Only 1 display will show output. Fresh install of KDE plasma manjaro. kernal 5.15 downgraded from 6.1.19. Shows output while booting then once it gets to the login page nothing. doesnt even show on the display settings page. Ideas? AMD gpu. Only outputting on the VGA no HDMI.
can you add on boot kernel “iommu=pt” with USB live manjaro
open a terminal and a browser on this topic
and returns
inxi -Fza
sudo mhwd-kernel -li
sudo mhw -li
inxi: System: Kernel: 5.15.106-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1 parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=8aefc6ac-fdb2-4669-9917-63e71292823b rw quiet splash udev.log_priority=3 Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux Machine: Type: Desktop Mobo: Micro-Star model: X470 GAMING PRO (MS-7B79) v: 1.0 serial: <superuser required> UEFI: American Megatrends v: 1.30 date: 04/23/2018 CPU: Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB Speed (MHz): avg: 1475 high: 1948 min/max: 1550/3400 boost: enabled scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1948 2: 1582 3: 1402 4: 1390 5: 1548 6: 1279 7: 1372 8: 1375 9: 1509 10: 1549 11: 1381 12: 1369 bogomips: 81614 Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm Vulnerabilities: Type: itlb_multihit status: Not affected Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: mmio_stale_data status: Not affected Type: retbleed mitigation: untrained return thunk; SMT vulnerable Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DVI-D-1 empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 1d:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 35.0 C Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1 Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99") s-diag: 414mm (16.31") Monitor-1: DVI-D-1 mapped: DVI-D-0 model: AOC 936W serial: <filter> built: 2010 res: 1366x768 hz: 60 dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes: max: 1366x768 min: 720x400 API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon RX 590 Series (polaris10 LLVM 15.0.7 DRM 3.42 5.15.106-1-MANJARO) direct-render: Yes Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 1d:00.1 chip-ID: 1002:aaf0 class-ID: 0403 Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 1f:00.3 chip-ID: 1022:1457 class-ID: 0403 API: ALSA v: k5.15.106-1-MANJARO status: kernel-api with: aoss type: oss-emulator tools: alsamixer,amixer Server-1: JACK v: 1.9.22 status: off tools: N/A Server-2: PipeWire v: 0.3.68 status: off with: wireplumber status: active tools: pw-cli,wpctl Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 18:00.0 chip-ID: 10ec:8168 class-ID: 0200 IF: enp24s0 state: down mac: <filter> Device-2: Broadcom BCM4352 802.11ac Wireless Network Adapter vendor: ASUSTeK driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 1a:00.0 chip-ID: 14e4:43b1 class-ID: 0280 IF: wlp26s0 state: up mac: <filter> Drives: Local Storage: total: 6.64 TiB used: 19.72 GiB (0.3%) SMART Message: Unable to run smartctl. Root privileges required. ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS2030 240GB SSD size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: CS203021 temp: 38.9 C scheme: GPT ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q scheme: GPT ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: MBR ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: MBR ID-5: /dev/sdd maj-min: 8:48 vendor: Toshiba model: DT01ACA200 size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: ABS0 scheme: GPT ID-6: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk model: Cruzer Blade size: 58.42 GiB block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure? Partition: ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 19.72 GiB (2.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 Swap: Alert: No swap data was found. Sensors: System Temperatures: cpu: 32.8 C mobo: N/A gpu: amdgpu temp: 35.0 C Fan Speeds (RPM): N/A gpu: amdgpu fan: 1963 Info: Processes: 294 Uptime: 9h 33m wakeups: 0 Memory: 15.57 GiB used: 1.8 GiB (11.6%) Init: systemd v: 252 default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1218 libs: 341 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
~ sudo mhwd-kernel -li ✔
[sudo] password for james:
Currently running: 5.15.106-1-MANJARO (linux515)
* linux414
* linux515
~ sudo mhwd -li 1 ✘
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
Please enclose your code in 3 tics like so:
Lines
and
Lines
(it is difficult to read as is)
