin-cli/node_modules/tree-kit/package.json
usr/share/joplin-cli/node_modules/clean-html/package.json
usr/share/joplin-cli/node_modules/clean-html/node_modules/readable-stream/package.json
usr/share/joplin-cli/node_modules/clean-html/node_modules/minimist/package.json
usr/share/joplin-cli/node_modules/clean-html/node_modules/string_decoder/package.json
usr/share/joplin-cli/node_modules/clean-html/node_modules/domutils/package.json
usr/share/joplin-cli/node_modules/clean-html/node_modules/domelementtype/package.json
usr/share/joplin-cli/node_modules/clean-html/node_modules/domhandler/package.json
usr/share/joplin-cli/node_modules/clean-html/node_modules/htmlparser2/package.json
usr/share/joplin-cli/node_modules/clean-html/node_modules/safe-buffer/package.json
usr/share/joplin-cli/node_modules/nanomatch/package.json
usr/share/joplin-cli/node_modules/nanomatch/node_modules/is-windows/package.json
usr/share/joplin-cli/node_modules/ansi-colors/package.json
usr/share/joplin-cli/node_modules/lcid/package.json
usr/share/joplin-cli/node_modules/unpack-string/package.json
usr/share/joplin-cli/node_modules/xtend/package.json
usr/share/joplin-cli/node_modules/arr-union/package.json
usr/share/joplin-cli/node_modules/magicli/package.json
usr/share/joplin-cli/node_modules/iota-array/package.json
usr/share/joplin-cli/node_modules/decompress-response/package.json
usr/share/joplin-cli/node_modules/is-docker/package.json
usr/share/joplin-cli/node_modules/findup-sync/package.json
usr/share/joplin-cli/node_modules/shebang-regex/package.json
usr/share/joplin-cli/node_modules/fined/package.json
usr/share/joplin-cli/node_modules/os-tmpdir/package.json
usr/share/joplin-cli/node_modules/browser-process-hrtime/package.json
usr/share/joplin-cli/node_modules/caseless/package.json
usr/share/joplin-cli/node_modules/compare-version/package.json
usr/share/joplin-cli/node_modules/rimraf/package.json
usr/share/joplin-cli/node_modules/wrappy/package.json
usr/share/joplin-cli/node_modules/uid-safe/package.json
usr/share/joplin-cli/node_modules/format/package.json
usr/share/joplin-cli/node_modules/jsprim/package.json
usr/share/joplin-cli/node_modules/strip-ansi/package.json
usr/share/joplin-cli/node_modules/mdurl/package.json
usr/share/joplin-cli/node_modules/esprima/package.json
usr/share/joplin-cli/node_modules/normalize-path/package.json
usr/share/joplin-cli/node_modules/font-awesome-filetypes/package.json
usr/share/joplin-cli/node_modules/object-to-arguments/package.json
usr/share/joplin-cli/node_modules/object-to-arguments/node_modules/magicli/package.json
usr/share/joplin-cli/node_modules/object-to-arguments/node_modules/inspect-parameters-declaration/package.json
usr/share/joplin-cli/node_modules/whatwg-url/package.json
usr/share/joplin-cli/node_modules/end-of-stream/package.json
usr/share/joplin-cli/node_modules/fancy-log/package.json
usr/share/joplin-cli/node_modules/commander/package.json
usr/share/joplin-cli/node_modules/setimmediate/package.json
usr/share/joplin-cli/node_modules/is-stream/package.json
usr/share/joplin-cli/node_modules/cliui/package.json
usr/share/joplin-cli/node_modules/cliui/node_modules/strip-ansi/package.json
usr/share/joplin-cli/node_modules/cliui/node_modules/wrap-ansi/package.json
usr/share/joplin-cli/node_modules/cliui/node_modules/ansi-regex/package.json
usr/share/joplin-cli/node_modules/cliui/node_modules/string-width/package.json
usr/share/joplin-cli/node_modules/cliui/node_modules/is-fullwidth-code-point/package.json
usr/share/joplin-cli/node_modules/fragment-cache/package.json
usr/share/joplin-cli/node_modules/ndarray/package.json
usr/share/joplin-cli/node_modules/typedarray/package.json
usr/share/joplin-cli/node_modules/glob-stream/package.json
usr/share/joplin-cli/node_modules/pngjs/package.json
usr/share/joplin-cli/node_modules/base64-js/package.json
usr/share/joplin-cli/node_modules/w3c-hr-time/package.json
usr/share/joplin-cli/node_modules/moment/package.json
usr/share/joplin-cli/node_modules/color-convert/package.json
usr/share/joplin-cli/node_modules/global-prefix/package.json
usr/share/joplin-cli/node_modules/global-prefix/node_modules/is-windows/package.json
usr/share/joplin-cli/node_modules/source-map/package.json
usr/share/joplin-cli/node_modules/jasmine-core/package.json
usr/share/joplin-cli/node_modules/default-compare/package.json
usr/share/joplin-cli/node_modules/default-compare/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/last-run/package.json
usr/share/joplin-cli/node_modules/has-value/package.json
usr/share/joplin-cli/node_modules/load-json-file/package.json
usr/share/joplin-cli/node_modules/load-json-file/node_modules/pify/package.json
usr/share/joplin-cli/node_modules/node-persist/package.json
usr/share/joplin-cli/node_modules/clean-css/package.json
usr/share/joplin-cli/node_modules/code-point-at/package.json
usr/share/joplin-cli/node_modules/@yarnpkg/lockfile/package.json
usr/share/joplin-cli/node_modules/validate-npm-package-license/package.json
usr/share/joplin-cli/node_modules/klaw/package.json
usr/share/joplin-cli/node_modules/has-values/package.json
usr/share/joplin-cli/node_modules/has-values/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/unset-value/package.json
usr/share/joplin-cli/node_modules/unset-value/node_modules/has-value/package.json
usr/share/joplin-cli/node_modules/unset-value/node_modules/has-value/node_modules/isobject/package.json
usr/share/joplin-cli/node_modules/unset-value/node_modules/has-values/package.json
usr/share/joplin-cli/node_modules/buffer-equal/package.json
usr/share/joplin-cli/node_modules/follow-redirects/package.json
usr/share/joplin-cli/node_modules/xml2js/package.json
usr/share/joplin-cli/node_modules/dashdash/package.json
usr/share/joplin-cli/node_modules/object.defaults/package.json
usr/share/joplin-cli/node_modules/parse-node-version/package.json
usr/share/joplin-cli/node_modules/get-value/package.json
usr/share/joplin-cli/node_modules/temp/package.json
usr/share/joplin-cli/node_modules/to-through/package.json
usr/share/joplin-cli/node_modules/snapdragon-node/package.json
usr/share/joplin-cli/node_modules/snapdragon-node/node_modules/is-descriptor/package.json
usr/share/joplin-cli/node_modules/snapdragon-node/node_modules/define-property/package.json
usr/share/joplin-cli/node_modules/snapdragon-node/node_modules/is-data-descriptor/package.json
usr/share/joplin-cli/node_modules/snapdragon-node/node_modules/is-accessor-descriptor/package.json
usr/share/joplin-cli/node_modules/resolve-options/package.json
usr/share/joplin-cli/node_modules/braces/package.json
usr/share/joplin-cli/node_modules/braces/node_modules/extend-shallow/package.json
usr/share/joplin-cli/node_modules/json-stable-stringify-without-jsonify/package.json
usr/share/joplin-cli/node_modules/nopt/package.json
usr/share/joplin-cli/node_modules/buffer-from/package.json
usr/share/joplin-cli/node_modules/oauth-sign/package.json
usr/share/joplin-cli/node_modules/async-mutex/package.json
usr/share/joplin-cli/node_modules/linkify-it/package.json
usr/share/joplin-cli/node_modules/is-typedarray/package.json
usr/share/joplin-cli/node_modules/path-root/package.json
usr/share/joplin-cli/node_modules/tar-stream/package.json
usr/share/joplin-cli/node_modules/tar-stream/node_modules/readable-stream/package.json
usr/share/joplin-cli/node_modules/tar-stream/node_modules/string_decoder/package.json
usr/share/joplin-cli/node_modules/tar-stream/node_modules/safe-buffer/package.json
usr/share/joplin-cli/node_modules/es6-weak-map/package.json
usr/share/joplin-cli/node_modules/resolve/package.json
usr/share/joplin-cli/node_modules/wrap-ansi/package.json
usr/share/joplin-cli/node_modules/glob-watcher/package.json
usr/share/joplin-cli/node_modules/which/package.json
usr/share/joplin-cli/node_modules/slice-ansi/package.json
usr/share/joplin-cli/node_modules/webidl-conversions/package.json
usr/share/joplin-cli/node_modules/aproba/package.json
usr/share/joplin-cli/node_modules/matchdep/package.json
usr/share/joplin-cli/node_modules/matchdep/node_modules/findup-sync/package.json
usr/share/joplin-cli/node_modules/matchdep/node_modules/is-glob/package.json
usr/share/joplin-cli/node_modules/resolve-dir/package.json
usr/share/joplin-cli/node_modules/aws4/package.json
usr/share/joplin-cli/node_modules/set-value/package.json
usr/share/joplin-cli/node_modules/set-value/node_modules/extend-shallow/package.json
usr/share/joplin-cli/node_modules/js-tokens/package.json
usr/share/joplin-cli/node_modules/object.pick/package.json
usr/share/joplin-cli/node_modules/pascalcase/package.json
usr/share/joplin-cli/node_modules/async-settle/package.json
usr/share/joplin-cli/node_modules/wordwrapjs/package.json
usr/share/joplin-cli/node_modules/osenv/package.json
usr/share/joplin-cli/node_modules/unique-stream/package.json
usr/share/joplin-cli/node_modules/har-validator/package.json
usr/share/joplin-cli/node_modules/har-validator/node_modules/json-schema-traverse/package.json
usr/share/joplin-cli/node_modules/har-validator/node_modules/fast-deep-equal/package.json
usr/share/joplin-cli/node_modules/har-validator/node_modules/ajv/package.json
usr/share/joplin-cli/node_modules/statuses/package.json
usr/share/joplin-cli/node_modules/cross-spawn/package.json
usr/share/joplin-cli/node_modules/cross-spawn/node_modules/semver/package.json
usr/share/joplin-cli/node_modules/semver-greatest-satisfied-range/package.json
usr/share/joplin-cli/node_modules/readdirp/package.json
usr/share/joplin-cli/node_modules/wide-align/package.json
usr/share/joplin-cli/node_modules/lazystream/package.json
usr/share/joplin-cli/node_modules/abab/package.json
usr/share/joplin-cli/node_modules/lower-case/package.json
usr/share/joplin-cli/node_modules/read-chunk/package.json
usr/share/joplin-cli/node_modules/assign-symbols/package.json
usr/share/joplin-cli/node_modules/loose-envify/package.json
usr/share/joplin-cli/node_modules/promise/package.json
usr/share/joplin-cli/node_modules/find-yarn-workspace-root/package.json
usr/share/joplin-cli/node_modules/find-yarn-workspace-root/node_modules/fs-extra/package.json
usr/share/joplin-cli/node_modules/@cronvel/get-pixels/package.json
usr/share/joplin-cli/node_modules/node-abi/package.json
usr/share/joplin-cli/node_modules/tough-cookie/package.json
usr/share/joplin-cli/node_modules/tough-cookie/node_modules/punycode/package.json
usr/share/joplin-cli/node_modules/combined-stream/package.json
usr/share/joplin-cli/node_modules/acorn-walk/package.json
usr/share/joplin-cli/node_modules/tunnel-agent/package.json
usr/share/joplin-cli/node_modules/union-value/package.json
usr/share/joplin-cli/node_modules/forever-agent/package.json
usr/share/joplin-cli/node_modules/color-support/package.json
usr/share/joplin-cli/node_modules/fs-minipass/package.json
usr/share/joplin-cli/node_modules/pinkie/package.json
usr/share/joplin-cli/node_modules/aws-sdk/package.json
usr/share/joplin-cli/node_modules/aws-sdk/node_modules/uuid/package.json
usr/share/joplin-cli/node_modules/aws-sdk/node_modules/sax/package.json
usr/share/joplin-cli/node_modules/pinkie-promise/package.json
usr/share/joplin-cli/node_modules/is-binary-path/package.json
usr/share/joplin-cli/node_modules/p-locate/package.json
usr/share/joplin-cli/node_modules/tar-fs/package.json
usr/share/joplin-cli/node_modules/ret/package.json
usr/share/joplin-cli/node_modules/nextgen-events/package.json
usr/share/joplin-cli/node_modules/html-minifier/package.json
usr/share/joplin-cli/node_modules/glob/package.json
usr/share/joplin-cli/node_modules/through2/package.json
usr/share/joplin-cli/node_modules/through2/node_modules/readable-stream/package.json
usr/share/joplin-cli/node_modules/through2/node_modules/process-nextick-args/package.json
usr/share/joplin-cli/node_modules/through2/node_modules/string_decoder/package.json
usr/share/joplin-cli/node_modules/d/package.json
usr/share/joplin-cli/node_modules/pipe-functions/package.json
usr/share/joplin-cli/node_modules/is-windows/package.json
usr/share/joplin-cli/node_modules/mime-types/package.json
usr/share/joplin-cli/node_modules/uslug/package.json
usr/share/joplin-cli/node_modules/relative/package.json
usr/share/joplin-cli/node_modules/relative/node_modules/isobject/package.json
usr/share/joplin-cli/node_modules/color/package.json
usr/share/joplin-cli/node_modules/color/node_modules/color-convert/package.json
usr/share/joplin-cli/node_modules/levn/package.json
usr/share/joplin-cli/node_modules/micromatch/package.json
usr/share/joplin-cli/node_modules/string-to-stream/package.json
usr/share/joplin-cli/node_modules/is-descriptor/package.json
usr/share/joplin-cli/node_modules/is-descriptor/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/pend/package.json
usr/share/joplin-cli/node_modules/component-emitter/package.json
usr/share/joplin-cli/node_modules/set-blocking/package.json
usr/share/joplin-cli/node_modules/graceful-fs/package.json
usr/share/joplin-cli/node_modules/json-schema-traverse/package.json
usr/share/joplin-cli/node_modules/hosted-git-info/package.json
usr/share/joplin-cli/node_modules/nan/package.json
usr/share/joplin-cli/node_modules/mute-stdout/package.json
usr/share/joplin-cli/node_modules/snapdragon/package.json
usr/share/joplin-cli/node_modules/snapdragon/node_modules/extend-shallow/package.json
usr/share/joplin-cli/node_modules/snapdragon/node_modules/define-property/package.json
usr/share/joplin-cli/node_modules/to-object-path/package.json
usr/share/joplin-cli/node_modules/to-object-path/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/fast-json-stable-stringify/package.json
usr/share/joplin-cli/node_modules/clone-buffer/package.json
usr/share/joplin-cli/node_modules/require-main-filename/package.json
usr/share/joplin-cli/node_modules/yargs/package.json
usr/share/joplin-cli/node_modules/yargs/node_modules/camelcase/package.json
usr/share/joplin-cli/node_modules/yargs/node_modules/strip-ansi/package.json
usr/share/joplin-cli/node_modules/yargs/node_modules/ansi-regex/package.json
usr/share/joplin-cli/node_modules/yargs/node_modules/string-width/package.json
usr/share/joplin-cli/node_modules/yargs/node_modules/is-fullwidth-code-point/package.json
usr/share/joplin-cli/node_modules/yargs/node_modules/yargs-parser/package.json
usr/share/joplin-cli/node_modules/npm-packlist/package.json
usr/share/joplin-cli/node_modules/markdown-it-sup/package.json
usr/share/joplin-cli/node_modules/qs/package.json
usr/share/joplin-cli/node_modules/split-skip/package.json
usr/share/joplin-cli/node_modules/minipass/package.json
usr/share/joplin-cli/node_modules/bl/package.json
usr/share/joplin-cli/node_modules/bl/node_modules/readable-stream/package.json
usr/share/joplin-cli/node_modules/bl/node_modules/string_decoder/package.json
usr/share/joplin-cli/node_modules/bl/node_modules/safe-buffer/package.json
usr/share/joplin-cli/node_modules/console-control-strings/package.json
usr/share/joplin-cli/node_modules/querystring/package.json
usr/share/joplin-cli/node_modules/just-debounce/package.json
usr/share/joplin-cli/node_modules/to-regex/package.json
usr/share/joplin-cli/node_modules/levenshtein/package.json
usr/share/joplin-cli/node_modules/markdown-it-expand-tabs/package.json
usr/share/joplin-cli/node_modules/universalify/package.json
usr/share/joplin-cli/node_modules/array-slice/package.json
usr/share/joplin-cli/node_modules/uuid/package.json
usr/share/joplin-cli/node_modules/needle/package.json
usr/share/joplin-cli/node_modules/needle/node_modules/debug/package.json
usr/share/joplin-cli/node_modules/needle/node_modules/ms/package.json
usr/share/joplin-cli/node_modules/y18n/package.json
usr/share/joplin-cli/node_modules/async-each/package.json
usr/share/joplin-cli/node_modules/emphasize/package.json
usr/share/joplin-cli/node_modules/emphasize/node_modules/ansi-styles/package.json
usr/share/joplin-cli/node_modules/emphasize/node_modules/chalk/package.json
usr/share/joplin-cli/node_modules/emphasize/node_modules/strip-ansi/package.json
usr/share/joplin-cli/node_modules/emphasize/node_modules/ansi-regex/package.json
usr/share/joplin-cli/node_modules/emphasize/node_modules/supports-color/package.json
usr/share/joplin-cli/node_modules/emphasize/node_modules/highlight.js/package.json
usr/share/joplin-cli/node_modules/now-and-later/package.json
usr/share/joplin-cli/node_modules/class-utils/package.json
usr/share/joplin-cli/node_modules/class-utils/node_modules/define-property/package.json
usr/share/joplin-cli/node_modules/path-type/package.json
usr/share/joplin-cli/node_modules/path-type/node_modules/pify/package.json
usr/share/joplin-cli/node_modules/bcrypt-pbkdf/package.json
usr/share/joplin-cli/node_modules/decode-uri-component/package.json
usr/share/joplin-cli/node_modules/fast-levenshtein/package.json
usr/share/joplin-cli/node_modules/undertaker/package.json
usr/share/joplin-cli/node_modules/markdown-it/package.json
usr/share/joplin-cli/node_modules/markdown-it/node_modules/entities/package.json
usr/share/joplin-cli/node_modules/redux/package.json
usr/share/joplin-cli/node_modules/extend-shallow/package.json
usr/share/joplin-cli/node_modules/extend-shallow/node_modules/is-extendable/package.json
usr/share/joplin-cli/node_modules/ansi-regex/package.json
usr/share/joplin-cli/node_modules/glogg/package.json
usr/share/joplin-cli/node_modules/node-bitmap/package.json
usr/share/joplin-cli/node_modules/is-glob/package.json
usr/share/joplin-cli/node_modules/vinyl/package.json
usr/share/joplin-cli/node_modules/error-ex/package.json
usr/share/joplin-cli/node_modules/error-ex/node_modules/is-arrayish/package.json
usr/share/joplin-cli/node_modules/es6-iterator/package.json
usr/share/joplin-cli/node_modules/balanced-match/package.json
usr/share/joplin-cli/node_modules/whatwg-mimetype/package.json
usr/share/joplin-cli/node_modules/debug/package.json
usr/share/joplin-cli/node_modules/lead/package.json
usr/share/joplin-cli/node_modules/markdown-it-anchor/package.json
usr/share/joplin-cli/node_modules/typical/package.json
usr/share/joplin-cli/node_modules/saxes/package.json
usr/share/joplin-cli/node_modules/param-case/package.json
usr/share/joplin-cli/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/is-negated-glob/package.json
usr/share/joplin-cli/node_modules/pump/package.json
usr/share/joplin-cli/node_modules/ordered-read-streams/package.json
usr/share/joplin-cli/node_modules/array-unique/package.json
usr/share/joplin-cli/node_modules/setprototypeof/package.json
usr/share/joplin-cli/node_modules/safer-buffer/package.json
usr/share/joplin-cli/node_modules/interpret/package.json
usr/share/joplin-cli/node_modules/concat-stream/package.json
usr/share/joplin-cli/node_modules/xmlchars/package.json
usr/share/joplin-cli/node_modules/readable-stream/package.json
usr/share/joplin-cli/node_modules/terminal-kit/package.json
usr/share/joplin-cli/node_modules/string-kit/package.json
usr/share/joplin-cli/node_modules/stack-trace/package.json
usr/share/joplin-cli/node_modules/parse5/package.json
usr/share/joplin-cli/node_modules/upath/package.json
usr/share/joplin-cli/node_modules/strip-bom/package.json
usr/share/joplin-cli/node_modules/jsdom/package.json
usr/share/joplin-cli/node_modules/co/package.json
usr/share/joplin-cli/node_modules/whatwg-encoding/package.json
usr/share/joplin-cli/node_modules/whatwg-encoding/node_modules/iconv-lite/package.json
usr/share/joplin-cli/node_modules/prelude-ls/package.json
usr/share/joplin-cli/node_modules/map-cache/package.json
usr/share/joplin-cli/node_modules/fast-deep-equal/package.json
usr/share/joplin-cli/node_modules/encoding/package.json
usr/share/joplin-cli/node_modules/multiparty/package.json
usr/share/joplin-cli/node_modules/multiparty/node_modules/safe-buffer/package.json
usr/share/joplin-cli/node_modules/spdx-expression-parse/package.json
usr/share/joplin-cli/node_modules/define-properties/package.json
usr/share/joplin-cli/node_modules/decamelize/package.json
usr/share/joplin-cli/node_modules/snapdragon-util/package.json
usr/share/joplin-cli/node_modules/snapdragon-util/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/tweetnacl/package.json
usr/share/joplin-cli/node_modules/querystringify/package.json
usr/share/joplin-cli/node_modules/liftoff/package.json
usr/share/joplin-cli/node_modules/static-extend/package.json
usr/share/joplin-cli/node_modules/static-extend/node_modules/define-property/package.json
usr/share/joplin-cli/node_modules/jsbn/package.json
usr/share/joplin-cli/node_modules/asn1/package.json
usr/share/joplin-cli/node_modules/get-caller-file/package.json
usr/share/joplin-cli/node_modules/remove-bom-buffer/package.json
usr/share/joplin-cli/node_modules/minimatch/package.json
usr/share/joplin-cli/node_modules/performance-now/package.json
usr/share/joplin-cli/node_modules/ansi-escape-sequences/package.json
usr/share/joplin-cli/node_modules/markdown-it-multimd-table/package.json
usr/share/joplin-cli/node_modules/markdown-it-multimd-table/node_modules/markdown-it/package.json
usr/share/joplin-cli/node_modules/process-nextick-args/package.json
usr/share/joplin-cli/node_modules/css/package.json
usr/share/joplin-cli/node_modules/css/node_modules/source-map/package.json
usr/share/joplin-cli/node_modules/lodash-es/package.json
usr/share/joplin-cli/node_modules/cloneable-readable/package.json
usr/share/joplin-cli/node_modules/cloneable-readable/node_modules/readable-stream/package.json
usr/share/joplin-cli/node_modules/cloneable-readable/node_modules/process-nextick-args/package.json
usr/share/joplin-cli/node_modules/cloneable-readable/node_modules/string_decoder/package.json
usr/share/joplin-cli/node_modules/replace-homedir/package.json
usr/share/joplin-cli/node_modules/replace-homedir/node_modules/is-windows/package.json
usr/share/joplin-cli/node_modules/replace-homedir/node_modules/is-relative/package.json
usr/share/joplin-cli/node_modules/replace-homedir/node_modules/is-absolute/package.json
usr/share/joplin-cli/node_modules/replace-homedir/node_modules/is-unc-path/package.json
usr/share/joplin-cli/node_modules/md5/package.json
usr/share/joplin-cli/node_modules/anymatch/package.json
usr/share/joplin-cli/node_modules/image-type/package.json
usr/share/joplin-cli/node_modules/define-property/package.json
usr/share/joplin-cli/node_modules/define-property/node_modules/is-descriptor/package.json
usr/share/joplin-cli/node_modules/define-property/node_modules/is-data-descriptor/package.json
usr/share/joplin-cli/node_modules/define-property/node_modules/is-accessor-descriptor/package.json
usr/share/joplin-cli/node_modules/flush-write-stream/package.json
usr/share/joplin-cli/node_modules/flush-write-stream/node_modules/readable-stream/package.json
usr/share/joplin-cli/node_modules/flush-write-stream/node_modules/process-nextick-args/package.json
usr/share/joplin-cli/node_modules/flush-write-stream/node_modules/string_decoder/package.json
usr/share/joplin-cli/node_modules/string-width/package.json
usr/share/joplin-cli/node_modules/assert-plus/package.json
usr/share/joplin-cli/node_modules/spdx-license-ids/package.json
usr/share/joplin-cli/node_modules/tcp-port-used/package.json
usr/share/joplin-cli/node_modules/tcp-port-used/node_modules/debug/package.json
usr/share/joplin-cli/node_modules/tcp-port-used/node_modules/q/package.json
usr/share/joplin-cli/node_modules/json-stringify-safe/package.json
usr/share/joplin-cli/node_modules/inspect-property/package.json
usr/share/joplin-cli/node_modules/inspect-property/node_modules/split-skip/package.json
usr/share/joplin-cli/node_modules/inspect-property/node_modules/inspect-function/package.json
usr/share/joplin-cli/node_modules/inspect-property/node_modules/inspect-parameters-declaration/package.json
usr/share/joplin-cli/node_modules/inspect-property/node_modules/inspect-parameters-declaration/node_modules/magicli/package.json
usr/share/joplin-cli/node_modules/inspect-property/node_modules/inspect-parameters-declaration/node_modules/split-skip/package.json
usr/share/joplin-cli/node_modules/inspect-property/node_modules/inspect-parameters-declaration/node_modules/inspect-function/package.json
usr/share/joplin-cli/node_modules/inspect-property/node_modules/inspect-parameters-declaration/node_modules/inspect-function/node_modules/split-skip/package.json
usr/share/joplin-cli/node_modules/find-up/package.json
usr/share/joplin-cli/node_modules/time-stamp/package.json
usr/share/joplin-cli/node_modules/path-exists/package.json
usr/share/joplin-cli/node_modules/form-data/package.json
usr/share/joplin-cli/node_modules/acorn/package.json
usr/share/joplin-cli/node_modules/valid-url/package.json
usr/share/joplin-cli/node_modules/expand-template/package.json
usr/share/joplin-cli/node_modules/esutils/package.json
usr/share/joplin-cli/node_modules/http-errors/package.json
usr/share/joplin-cli/node_modules/http-errors/node_modules/inherits/package.json
usr/share/joplin-cli/node_modules/delayed-stream/package.json
usr/share/joplin-cli/node_modules/mixin-deep/package.json
usr/share/joplin-cli/node_modules/mixin-deep/node_modules/is-extendable/package.json
usr/share/joplin-cli/node_modules/ws/package.json
usr/share/joplin-cli/node_modules/object.reduce/package.json
usr/share/joplin-cli/node_modules/ansi-wrap/package.json
usr/share/joplin-cli/node_modules/is-extendable/package.json
usr/share/joplin-cli/node_modules/p-try/package.json
usr/share/joplin-cli/node_modules/isobject/package.json
usr/share/joplin-cli/node_modules/os-homedir/package.json
usr/share/joplin-cli/node_modules/spdx-exceptions/package.json
usr/share/joplin-cli/node_modules/uniq/package.json
usr/share/joplin-cli/node_modules/is-number/package.json
usr/share/joplin-cli/node_modules/is-number/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/copy-props/package.json
usr/share/joplin-cli/node_modules/to-absolute-glob/package.json
usr/share/joplin-cli/node_modules/to-absolute-glob/node_modules/is-windows/package.json
usr/share/joplin-cli/node_modules/to-absolute-glob/node_modules/is-relative/package.json
usr/share/joplin-cli/node_modules/to-absolute-glob/node_modules/is-absolute/package.json
usr/share/joplin-cli/node_modules/to-absolute-glob/node_modules/is-unc-path/package.json
usr/share/joplin-cli/node_modules/stringify-parameters/package.json
usr/share/joplin-cli/node_modules/stringify-parameters/node_modules/magicli/package.json
usr/share/joplin-cli/node_modules/estraverse/package.json
usr/share/joplin-cli/node_modules/sshpk/package.json
usr/share/joplin-cli/node_modules/object-keys/package.json
usr/share/joplin-cli/node_modules/mkdirp/package.json
usr/share/joplin-cli/node_modules/mkdirp/node_modules/minimist/package.json
usr/share/joplin-cli/node_modules/simple-get/package.json
usr/share/joplin-cli/node_modules/prebuild-install/package.json
usr/share/joplin-cli/node_modules/prebuild-install/node_modules/minimist/package.json
usr/share/joplin-cli/node_modules/diff-match-patch/package.json
usr/share/joplin-cli/node_modules/es6-symbol/package.json
usr/share/joplin-cli/node_modules/random-bytes/package.json
usr/share/joplin-cli/node_modules/image-data-uri/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/jsonfile/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/oauth-sign/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/aws4/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/har-validator/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/tough-cookie/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/combined-stream/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/mime-types/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/uuid/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/form-data/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/form-data/node_modules/combined-stream/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/extend/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/mime-db/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/safe-buffer/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/fs-extra/package.json
usr/share/joplin-cli/node_modules/image-data-uri/node_modules/request/package.json
usr/share/joplin-cli/node_modules/stealthy-require/package.json
usr/share/joplin-cli/node_modules/toidentifier/package.json
usr/share/joplin-cli/node_modules/html-encoding-sniffer/package.json
usr/share/joplin-cli/node_modules/jssha/package.json
usr/share/joplin-cli/node_modules/gauge/package.json
usr/share/joplin-cli/node_modules/gauge/node_modules/strip-ansi/package.json
usr/share/joplin-cli/node_modules/gauge/node_modules/ansi-regex/package.json
usr/share/joplin-cli/node_modules/gauge/node_modules/string-width/package.json
usr/share/joplin-cli/node_modules/gauge/node_modules/is-fullwidth-code-point/package.json
usr/share/joplin-cli/node_modules/http-signature/package.json
usr/share/joplin-cli/node_modules/mimic-response/package.json
usr/share/joplin-cli/node_modules/markdown-it-abbr/package.json
usr/share/joplin-cli/node_modules/path-dirname/package.json
usr/share/joplin-cli/node_modules/convert-source-map/package.json
usr/share/joplin-cli/node_modules/jmespath/package.json
usr/share/joplin-cli/node_modules/ini/package.json
usr/share/joplin-cli/node_modules/chroma-js/package.json
usr/share/joplin-cli/node_modules/inflight/package.json
usr/share/joplin-cli/node_modules/aws-sign2/package.json
usr/share/joplin-cli/node_modules/for-own/package.json
usr/share/joplin-cli/node_modules/string_decoder/package.json
usr/share/joplin-cli/node_modules/normalize-package-data/package.json
usr/share/joplin-cli/node_modules/domutils/package.json
usr/share/joplin-cli/node_modules/getpass/package.json
usr/share/joplin-cli/node_modules/make-iterator/package.json
usr/share/joplin-cli/node_modules/p-limit/package.json
usr/share/joplin-cli/node_modules/q/package.json
usr/share/joplin-cli/node_modules/object-visit/package.json
usr/share/joplin-cli/node_modules/domexception/package.json
usr/share/joplin-cli/node_modules/verror/package.json
usr/share/joplin-cli/node_modules/inspect-function/package.json
usr/share/joplin-cli/node_modules/inspect-function/node_modules/split-skip/package.json
usr/share/joplin-cli/node_modules/table-layout/package.json
usr/share/joplin-cli/node_modules/inspect-parameters-declaration/package.json
usr/share/joplin-cli/node_modules/inspect-parameters-declaration/node_modules/magicli/package.json
usr/share/joplin-cli/node_modules/ajv/package.json
usr/share/joplin-cli/node_modules/has-flag/package.json
usr/share/joplin-cli/node_modules/request-promise-native/package.json
usr/share/joplin-cli/node_modules/request-promise-native/node_modules/tough-cookie/package.json
usr/share/joplin-cli/node_modules/request-promise-native/node_modules/punycode/package.json
usr/share/joplin-cli/node_modules/resolve-url/package.json
usr/share/joplin-cli/node_modules/domelementtype/package.json
usr/share/joplin-cli/node_modules/md5-file/package.json
usr/share/joplin-cli/node_modules/acorn-globals/package.json
usr/share/joplin-cli/node_modules/acorn-globals/node_modules/acorn/package.json
usr/share/joplin-cli/node_modules/deep-is/package.json
usr/share/joplin-cli/node_modules/node-fetch/package.json
usr/share/joplin-cli/node_modules/joplin-turndown-plugin-gfm/package.json
usr/share/joplin-cli/node_modules/markdown-it-sub/package.json
usr/share/joplin-cli/node_modules/os-locale/package.json
usr/share/joplin-cli/node_modules/domhandler/package.json
usr/share/joplin-cli/node_modules/repeat-string/package.json
usr/share/joplin-cli/node_modules/arr-filter/package.json
usr/share/joplin-cli/node_modules/symbol-tree/package.json
usr/share/joplin-cli/node_modules/string-padding/package.json
usr/share/joplin-cli/node_modules/array-equal/package.json
usr/share/joplin-cli/node_modules/has-unicode/package.json
usr/share/joplin-cli/node_modules/inherits/package.json
usr/share/joplin-cli/node_modules/which-module/package.json
usr/share/joplin-cli/node_modules/command-line-usage/package.json
usr/share/joplin-cli/node_modules/optionator/package.json
usr/share/joplin-cli/node_modules/optionator/node_modules/deep-is/package.json
usr/share/joplin-cli/node_modules/color-name/package.json
usr/share/joplin-cli/node_modules/number-is-nan/package.json
usr/share/joplin-cli/node_modules/type/package.json
usr/share/joplin-cli/node_modules/patch-package/package.json
usr/share/joplin-cli/node_modules/patch-package/node_modules/chalk/package.json
usr/share/joplin-cli/node_modules/patch-package/node_modules/rimraf/package.json
usr/share/joplin-cli/node_modules/patch-package/node_modules/glob/package.json
usr/share/joplin-cli/node_modules/patch-package/node_modules/minimist/package.json
usr/share/joplin-cli/node_modules/patch-package/node_modules/semver/package.json
usr/share/joplin-cli/node_modules/patch-package/node_modules/fs-extra/package.json
usr/share/joplin-cli/node_modules/atob/package.json
usr/share/joplin-cli/node_modules/htmlparser2/package.json
usr/share/joplin-cli/node_modules/htmlparser2/node_modules/entities/package.json
usr/share/joplin-cli/node_modules/default-resolution/package.json
usr/share/joplin-cli/node_modules/requires-port/package.json
usr/share/joplin-cli/node_modules/extglob/package.json
usr/share/joplin-cli/node_modules/extglob/node_modules/is-descriptor/package.json
usr/share/joplin-cli/node_modules/extglob/node_modules/extend-shallow/package.json
usr/share/joplin-cli/node_modules/extglob/node_modules/define-property/package.json
usr/share/joplin-cli/node_modules/extglob/node_modules/is-data-descriptor/package.json
usr/share/joplin-cli/node_modules/extglob/node_modules/is-accessor-descriptor/package.json
usr/share/joplin-cli/node_modules/is-fullwidth-code-point/package.json
usr/share/joplin-cli/node_modules/jpeg-js/package.json
usr/share/joplin-cli/node_modules/parse-filepath/package.json
usr/share/joplin-cli/node_modules/parse-filepath/node_modules/is-windows/package.json
usr/share/joplin-cli/node_modules/parse-filepath/node_modules/is-relative/package.json
usr/share/joplin-cli/node_modules/parse-filepath/node_modules/is-absolute/package.json
usr/share/joplin-cli/node_modules/parse-filepath/node_modules/is-unc-path/package.json
usr/share/joplin-cli/node_modules/node-emoji/package.json
usr/share/joplin-cli/node_modules/keytar/package.json
usr/share/joplin-cli/node_modules/keytar/build/config.gypi
usr/share/joplin-cli/node_modules/keytar/build/Makefile
usr/share/joplin-cli/node_modules/keytar/node_modules/nan/package.json
usr/share/joplin-cli/node_modules/keytar/node_modules/minimist/package.json
usr/share/joplin-cli/node_modules/keytar/node_modules/prebuild-install/package.json
usr/share/joplin-cli/node_modules/sharp/package.json
usr/share/joplin-cli/node_modules/sharp/build/config.gypi
usr/share/joplin-cli/node_modules/sharp/build/Makefile
usr/share/joplin-cli/node_modules/sharp/node_modules/fs-minipass/package.json
usr/share/joplin-cli/node_modules/sharp/node_modules/nan/package.json
usr/share/joplin-cli/node_modules/sharp/node_modules/minipass/package.json
usr/share/joplin-cli/node_modules/sharp/node_modules/semver/package.json
usr/share/joplin-cli/node_modules/sharp/node_modules/tar/package.json
usr/share/joplin-cli/node_modules/sharp/node_modules/minizlib/package.json
usr/share/joplin-cli/node_modules/sharp/node_modules/yallist/package.json
usr/share/joplin-cli/node_modules/napi-build-utils/package.json
usr/share/joplin-cli/node_modules/split-string/package.json
usr/share/joplin-cli/node_modules/sax/package.json
usr/share/joplin-cli/node_modules/open/package.json
usr/share/joplin-cli/node_modules/url/package.json
usr/share/joplin-cli/node_modules/url/node_modules/punycode/package.json
usr/share/joplin-cli/node_modules/upper-case/package.json
usr/share/joplin-cli/node_modules/retry/package.json
usr/share/joplin-cli/node_modules/json-schema/package.json
usr/share/joplin-cli/node_modules/undertaker-registry/package.json
usr/share/joplin-cli/node_modules/is-data-descriptor/package.json
usr/share/joplin-cli/node_modules/is-data-descriptor/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/symbol-observable/package.json
usr/share/joplin-cli/node_modules/lodash/package.json
usr/share/joplin-cli/node_modules/is-wsl/package.json
usr/share/joplin-cli/node_modules/katex/package.json
usr/share/joplin-cli/node_modules/katex/node_modules/commander/package.json
usr/share/joplin-cli/node_modules/rechoir/package.json
usr/share/joplin-cli/node_modules/pumpify/package.json
usr/share/joplin-cli/node_modules/pumpify/node_modules/pump/package.json
usr/share/joplin-cli/node_modules/asynckit/package.json
usr/share/joplin-cli/node_modules/strict-uri-encode/package.json
usr/share/joplin-cli/node_modules/clone-stats/package.json
usr/share/joplin-cli/node_modules/es5-ext/package.json
usr/share/joplin-cli/node_modules/base64-stream/package.json
usr/share/joplin-cli/node_modules/cliss/package.json
usr/share/joplin-cli/node_modules/relateurl/package.json
usr/share/joplin-cli/node_modules/dom-serializer/package.json
usr/share/joplin-cli/node_modules/dom-serializer/node_modules/entities/package.json
usr/share/joplin-cli/node_modules/vinyl-sourcemap/package.json
usr/share/joplin-cli/node_modules/repeat-element/package.json
usr/share/joplin-cli/node_modules/xmlbuilder/package.json
usr/share/joplin-cli/node_modules/gulplog/package.json
usr/share/joplin-cli/node_modules/markdown-it-emoji/package.json
usr/share/joplin-cli/node_modules/entities/package.json
usr/share/joplin-cli/node_modules/array-initial/package.json
usr/share/joplin-cli/node_modules/array-initial/node_modules/is-number/package.json
usr/share/joplin-cli/node_modules/each-props/package.json
usr/share/joplin-cli/node_modules/source-map-url/package.json
usr/share/joplin-cli/node_modules/sqlite3/package.json
usr/share/joplin-cli/node_modules/sqlite3/build/Release/.deps/var/tmp/pamac-build-john/joplin/src/joplin-1.1.4/CliClient/node_modules/sqlite3/lib/binding/node-v83-linux-x64/node_sqlite3.node.d
usr/share/joplin-cli/node_modules/sqlite3/build/Release/.deps/Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c.d
usr/share/joplin-cli/node_modules/sqlite3/build/config.gypi
usr/share/joplin-cli/node_modules/sqlite3/build/Makefile
usr/share/joplin-cli/node_modules/sqlite3/build/action_after_build.target.mk
usr/share/joplin-cli/node_modules/omggif/package.json
usr/share/joplin-cli/node_modules/fill-range/package.json
usr/share/joplin-cli/node_modules/fill-range/node_modules/extend-shallow/package.json
usr/share/joplin-cli/node_modules/strip-json-comments/package.json
usr/share/joplin-cli/node_modules/for-in/package.json
usr/share/joplin-cli/node_modules/mime/package.json
usr/share/joplin-cli/node_modules/parse-passwd/package.json
usr/share/joplin-cli/node_modules/append-buffer/package.json
usr/share/joplin-cli/node_modules/remove-trailing-separator/package.json
usr/share/joplin-cli/node_modules/fault/package.json
usr/share/joplin-cli/node_modules/object.assign/package.json
usr/share/joplin-cli/node_modules/iconv-lite/package.json
usr/share/joplin-cli/node_modules/extend/package.json
usr/share/joplin-cli/node_modules/sver-compat/package.json
usr/share/joplin-cli/node_modules/pify/package.json
usr/share/joplin-cli/node_modules/noop-logger/package.json
usr/share/joplin-cli/node_modules/which-pm-runs/package.json
usr/share/joplin-cli/node_modules/are-we-there-yet/package.json
usr/share/joplin-cli/node_modules/semver/package.json
usr/share/joplin-cli/node_modules/is-buffer/package.json
usr/share/joplin-cli/node_modules/is-relative/package.json
usr/share/joplin-cli/node_modules/har-schema/package.json
usr/share/joplin-cli/node_modules/map-visit/package.json
usr/share/joplin-cli/node_modules/klaw-sync/package.json
usr/share/joplin-cli/node_modules/array-back/package.json
usr/share/joplin-cli/node_modules/flagged-respawn/package.json
usr/share/joplin-cli/node_modules/xml-name-validator/package.json
usr/share/joplin-cli/node_modules/through2-filter/package.json
usr/share/joplin-cli/node_modules/array-last/package.json
usr/share/joplin-cli/node_modules/array-last/node_modules/is-number/package.json
usr/share/joplin-cli/node_modules/uri-js/package.json
usr/share/joplin-cli/node_modules/uri-js/node_modules/punycode/package.json
usr/share/joplin-cli/node_modules/cssstyle/package.json
usr/share/joplin-cli/node_modules/cssstyle/node_modules/cssom/package.json
usr/share/joplin-cli/node_modules/path-key/package.json
usr/share/joplin-cli/node_modules/expand-tilde/package.json
usr/share/joplin-cli/node_modules/safe-regex/package.json
usr/share/joplin-cli/node_modules/arr-map/package.json
usr/share/joplin-cli/node_modules/is2/package.json
usr/share/joplin-cli/node_modules/array-each/package.json
usr/share/joplin-cli/node_modules/object-assign/package.json
usr/share/joplin-cli/node_modules/path-parse/package.json
usr/share/joplin-cli/node_modules/isstream/package.json
usr/share/joplin-cli/node_modules/punycode/package.json
usr/share/joplin-cli/node_modules/signal-exit/package.json
usr/share/joplin-cli/node_modules/proper-lockfile/package.json
usr/share/joplin-cli/node_modules/fs-mkdirp-stream/package.json
usr/share/joplin-cli/node_modules/is-valid-glob/package.json
usr/share/joplin-cli/node_modules/camel-case/package.json
usr/share/joplin-cli/node_modules/stream-exhaust/package.json
usr/share/joplin-cli/node_modules/use/package.json
usr/share/joplin-cli/node_modules/unc-path-regex/package.json
usr/share/joplin-cli/node_modules/remove-bom-stream/package.json
usr/share/joplin-cli/node_modules/npmlog/package.json
usr/share/joplin-cli/node_modules/chokidar/package.json
usr/share/joplin-cli/node_modules/chokidar/node_modules/normalize-path/package.json
usr/share/joplin-cli/node_modules/homedir-polyfill/package.json
usr/share/joplin-cli/node_modules/ignore-walk/package.json
usr/share/joplin-cli/node_modules/word-wrap/package.json
usr/share/joplin-cli/node_modules/tar/package.json
usr/share/joplin-cli/node_modules/tar/node_modules/minipass/package.json
usr/share/joplin-cli/node_modules/tar/node_modules/safe-buffer/package.json
usr/share/joplin-cli/node_modules/tar/node_modules/yallist/package.json
usr/share/joplin-cli/node_modules/tar/node_modules/chownr/package.json
usr/share/joplin-cli/node_modules/path-root-regex/package.json
usr/share/joplin-cli/node_modules/detect-file/package.json
usr/share/joplin-cli/node_modules/locate-path/package.json
usr/share/joplin-cli/node_modules/async-done/package.json
usr/share/joplin-cli/node_modules/async-done/node_modules/process-nextick-args/package.json
usr/share/joplin-cli/node_modules/file-type/package.json
usr/share/joplin-cli/node_modules/npm-bundled/package.json
usr/share/joplin-cli/node_modules/core-util-is/package.json
usr/share/joplin-cli/node_modules/archy/package.json
usr/share/joplin-cli/node_modules/pn/package.json
usr/share/joplin-cli/node_modules/app-module-path/package.json
usr/share/joplin-cli/node_modules/slash/package.json
usr/share/joplin-cli/node_modules/reduce-flatten/package.json
usr/share/joplin-cli/node_modules/deep-extend/package.json
usr/share/joplin-cli/node_modules/shebang-command/package.json
usr/share/joplin-cli/node_modules/node-pre-gyp/package.json
usr/share/joplin-cli/node_modules/lazyness/package.json
usr/share/joplin-cli/node_modules/get-prototype-chain/package.json
usr/share/joplin-cli/node_modules/clone/package.json
usr/share/joplin-cli/node_modules/file-uri-to-path/package.json
usr/share/joplin-cli/node_modules/fs.realpath/package.json
usr/share/joplin-cli/node_modules/to-regex-range/package.json
usr/share/joplin-cli/node_modules/syswide-cas/package.json
usr/share/joplin-cli/node_modules/arr-diff/package.json
usr/share/joplin-cli/node_modules/cwise-compiler/package.json
usr/share/joplin-cli/node_modules/brace-expansion/package.json
usr/share/joplin-cli/node_modules/v8flags/package.json
usr/share/joplin-cli/node_modules/collection-visit/package.json
usr/share/joplin-cli/node_modules/mime-db/package.json
usr/share/joplin-cli/node_modules/nwsapi/package.json
usr/share/joplin-cli/node_modules/npm-normalize-package-bin/package.json
usr/share/joplin-cli/node_modules/safe-buffer/package.json
usr/share/joplin-cli/node_modules/data-urls/package.json
usr/share/joplin-cli/node_modules/minizlib/package.json
usr/share/joplin-cli/node_modules/lowlight/package.json
usr/share/joplin-cli/node_modules/lowlight/node_modules/highlight.js/package.json
usr/share/joplin-cli/node_modules/jasmine/package.json
usr/share/joplin-cli/node_modules/jasmine/node_modules/glob/package.json
usr/share/joplin-cli/node_modules/yallist/package.json
usr/share/joplin-cli/node_modules/ecc-jsbn/package.json
usr/share/joplin-cli/node_modules/replace-ext/package.json
usr/share/joplin-cli/node_modules/lodash.sortby/package.json
usr/share/joplin-cli/node_modules/mkdirp-classic/package.json
usr/share/joplin-cli/node_modules/collection-map/package.json
usr/share/joplin-cli/node_modules/read-pkg-up/package.json
usr/share/joplin-cli/node_modules/read-pkg-up/node_modules/find-up/package.json
usr/share/joplin-cli/node_modules/read-pkg-up/node_modules/path-exists/package.json
usr/share/joplin-cli/node_modules/events/package.json
usr/share/joplin-cli/node_modules/object.map/package.json
usr/share/joplin-cli/node_modules/markdown-it-deflist/package.json
usr/share/joplin-cli/node_modules/crypt/package.json
usr/share/joplin-cli/node_modules/fs-constants/package.json
usr/share/joplin-cli/node_modules/urix/package.json
usr/share/joplin-cli/node_modules/simple-swizzle/package.json
usr/share/joplin-cli/node_modules/joplin-turndown/package.json
usr/share/joplin-cli/node_modules/buffer/package.json
usr/share/joplin-cli/node_modules/uc.micro/package.json
usr/share/joplin-cli/node_modules/has-ansi/package.json
usr/share/joplin-cli/node_modules/has-ansi/node_modules/ansi-regex/package.json
usr/share/joplin-cli/node_modules/expand-brackets/package.json
usr/share/joplin-cli/node_modules/expand-brackets/node_modules/extend-shallow/package.json
usr/share/joplin-cli/node_modules/expand-brackets/node_modules/define-property/package.json
usr/share/joplin-cli/node_modules/path-is-absolute/package.json
usr/share/joplin-cli/node_modules/concat-map/package.json
usr/share/joplin-cli/node_modules/color-string/package.json
usr/share/joplin-cli/node_modules/chownr/package.json
usr/share/joplin-cli/node_modules/glob-parent/package.json
usr/share/joplin-cli/node_modules/glob-parent/node_modules/is-glob/package.json
usr/share/joplin-cli/node_modules/memory-cache/package.json
usr/share/joplin-cli/node_modules/ndarray-pack/package.json
usr/share/joplin-cli/node_modules/markdown-it-ins/package.json
usr/share/joplin-cli/node_modules/once/package.json
usr/share/joplin-cli/node_modules/is-extglob/package.json
usr/share/joplin-cli/node_modules/is-absolute/package.json
usr/share/joplin-cli/node_modules/bach/package.json
usr/share/joplin-cli/node_modules/next-tick/package.json
usr/share/joplin-cli/node_modules/is-ci/package.json
usr/share/joplin-cli/node_modules/cssom/package.json
usr/share/joplin-cli/node_modules/read-pkg/package.json
usr/share/joplin-cli/node_modules/pretty-hrtime/package.json
usr/share/joplin-cli/node_modules/lodash.padend/package.json
usr/share/joplin-cli/node_modules/base/package.json
usr/share/joplin-cli/node_modules/base/node_modules/is-descriptor/package.json
usr/share/joplin-cli/node_modules/base/node_modules/define-property/package.json
usr/share/joplin-cli/node_modules/base/node_modules/is-data-descriptor/package.json
usr/share/joplin-cli/node_modules/base/node_modules/is-accessor-descriptor/package.json
usr/share/joplin-cli/node_modules/es6-promise-pool/package.json
usr/share/joplin-cli/node_modules/util-deprecate/package.json
usr/share/joplin-cli/node_modules/simple-concat/package.json
usr/share/joplin-cli/node_modules/escodegen/package.json
usr/share/joplin-cli/node_modules/escodegen/node_modules/source-map/package.json
usr/share/joplin-cli/node_modules/supports-color/package.json
usr/share/joplin-cli/node_modules/html-entities/package.json
usr/share/joplin-cli/node_modules/value-or-function/package.json
usr/share/joplin-cli/node_modules/highlight.js/package.json
usr/share/joplin-cli/node_modules/ip-regex/package.json
usr/share/joplin-cli/node_modules/asap/package.json
usr/share/joplin-cli/node_modules/query-string/package.json
usr/share/joplin-cli/node_modules/charenc/package.json
usr/share/joplin-cli/node_modules/is-unc-path/package.json
usr/share/joplin-cli/node_modules/w3c-xmlserializer/package.json
usr/share/joplin-cli/node_modules/copy-descriptor/package.json
usr/share/joplin-cli/node_modules/isarray/package.json
usr/share/joplin-cli/node_modules/binary-extensions/package.json
usr/share/joplin-cli/node_modules/array-sort/package.json
usr/share/joplin-cli/node_modules/array-sort/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/is-plain-object/package.json
usr/share/joplin-cli/node_modules/sprintf-js/package.json
usr/share/joplin-cli/node_modules/github-from-package/package.json
usr/share/joplin-cli/node_modules/delegates/package.json
usr/share/joplin-cli/node_modules/url-parse/package.json
usr/share/joplin-cli/node_modules/no-case/package.json
usr/share/joplin-cli/node_modules/escape-string-regexp/package.json
usr/share/joplin-cli/node_modules/object-copy/package.json
usr/share/joplin-cli/node_modules/object-copy/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/object-copy/node_modules/define-property/package.json
usr/share/joplin-cli/node_modules/regex-not/package.json
usr/share/joplin-cli/node_modules/yargs-parser/package.json
usr/share/joplin-cli/node_modules/fs-extra/package.json
usr/share/joplin-cli/node_modules/cache-base/package.json
usr/share/joplin-cli/node_modules/for-each-property/package.json
usr/share/joplin-cli/node_modules/has-symbols/package.json
usr/share/joplin-cli/node_modules/sparkles/package.json
usr/share/joplin-cli/node_modules/posix-character-classes/package.json
usr/share/joplin-cli/node_modules/argparse/package.json
usr/share/joplin-cli/node_modules/argparse/node_modules/sprintf-js/package.json
usr/share/joplin-cli/node_modules/extsprintf/package.json
usr/share/joplin-cli/node_modules/markdown-it-toc-done-right/package.json
usr/share/joplin-cli/node_modules/he/package.json
usr/share/joplin-cli/node_modules/ms/package.json
usr/share/joplin-cli/node_modules/arr-flatten/package.json
usr/share/joplin-cli/node_modules/ext/package.json
usr/share/joplin-cli/node_modules/ext/node_modules/type/package.json
usr/share/joplin-cli/node_modules/function-bind/package.json
usr/share/joplin-cli/node_modules/request-promise-core/package.json
usr/share/joplin-cli/node_modules/request-promise-core/node_modules/lodash/package.json
usr/share/joplin-cli/node_modules/seventh/package.json
usr/share/joplin-cli/node_modules/markdown-it-mark/package.json
usr/share/joplin-cli/node_modules/is-arrayish/package.json
usr/share/joplin-cli/node_modules/ieee754/package.json
usr/share/joplin-cli/node_modules/parse-json/package.json
usr/share/joplin-cli/node_modules/gulp/package.json
usr/share/joplin-cli/node_modules/gulp/node_modules/gulp-cli/package.json
usr/share/joplin-cli/node_modules/is-accessor-descriptor/package.json
usr/share/joplin-cli/node_modules/is-accessor-descriptor/node_modules/kind-of/package.json
usr/share/joplin-cli/node_modules/depd/package.json
usr/share/joplin-cli/node_modules/vinyl-fs/package.json
usr/share/joplin-cli/node_modules/source-map-resolve/package.json
usr/share/joplin-cli/node_modules/lodash.toarray/package.json
usr/share/joplin-cli/node_modules/base-64/package.json
usr/share/joplin-cli/node_modules/psl/package.json
usr/share/joplin-cli/node_modules/global-modules/package.json
usr/share/joplin-cli/node_modules/global-modules/node_modules/is-windows/package.json
usr/share/joplin-cli/node_modules/detect-libc/package.json
usr/share/joplin-cli/node_modules/uglify-js/package.json
usr/share/joplin-cli/node_modules/uglify-js/node_modules/source-map/package.json
usr/share/joplin-cli/node_modules/spdx-correct/package.json
usr/share/joplin-cli/node_modules/tmp/package.json
usr/share/joplin-cli/node_modules/deepmerge/package.json
usr/share/joplin-cli/node_modules/require-directory/package.json
usr/share/joplin-cli/node_modules/request/package.json
usr/share/joplin-cli/node_modules/request/node_modules/tough-cookie/package.json
usr/share/joplin-cli/node_modules/request/node_modules/combined-stream/package.json
usr/share/joplin-cli/node_modules/request/node_modules/mime-types/package.json
usr/share/joplin-cli/node_modules/request/node_modules/uuid/package.json
usr/share/joplin-cli/node_modules/request/node_modules/form-data/package.json
usr/share/joplin-cli/node_modules/request/node_modules/mime-db/package.json
usr/share/joplin-cli/node_modules/request/node_modules/safe-buffer/package.json
usr/share/joplin-cli/node_modules/isexe/package.json
usr/share/joplin-cli/node_modules/ci-info/package.json
usr/share/joplin-cli/node_modules/server-destroy/package.json
usr/share/joplin-cli/node_modules/tkwidgets/package.json
usr/share/joplin-cli/node_modules/tkwidgets/node_modules/node-emoji/package.json
usr/share/joplin-cli/node_modules/markdown-it-footnote/package.json
usr/share/joplin-cli/node_modules/fd-slicer/package.json
usr/share/joplin-cli/node_modules/type-check/package.json
usr/share/joplin-cli/node_modules/rc/package.json
usr/share/joplin-cli/node_modules/rc/node_modules/minimist/package.json
==> Creating package "joplin"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: joplin 1.1.4-1 (piฤ
, 25 wrz 2020, 22:03:44)
==> Cleaning up...
Checking keyring... [6/6]
Checking integrity... [6/6]
Loading packages files... [6/6]
Checking file conflicts... [6/6]
Checking available disk space... [6/6]
Upgrading jre (14.0.2-1 -> 15-1)... [1/6]
Upgrading jdk (14.0.2-1 -> 15-1)... [2/6]
Upgrading gitkraken (7.3.0-1 -> 7.3.2-1)... [3/6]
Configuring jlink-software-and-documentation...
-> By installing this software you agree to the term of the Segger license.
-> See /usr/share/licenses/jlink-software-and-documentation/License.txt
-> SEGGER J-Link software may only be used with original SEGGER products and authorized OEM products.
-> The use of the licensed software to operate SEGGER product clones is prohibited and illegal.
Upgrading jlink-software-and-documentation (29:6.84-1 -> 30:6.86-1)... [4/6]
Upgrading clion (1:2020.2.1-1 -> 1:2020.2.3-1)... [5/6]
Upgrading joplin (1.0.233-1 -> 1.1.4-1)... [6/6]
Reloading device manager configuration... [1/4]
Arming ConditionNeedsUpdate... [2/4]
Updating icon theme caches... [3/4]
Updating the desktop file MIME type cache... [4/4]
Building minecraft...
==> Making package: minecraft 2.1.16102-2 (piฤ
, 25 wrz 2020, 22:04:09)
==> Retrieving sources...
-> Found minecraft-2.1.16102.deb
minecraft-2.1.16102.deb ... FAILED
==> ERROR: One or more files did not pass the validity check!
Error: Failed to build minecraft
[john@john-pc ~]$
So except for minecraft only warnings. Since minecraft did not pass the validity check either the package files are inconsistent or the download. I would reboot and check if everything else is OK.
When everything is OK then add at least one kernel, e.g. 5.4 as 5.7 is EOL, means itโs at its end of life and wonโt be supported for long. Itโs advisable to switch the kernel before supprt fully ends. You can see this in #announcements, where the currently supprted kernels are given and which kernels are EOL. Itโs good practice to check #announcements before updating to avoid the used kernel runs out of support. If this would be the case you should
- change to another, still supported kernel
- remove the unsupported kernel
- and THEN update
After rebooting all I get is a black screen. I already tried rebooting again, and still black screen
Boot using an USB stick with a Manjaro ISO and enter
sudo manjaro-chroot -a
{select 1 if only one line is offered}
and then
mhwd -i linux57-nvidia-450xx
exit
and reboot.
I have Windows 10 on a separate drive also connected, thatโs how I dual boot, wont that damage somehow the Windows?
No, not at all. You only need to go into your firmware and select the stick to be booted from it. Most firmwares allow this without permanent change of boot order.
As Iโm leaving now for the day, if you need further advice you could also study the wiki for reinstalling the graphics driver:
https://wiki.manjaro.org/index.php?title=Configure_Graphics_Cards
Itโs getting late here, I think I will just do it tomorrow then. Thanks for your help, I will try it tomorrow
