Dialog Fonts invisible
I am on the rolling release of Manjaro with Gnome and latest updates and for a while - I think it was the last last major update - I cannot read anything in system dialogs anymore. Also nautilus wont show any text. Installation is more or less stock, using Adwaita in dark mode. Used to work but then after that update text went missing. Tried to dig into how Gnome does stuff, got lost but did not get my text back. Any ideas much appreciated :slightly_smiling_face:
Its a notebook with an older nvidia quadro K1000M using the 390.157 drivers.
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
sudo inxi --verbosity=8 --filter --width
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
  1. Or we can try to play hide and seek :wink:
After posting this I happen to find out that this problem bubbled up while I was overseas - there was a solution a few days old that I did not see before posting.
See this post for this solution (others may pop up elsewhere):
  • 390 nvidia drivers causing the problem in Gnome 46
  • add the following lines to /etc/environment and reboot
GSK_RENDERER=gl
GDK_DEBUG=gl-prefer-gl
  • keep this until 390 drivers fixed?
