Displayport audio interface not detected
Hi All,
So I did a fresh install of Manjaro KDE on my “new” (five years old but new to me) computer last night.
It went fairly smoothly as expected except for a couple of odd issues.
I use the Displayport as both a video out and audio output.
However, the Displayport is not listed as an option for audio out.
The only options I have are internal speaker, the headphone jack and the headset jack.
I did a search of the forum and saw a suggestion on one thread to install manjaro-pipewire; I tried that but it didn’t help. I just installed it, I did not run any other command.
I then tried the suggestion from this post as it was the closest matching my problem, but it didn’t work either:
I actually no longer have sound coming out of the internal speaker!
I changed the file back to the original and updated grub but no luck in getting my internal speaker working again or having my Displayport show up as an option.
I tried Google but didn’t find the answer there either.
Any help that you can provide will be greatly appreciated.
Hello @NeoVeo :wink:
I had the same issue. Only solution was manually adjust the pins, since they were not registered automatically because the chip/firmware was slightly modified by HP in that case:
Probably check:
journalctl --dmesg --grep "snd" --no-pager --no-hostname
Thank you @megavolt, I appreciate your help!
Well my internal speaker started working again - yea!
Here’s the output from the command line you provided:
 ~  journalctl --dmesg --grep "snd" --no-pager --no-hostname
Sep 16 19:14:58 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=004618d4-fc71-4726-b68f-448f765a3c17 rw quiet splash snd_hda_intel.dmic_detect=0
Sep 16 19:14:58 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=004618d4-fc71-4726-b68f-448f765a3c17 rw quiet splash snd_hda_intel.dmic_detect=0
Sep 16 19:14:58 kernel: snd_hda_intel 0000:00:1f.3: dmic_detect option is deprecated, pass snd-intel-dspcfg.dsp_driver=1 option instead
Sep 16 19:14:58 kernel: snd_hda_intel 0000:00:1f.3: enabling device (0100 -> 0102)
Sep 16 19:14:59 kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Sep 16 19:14:59 kernel: snd_hda_codec_conexant hdaudioC0D0: CX20632: BIOS auto-probing.
Sep 16 19:14:59 kernel: snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX20632: line_outs=2 (0x19/0x1c/0x0/0x0/0x0) type:hp
Sep 16 19:14:59 kernel: snd_hda_codec_conexant hdaudioC0D0:    speaker_outs=1 (0x1f/0x0/0x0/0x0/0x0)
Sep 16 19:14:59 kernel: snd_hda_codec_conexant hdaudioC0D0:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
Sep 16 19:14:59 kernel: snd_hda_codec_conexant hdaudioC0D0:    mono: mono_out=0x0
Sep 16 19:14:59 kernel: snd_hda_codec_conexant hdaudioC0D0:    inputs:
Sep 16 19:14:59 kernel: snd_hda_codec_conexant hdaudioC0D0:      Mic=0x1a
Sep 16 19:15:00 kernel: usbcore: registered new interface driver snd-usb-audio
I noted that there is a line above that states Sep 16 19:14:58 kernel: snd_hda_intel 0000:00:1f.3: dmic_detect option is deprecated, pass snd-intel-dspcfg.dsp_driver=1 option instead
I’m not sure if that helps troubleshoot the problem.
My “new” computer where I’m experiencing this and other issues is an HP 800 G4 mini.
My “old” computer where everything Manjaro works just great, is an HP 600 G1 mini.
I’ll try the solution from the thread you included and see if that does the trick.
Wish me luck!
Edit:
And my internal speaker stopped working again.
Perhaps installing Manjaro-pipewire has caused a conflict.
Maybe I should uninstall it, although I’ve read in other people’s posts that that may not be possible…
inxi MAazy
~ inxi -MAazy
Type: Desktop System: HP product: HP EliteDesk 800 G4 DM 35W (TAA) v: N/A
serial: Chassis: type: 6 serial:
Mobo: HP model: 83E2 v: KBC Version 07.D2.00 serial:
UEFI: HP v: Q21 Ver. 02.24.00 date: 06/15/2023
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: Blue Microphones Yeti Nano
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5.3:6 chip-ID: b58e:0005 class-ID: 0300
serial:
Device-3: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.4:7
chip-ID: 046d:0843 class-ID: 0102 serial:
API: ALSA v: k6.1.51-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
And this:
cat /proc/asound/card*/codec* | grep Codec
Codec: Conexant CX20632
Codec: Intel Kabylake HDMI
Thank you very, very much @megavolt!
Your solution worked like MAGIC!!!
