Good day,
I have 2 new laptops which I have installed Manjaro XFCE and I use xinput commands to allow touchpad to be used while typing for gaming, however trying to create a script to run at startup is beyond my Linux capabilities and my Google/search skills are lacking as I can’t find a dummed down enough forum post to teach me, essentially what I want to happen is for the following command to activate on startup, or a different way to achieve the same effect on startup.
Based on instructions from this post: [HowTo] Enable Touchpad While Typing In Manjaro Xfce
“[setayo@Majaro-F7S ~]$ xinput set-prop 9 337 0”
xinput prop 9 is my touchpad, 337 is the disable while typing argument.
338 is the default for disable while typing, however when I try to edit that even as sudo comes up with an error.
“[setayo@Majaro-F7S ~]$ sudo xinput set-prop 9 338 0
[sudo] password for setayo:
X Error of failed request: BadAccess (attempt to access private resource denied)
Major opcode of failed request: 131 (XInputExtension)
Minor opcode of failed request: 57 ()
Serial number of failed request: 20
Current serial number in output stream: 21”
Even if I try sudo su it will come up with the same result.
[setayo@SamsungS9 ~]$ xinput set-prop 11 320 0
[setayo@SamsungS9 ~]$ sudo su
[SamsungS9 setayo]# xinput set-prop 11 321 0
