Could be a permissions issue.
Or Filelight doesnāt understand how to properly read and scan BTRFS, unlike traditional filesystems such as Ext4, XFS, and FAT.
I can confirm that Filelight shows wrong size in my device when using Btrfs.
okay cool!
but i still feel like 30GB is a lot ā¦ i mean isnt it? after cleaning up everything. i dont have a lot of software and especially nothing that would take up a lot of space
No, itās normal. Comparing with Manjaro KDE in my VM it also has 26 GB without my data.
Curious about,
du -hs /home
okay
is there a way to show which packages / programs take up the most space?
You should disable baloo
that should not further reindex your data .
balooctl disable
balooctl purge
hahaha 16GB, u got me
5GB downloads, but almost 8GB in .local
Thatās why.
thanks a lot guys !
i dont really understand why tbh
Baloo is search algorithm to collect all your files, it is enabled by default.
but It has the known bug with Btrfs or Zfs:
https://bugs.kde.org/show_bug.cgi?id=402154
It will reindex your data every snapshot and reboot and store a lot of duplicate of indexing in Baloo cache.
You do not need Baloo, just use kfind
that was integrated in Dolphin.
okay thanks for the explanation
/tmp
does not reside on disk. It is a tmpfs
, i.e. a filesystem in virtual memory. Its contents live in RAM but can be paged out to swap if necessary.
Also, it is unnecessary to clean out /tmp
manually, becauseā¦
Given that it only resides in virtual memory, it is empty on boot, albeit that systemd
and other components of the system will quickly be creating sockets there; and
On systems that are kept running overnight, systemd
will periodically clean out /tmp
itself by way of the systemd-clean-tmpfiles.timer
Our old friend @dalto has built a very nice btrfs assistant software.
I recommend taking a look at it. It is a custom package and as such unsupported - that said - check it out.
pamac build btrfs-assistant
btrfs-assistant
source is original is in his Gitlab.
GitLab.com
We can support it if we have time.
grub-btrfs
was installed in Manjaro by default.
When you try to restore a snapshot in grub, but grub is still booting into the read-only snapshot, It is not restoring anything. You need to add grub-btrfs-overlayfs
in HOOKS.
See my explanation how restoring works.
