Hi everyone, this is driving me insane. I’ve disabled every device in /proc/acpi/wakeup
Device S-state Status Sysfs node
GPP0 S4 *disabled pci:0000:00:01.1
GPP2 S4 *disabled
GPP3 S4 *disabled
GPP4 S4 *disabled
GPP5 S4 *disabled
GPP6 S4 *disabled
GPP7 S4 *disabled
GPP8 S4 *disabled pci:0000:00:03.1
GPP9 S4 *disabled
GPPA S4 *disabled
GPPB S4 *disabled
GPPC S4 *disabled
GPPD S4 *disabled
GPPE S4 *disabled
GPPF S4 *disabled
GP10 S4 *disabled
GP11 S4 *disabled
GP12 S4 *disabled pci:0000:00:07.1
GP13 S4 *disabled pci:0000:00:08.1
XHC0 S4 *disabled pci:0000:2f:00.3
GP30 S4 *disabled
GP31 S4 *disabled
BXBR S4 *disabled pci:0000:00:01.2
And yet my Logitech Bolt receiver will not stop waking the computer. When I remove the receiver from the computer it will stay suspended. This issue does not happen in Windows. I’ve tried switching the kernel from 6.1.23-1 to 6.2.10-1 and 6.3.0rc5-1 but they all have the same issue.
Below is my software version information as well as hardware.
cscs
10 April 2023 02:26
2
Disable Wake-on-LAN in BIOS?
PS your soft/hard info is woefully incomplete (ex - the reciever in question).
Please see the following or any similar thread.
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
Finally found the solution, I hope this helps someone in the future.
Create /etc/udev/rules.d/90-usb-wakeup.rules with the following content:
# Disable Logitech waking
ACTION=="add", SUBSYSTEM=="usb", DRIVERS=="usb", ATTRS{idVendor}=="046d", ATTRS{idProduct}=="c548", ATTR{power/wakeup}="disabled"
This is specific to my Logitech Bolt receiver, to verify you have the correct device run this:
lsusb | grep Logitech
This was my output
Bus 003 Device 005: ID 046d:c548 Logitech, Inc. Logi Bolt Receiver
In the udev rule replace the following with your device info:
idVendor=046d
idProduct=c548
Finally my system is able to sleep.
system
Closed
30 July 2023 15:37
4
