i am very confused about disk usage! when i right click->properties on my manjaro partition it says 75,5GB / 114,7GB free. however filelight show only 16,3GB of data on there.
the recycle bin (currently empty) has 11,5GB “free space”, im not sure what thats supposed to mean exactly. i thought it might “reserve” space, but adding 11,5GB + 16,3GB is not even 30GB and dolphin somehow says that 39,2GB (114,7-75,5) is used.
if someone could explain whats going on here i would be very thankful!
i just read a little about BRTFS, wow i didnt expect it to be so different from other file systems. i kinda understand now why the numbers in dolphin/filelight dont make sense, but i still dont know how i managed to fill so much space already
so this means i have 36GB of data and BRTFS uses 65GB to store it right now?
just launched timeshift for the first time. i knew about the snapshot feature but i did not mess with it so far. timeshift seems to be active and lists 4 snapshots, including one half an hour ago!
i dont know what hardlinks are … i basically chose BRTFS in installer and did not change anything about the filesystem manually.
I don’t use BTRFS, but I had assumed that the default layout during installation puts tmp in its own subvolume and specifically excludes it from snapshots?
That’s up to you.
Personally, I have switched to creating Timeshift snapshots manually, and keep one “fairly recent” shapshot at all times, just in case an update breaks something. At least I can revert and keep using my system until a fix is discovered (or try the update again.)
Because I do it manually, I also manually delete older snapshots so that I always have “one fairly recent” snapshot in Timeshift. (I’m using XFS, not BTRFS.)
Just don’t try to get creative with btrfs commands, and stick to using Timeshift’s GUI to delete older snapshots. The reason I mention this is because there’s a risk of accidentally typing in the wrong command or parameter in the terminal, and you end up destroying invaluable data on the live filesystem.
but i still wonder how i have 33,8GB! no pictures/movies/music/etc on the SSD, just a month old manjaro. and not that many programs actually, i just tried many but uninstalled most.
