I recently bought a new laptop and wanted to install Manjaro XFCE (i am using it on the old one for quite a while).
But even the live usb has a strange problem, always on mouse move or sometimes on keyboard presses the screen flickers.
I have made a short video to show the issue but please be aware that this could cause an epileptic fit, so only watch if you can handle flickering.
Video: streamable.c om/a50wyo (seems I am not allowed to set links)
I managed to install the system but having the same issue there. I tried the solution of the thread 97556 but it only made the system unbootable.
Inxi (of the live system):
[manjaro@manjaro ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2131 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: SchenkerGmbH product: SCHENKER VISION 14 v: Standard
serial: <superuser required>
Mobo: NB02 model: PHxTQx1 v: Standard serial: <superuser required>
UEFI: American Megatrends LLC. v: N.1.01A05 date: 03/17/2022
ID-1: BAT0 charge: 39.1 Wh (74.9%) condition: 52.2/52.2 Wh (100.0%)
volts: 11.6 min: 11.6 model: standard type: Li-ion serial: <filter>
status: discharging
RAM: total: 31.1 GiB used: 1.68 GiB (5.4%)
RAM Report:
Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 763 high: 1202 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 506 2: 623 3: 1202 4: 590
5: 1008 6: 565 7: 964 8: 648 bogomips: 52856
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
vendor: Tongfang Hongkong driver: i915 v: kernel arch: Gen12.1
process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
vendor: Tongfang Hongkong driver: nouveau v: kernel non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 4 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2d:00.0 chip-ID: 10de:25a0 class-ID: 0302
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 3-6:3
chip-ID: 04f2:b71a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.00x18.74")
s-diag: 898mm (35.37")
Monitor-1: eDP-1 model-id: CSO 0x1402 built: 2020 res: 2880x1800 hz: 90
dpi: 242 gamma: 1.2 size: 302x188mm (11.89x7.4") diag: 356mm (14")
ratio: 16:10 modes: 2880x1800
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Tongfang Hongkong
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: no
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 939.01 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Generic model: Flash Disk
size: 7.5 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.07 scheme: MBR
Message: No partition data found.
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: NO_LABEL
uuid: EA8E-1277
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 512 MiB fs: ext4 label: N/A
uuid: ef4b4257-5cd8-4e54-bebd-f64c27a916e7
ID-3: /dev/sda1 maj-min: 8:1 size: 3.18 GiB fs: iso9660
ID-4: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 4195-5093
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s
Device-1: 3-1.2:4 info: Alcor Micro Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 058f:6387 class-ID: 0806 serial: <filter>
Device-2: 3-6:3 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b71a
Device-3: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 4-1:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
Device-1: 4-1.1:3 info: Realtek Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0316 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 221 Uptime: 55m wakeups: 342 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 1160 lib: 326 flatpak: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.19
Xrandr:
[manjaro@manjaro ~]$ xrandr
Screen 0: minimum 320 x 200, current 2880 x 1800, maximum 16384 x 16384
eDP-1 connected primary 2880x1800+0+0 (normal left inverted right x axis y axis) 302mm x 188mm
2880x1800 90.00*+
2880x1620 59.96 59.97
2560x1600 59.99 59.97
2560x1440 59.99 59.99 59.96 59.95
2048x1536 85.00 75.00 60.00
1920x1440 85.00 75.00 60.00
1856x1392 75.00 60.01
1792x1344 75.00 60.01
2048x1152 59.99 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 60.01 59.97 59.96 59.93
1600x1200 85.00 75.00 70.00 65.00 60.00
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 74.76 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
640x400 59.88 59.98 85.08
576x432 75.00
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
I hope anybody can point me to a solution as I would like to switch to the new hardware.
post output from:
mhwd -l && mhwd -li
Thanks for looking into the issue, and as requested:
[manjaro@manjaro ~]$ mhwd -l && mhwd -li
Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
> 0000:2d:00.0 (0302:10de:25a0) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.12.18 false PCI
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
> 0000:00:02.0 (0300:8086:9a49) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
you have installed only open source drivers that includes the noveau one… so go to system settings/ manjaro hardware configuration and click auto install proprietary driver, when its done and no errors are reported, reboot
That does not fix it, I booted to the live usb with proprietary drivers and have the same error and when I execute
Also I then tried to install the best matching proprietary driver via command line with:
[manjaro@manjaro ~]$ sudo mhwd -a pci nonfree 0300
> Skipping already installed config 'video-hybrid-intel-nvidia-prime' for device: 0000:00:02.0 (0300:8086:9a49) Display controller Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics]
It results in the same message when doing this via Manjaro Settings Manager → Hardware Configuration → Button Autoinstall Proprietary Drivers
i thought its because of the noveau driver…
output from:
journalctl -b0 -p4 --no-pager
find /etc/X11/ -name "*.conf"
It was a totally valid guess
journalctl:
[manjaro@manjaro ~]$ journalctl -b0 -p4 --no-pager
Jul 15 20:36:20 manjaro kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
Jul 15 20:36:20 manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jul 15 20:36:20 manjaro kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Jul 15 20:36:20 manjaro kernel: pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jul 15 20:36:20 manjaro kernel: hpet_acpi_add: no address or irqs in _CRS
Jul 15 20:36:20 manjaro kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Jul 15 20:36:20 manjaro kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 15 20:36:20 manjaro kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 15 20:36:20 manjaro kernel: usb: port power management may be unreliable
Jul 15 20:36:20 manjaro kernel: overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
Jul 15 20:36:20 manjaro systemd-udevd[399]: Configuration file /usr/lib/udev/rules.d/77-mm-fibocom-port-types.rules is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 15 20:36:21 manjaro kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Jul 15 20:36:22 manjaro kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Jul 15 20:36:22 manjaro kernel: asus_wmi: ASUS Management GUID not found
Jul 15 20:36:22 manjaro kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
Jul 15 20:36:22 manjaro kernel: caller tgl_uncore_imc_freerunning_init_box+0xba/0x110 [intel_uncore] mapping multiple BARs
Jul 15 20:36:22 manjaro systemd-udevd[435]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Jul 15 20:36:22 manjaro systemd-udevd[419]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
Jul 15 20:36:23 manjaro tlp[636]: Error: tlp.service is not enabled, power saving will not apply on boot.
Jul 15 20:36:23 manjaro tlp[636]: >>> Invoke 'systemctl enable tlp.service' to correct this!
Jul 15 20:36:24 manjaro systemd-udevd[406]: controlC0: Process '/usr/bin/alsactl restore 0' failed with exit code 99.
Jul 15 20:36:25 manjaro kernel: kauditd_printk_skb: 35 callbacks suppressed
Jul 15 20:36:50 manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [^^^^NPCF.UOCT], AE_NOT_FOUND (20210730/psargs-330)
Jul 15 20:36:50 manjaro kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0._Q83 due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jul 15 20:36:55 manjaro kernel: kauditd_printk_skb: 11 callbacks suppressed
Jul 15 20:37:19 manjaro systemd-udevd[399]: Configuration file /usr/lib/udev/rules.d/77-mm-fibocom-port-types.rules is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 15 20:37:20 manjaro kernel: nvidia: loading out-of-tree module taints kernel.
Jul 15 20:37:20 manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Jul 15 20:37:20 manjaro kernel: Disabling lock debugging due to kernel taint
Jul 15 20:37:20 manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.48.07 Fri May 27 03:26:43 UTC 2022
Jul 15 20:37:20 manjaro systemd-udevd[4604]: nvidia: Process '/usr/bin/bash -c '/usr/bin/mknod -Z -m 666 /dev/nvidiactl c $(grep nvidia-frontend /proc/devices | cut -d \ -f 1) 255'' failed with exit code 1.
Jul 15 20:37:20 manjaro kernel: kauditd_printk_skb: 9 callbacks suppressed
Jul 15 20:37:20 manjaro systemd-udevd[4604]: nvidia: Process '/usr/bin/bash -c 'for i in $(cat /proc/driver/nvidia/gpus/*/information | grep Minor | cut -d \ -f 4); do /usr/bin/mknod -Z -m 666 /dev/nvidia${i} c $(grep nvidia-frontend /proc/devices | cut -d \ -f 1) ${i}; done'' failed with exit code 1.
Jul 15 20:37:23 manjaro kernel: ACPI Warning: \_SB.PC00.RP09.PXSX._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Jul 15 20:37:23 manjaro kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Jul 15 20:37:24 manjaro systemd-udevd[399]: Configuration file /usr/lib/udev/rules.d/77-mm-fibocom-port-types.rules is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 15 20:37:25 manjaro lightdm[4679]: gkr-pam: no password is available for user
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: Configuration file /home/manjaro/.config/autostart/pulseaudio-ctl.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: Configuration file /home/manjaro/.config/autostart/live-session.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: Configuration file /home/manjaro/.config/autostart/disable-dpms.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: Configuration file /home/manjaro/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: /home/manjaro/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: /home/manjaro/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: /home/manjaro/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: /home/manjaro/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: /home/manjaro/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: /home/manjaro/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: Configuration file /home/manjaro/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 15 20:37:25 manjaro systemd-xdg-autostart-generator[4690]: /home/manjaro/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Jul 15 20:37:25 manjaro lightdm[4679]: gkr-pam: couldn't unlock the login keyring.
Jul 15 20:37:27 manjaro kernel: kauditd_printk_skb: 16 callbacks suppressed
Jul 15 20:37:27 manjaro xfconfd[4746]: Error parsing xfconf config file "/home/manjaro/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-desktop.xml": Error on line 22 char 11: Element “channel” was closed, but the currently open element is “property”
Jul 15 20:37:28 manjaro tumblerd[4830]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.6.so.0: cannot open shared object file: No such file or directory
Jul 15 20:37:29 manjaro gst-plugin-scan[4916]: type name '-a-png-encoder-pred' contains invalid characters
Jul 15 20:37:29 manjaro gst-plugin-scan[4916]: g_type_set_qdata: assertion 'node != NULL' failed
Jul 15 20:37:31 manjaro pulseaudio[4782]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jul 15 20:37:42 manjaro kernel: kauditd_printk_skb: 8 callbacks suppressed
Jul 15 20:39:55 manjaro kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xf8 on isa0060/serio0).
Jul 15 20:39:55 manjaro kernel: atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
Jul 15 20:39:57 manjaro kernel: atkbd serio0: Unknown key released (translated set 2, code 0xf8 on isa0060/serio0).
Jul 15 20:39:57 manjaro kernel: atkbd serio0: Use 'setkeycodes e078 <keycode>' to make it known.
Jul 15 20:46:14 manjaro xdg-desktop-por[5739]: Theme parser error: gtk.css:6100:3-36: No property named "-GtkTreeView-horizontal-separator"
Jul 15 20:46:14 manjaro xdg-desktop-por[5739]: Theme parser error: gtk.css:6101:3-34: No property named "-GtkTreeView-vertical-separator"
Jul 15 20:46:14 manjaro xdg-desktop-por[5739]: Theme parser error: gtk.css:6159:3-29: No property named "-GtkTreeView-expander-size"
Jul 15 20:46:14 manjaro xdg-desktop-por[5739]: Theme parser error: gtk.css:6192:3-37: No property named "-GraniteWidgetsPopOver-arrow-width"
Jul 15 20:46:14 manjaro xdg-desktop-por[5739]: Theme parser error: gtk.css:6193:3-38: No property named "-GraniteWidgetsPopOver-arrow-height"
Jul 15 20:46:14 manjaro xdg-desktop-por[5739]: Theme parser error: gtk.css:6194:3-39: No property named "-GraniteWidgetsPopOver-border-radius"
Jul 15 20:46:14 manjaro xdg-desktop-por[5739]: Theme parser error: gtk.css:6195:3-38: No property named "-GraniteWidgetsPopOver-border-width"
Jul 15 20:46:14 manjaro xdg-desktop-por[5739]: Theme parser error: gtk.css:6196:3-37: No property named "-GraniteWidgetsPopOver-shadow-size"
Jul 15 20:46:44 manjaro xdg-desktop-por[5722]: Failed to get application states: GDBus.Error:org.freedesktop.portal.Error.Failed: Could not get window list
find:
[manjaro@manjaro ~]$ find /etc/X11/ -name "*.conf"
/etc/X11/mhwd.d/nvidia.conf
/etc/X11/xorg.conf.d/90-mhwd.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
there are failed nvidia logs, dont really see anything there related to graphics/display… but since it also happend on open source drivers, the flickering is not probably related to nvidia…
install different kernel, the 5.18 for example and boot with it
Hmm, I did a
sudo pacman -S linux518
and rebooted, and then
[manuel@nial ~]$ uname -r
5.18.10-1-MANJARO
And it seems to be gone. But I now have another interesting issue - when I move the mouse in the upper third of the screen, it gets laggy and refreshes only after a little while to its real position.
But I will test the system a bit and create a new issue for that one. Thank you very much brahma.
so try another kernels, the 5.19 experimental, and the 5.18rt…
I will do that. What did resolve this issue for now is to put a custom scaling (eg. 0.9) at the Display setting.
system
Closed
21 July 2022 02:55
12
