ERROR: device 'UUID=d3a92cb7-ca9a-4e0e-89dc-0c131d2816d8' not found. Skipping fsck.
mount: /new_root: can't find UUID=d3a92cb7-ca9a-4e0e-89dc-0c131d2816d8.
You are now being dropped into an emergency shell.
sh: can't access tty; job control turned off
Following a similar step from another thread , I was able to get Manjaro to boot when installing vmd as a hook. However, upon shutdown, the system would revert to the problem pasted above. The first few times, the problem would be remedied when the Live USB was plugged into the system which would lead to manjaro booting as usual. After another shutdown, however, the system reverted back to the issue I’ve been facing for the past 3 days. Any help would be appreciated!
Just some system info: I have 2x1TB ssds which were previously in raid 0 with windows 11. Since then, I’ve disabled intel VMD and also disabled intel raid on the drives. I’ve wiped them clean using diskpart and am now trying to install manjaro.
edit: did a clean reinstall and still, no improvements whatsoever
Can you provide some system information ?
inxi -Fza
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2137 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Strix G733CX_G733CX v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G733CX v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G733CX.310 date: 07/29/2022
ID-1: BAT0 charge: 93.1 Wh (100.0%) condition: 93.1/90.0 Wh (103.5%)
volts: 17.4 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown
serial: <filter> status: full
Info: model: 12th Gen Intel Core i9-12950HX bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x22
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 1577 high: 3800 min/max: 800/4997:5076:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1193 2: 1658 3: 802
4: 800 5: 801 6: 1678 7: 3794 8: 3800 9: 1515 10: 1772 11: 1719 12: 1631
13: 1551 14: 1730 15: 801 16: 1713 17: 799 18: 1898 19: 1393 20: 1478
21: 800 22: 1487 23: 1470 24: 1582 bogomips: 119832
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel vendor: ASUSTeK driver: i915 v: kernel arch: Gen-12.2
process: Intel 10nm built: 2021-22+ ports: active: eDP-1 empty: DP-1, DP-2,
HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:4688 class-ID: 0300
Device-2: NVIDIA GA103M [GeForce RTX 3080 Ti Mobile] vendor: ASUSTeK
driver: N/A alternate: nouveau non-free: 515.xx+ status: current (as of
2022-07) arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2420 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0a00 built: 2021 res: 1920x1080
hz: 360 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2288 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: no
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 6d:00.0
IF: enp109s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 957.62 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme1n1 maj-min: 259:0 vendor: Micron
model: 3400 MTFDKBA1T0TFH size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: P7MA001 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: N/A size: 3.75 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 2.00 scheme: MBR
Message: No partition data found.
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2500
Processes: 419 Uptime: 0m wakeups: 2 Memory: 30.98 GiB used: 1.64 GiB
(5.3%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1166 lib: 327 flatpak: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.20
At this point, the nvme1n0 isn’t even showing up…
Can you post fdisk -l and blkid ?
sudo fdisk -l:
Disk /dev/nvme0n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: Micron_3400_MTFDKBA1T0TFH
Disklabel type: gpt
Disk identifier: 271C5139-FAB4-4340-9A22-8C94441AC526
Disk /dev/loop0: 131.84 MiB, 138248192 bytes, 270016 sectors
Disk /dev/loop1: 717.49 MiB, 752340992 bytes, 1469416 sectors
Disk /dev/loop2: 1.76 GiB, 1888153600 bytes, 3687800 sectors
Disk /dev/loop3: 645.26 MiB, 676605952 bytes, 1321496 sectors
Disk /dev/sda: 3.75 GiB, 4027580416 bytes, 7866368 sectors
Disk model: ProductCode
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 64 6894755 6894692 3.3G 0 Empty
/dev/sda2 6894756 6902947 8192 4M ef EFI (FAT-12/16/32)
sudo blkid
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/sda2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="D007-DD0F" BLOCK_SIZE="512" TYPE="vfat"
/dev/sda1: BLOCK_SIZE="2048" UUID="2022-08-16-12-55-20-00" LABEL="MANJARO_XFCE_2137" TYPE="iso9660"
/dev/loop3: TYPE="squashfs"
/dev/nvme0n1p3: LABEL="swap" UUID="d3a92cb7-ca9a-4e0e-89dc-0c131d2816d8" TYPE="swap" PARTUUID="bf4554f3-2183-0b4a-ae67-8efd21b749bf"
/dev/nvme0n1p1: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="D8E9-7EDB" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="3c51695f-651d-4c45-94f5-9b1ac6b2fdc3"
/dev/nvme0n1p2: UUID="7623fb52-ab86-4774-b27e-acba9a04bf31" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="root" PARTUUID="e50209f9-6ee9-4041-8938-955c6d55600b"
Can you start Gparted from Manjaro USB stick and show the partitioning/drives ?
When I use Gparted, the drive manjaro previously resided on disappears and can’t be seen through any of the commands above. The only way I can access the drive is through diskpart in windows where I wipe the drive clean. Only then, can manjaro see the drive once more. (Within the image is my second m.2 drive)
lsblk -fa:
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
loop4
loop5
loop6
loop7
sda iso9660 Joliet Extension MANJARO_XFCE_2137 2022-08-16-12-55-20-00 0 100% /run/miso/bootmnt
├─sda1 iso9660 Joliet Extension MANJARO_XFCE_2137 2022-08-16-12-55-20-00
└─sda2 vfat FAT12 MISO_EFI D007-DD0F
nvme1n1
nvme0n1 has seemingly vanished from existence…
brahma
1 September 2022 08:58
10
also add output from:
cat /etc/fstab
All yours
# /etc/fstab: static file system information
# <file system> <dir> <type> <options> <dump> <pass>
/dev/mapper/root-image / auto defaults 0 0
brahma
1 September 2022 09:07
12
it looks like the nvm is completely deleted …
when in the bios, the nvme is still visible. It’s only manjaro that can no longer detect whether the nvme still exists or not ;(
brahma
1 September 2022 09:10
14
lsblk shows that it is completely empty, not formatted like it was deleted …
the gparted pic shows the same
gparted/lsblk/blkid/fdisk are detecting the disk but its empty
oh nvme1n1 isn’t the target ssd. The target ssd is nvme0n1 which is completely off the radar
brahma
1 September 2022 09:14
16
you mean this one:
Disklabel type: gpt
brahma
1 September 2022 09:20
18
you mention something about raid … is AHCI enabled in bios?
Are you sure you properly removed both drives from the RAID 0 array ?
What looks strange is that nvme1n1 is shown in lsblk -fa but not in fdisk -l … and nvme0n1 is shown in fdisk -l but not in lsblk -fa
While in GParted, did you click on the dropdown menu ?
Yeah I have clicked the menu and still, only shows one drive at a time. Also I’m not quite sure if I have fully unraided the drives. I’m quite sure I have since they show as two separate drives on windows!
