Device not accepting address / xhci_hcd / device descriptor read error
Hi All,
I checked the “sudo dmesg” and I got this:
[ 2175.552372] usb 1-8: device not accepting address 87, error -71
[ 2175.552487] usb 1-8: WARN: invalid context state for evaluate context command.
[ 2175.872229] usb 1-8: new full-speed USB device number 88 using xhci_hcd
[ 2175.872382] usb 1-8: Device not responding to setup address.
[ 2176.075743] usb 1-8: Device not responding to setup address.
[ 2176.278951] usb 1-8: device not accepting address 88, error -71
[ 2176.279062] usb 1-8: WARN: invalid context state for evaluate context command.
[ 2176.279165] usb usb1-port8: unable to enumerate USB device
[ 2176.575651] usb 1-8: new full-speed USB device number 89 using xhci_hcd
[ 2176.692396] usb 1-8: device descriptor read/64, error -71
[ 2176.912353] usb 1-8: device descriptor read/64, error -71
[ 2177.132167] usb 1-8: new full-speed USB device number 90 using xhci_hcd
[ 2177.249043] usb 1-8: device descriptor read/64, error -71
[ 2177.468937] usb 1-8: device descriptor read/64, error -71
[ 2177.572375] usb usb1-port8: attempt power cycle
[ 2177.958825] usb 1-8: new full-speed USB device number 91 using xhci_hcd
[ 2177.959072] usb 1-8: Device not responding to setup address.
[ 2178.162481] usb 1-8: Device not responding to setup address.
[ 2178.366364] usb 1-8: device not accepting address 91, error -71
[ 2178.366508] usb 1-8: WARN: invalid context state for evaluate context command.
[ 2178.686371] usb 1-8: new full-speed USB device number 92 using xhci_hcd
[ 2178.686574] usb 1-8: Device not responding to setup address.
[ 2178.889916] usb 1-8: Device not responding to setup address.
[ 2179.093040] usb 1-8: device not accepting address 92, error -71
The system is:
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=9ca29dab-0cc3-4fd7-9da4-6561f7e7dd41 rw quiet splash apparmor=1
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: HP product: HP EliteBook 820 G4 v: N/A
  Mobo: HP model: 8292 v: KBC Version 45.52 serial: <superuser required>
    part-nu: Z2V75ET#ABU uuid: <superuser required> UEFI: HP v: P78 Ver. 01.48
    date: 10/05/2023
  ID-1: BAT0 charge: 32.1 Wh (100.0%) condition: 32.1/44.6 Wh (72.0%)
    volts: 12.7 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: full cycles: 383
  System RAM: total: 16 GiB available: 15.5 GiB used: 4.33 GiB (28.0%)
  Device-1: Bottom-Slot 1(left) type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: curr: 1 width (bits):
    data: 64 total: 128 manufacturer: Micron part-no: 18ASF1G72HZ-2G3B1
    serial: <filter>
  Device-2: Bottom-Slot 2(right) type: DDR4 detail: synchronous unbuffered
    data: 64 total: 64 manufacturer: Hynix/Hyundai part-no: HMA41GS6AFR8N-TF
    serial: <filter>
  Info: model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
    microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 800 min/max: 400/3500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 23209
    dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm
    lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
    pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
    sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
    tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:5916 class-ID: 0300
  Device-2: Chicony HP HD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:7 chip-ID: 04f2:b51d
  Display: x11 server: X.org v: 1.21.1.16 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: AU Optronics 0x226d built: 2015 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 177 gamma: 1.2 chroma: red:
    x: 0.584 y: 0.349 green: x: 0.345 y: 0.588 blue: x: 0.157 y: 0.114 white:
    x: 0.314 y: 0.329 size: 276x155mm (10.87x6.1") diag: 317mm (12.5")
    ratio: 16:9 modes: 1920x1080
  EDID-Warnings: 1: parse_edid: unknown flag 2
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
    device-ID: 8086:5916 memory: 7.57 GiB unified: yes
    x11: xprop,xrandr
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
    class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0a2b
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 68.31 GiB (14.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZHPV512HDGL-000L1
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 5L0Q scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 68.31 GiB (14.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 9ca29dab-0cc3-4fd7-9da4-6561f7e7dd41
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: A023-D873
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-7:2 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Device-2: 1-9:7 info: Chicony HP HD Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b51d class-ID: 0e02 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 34.0 C pch: 36.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1256 pm: pacman pkgs: 1250 libs: 380 tools: pamac,yay pm: flatpak
    pkgs: 6
    1: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    2: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    3: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    4: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    5: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    6: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    7: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    8: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 214
  1: cpu: 13.5% command: chrome pid: 15565 mem: 299.2 MiB (1.8%)
  2: cpu: 7.2% command: chrome pid: 8662 mem: 322.4 MiB (2.0%)
  3: cpu: 6.4% command: chrome pid: 8616 mem: 542.2 MiB (3.4%)
  4: cpu: 6.3% command: chrome pid: 15487 mem: 452.6 MiB (2.8%)
  5: cpu: 4.9% command: Xorg pid: 770 mem: 110.9 MiB (0.6%)
  Memory top: 5 of 214
  1: mem: 693.8 MiB (4.3%) command: telegram-desktop pid: 14751 cpu: 3.0%
  2: mem: 542.2 MiB (3.4%) command: chrome pid: 8616 cpu: 6.4%
  3: mem: 484.5 MiB (3.0%) command: chrome pid: 10135 cpu: 1.6%
  4: mem: 452.6 MiB (2.8%) command: chrome pid: 15487 cpu: 6.3%
  5: mem: 368.5 MiB (2.3%) command: chrome pid: 8809 cpu: 3.2%
  Processes: 214 Power: uptime: 4h 42m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: upowerd,xfce4-power-manager
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.37
Could You please help me, what is the problem and how can I solve it?
I am new in the world of Linux and I like the Manjaro.
Thanks for Your help in advance.
Is the system up to date?
Rebooted after kernel update?
What kind of device is it?
Do you positively know it is working?
Have you tried a different port - or a different cable?
Please format terminal output as “preformatted text” for readability → this symbol: </>
like this:
Please read through the linked items (marked with :eyes:) and after that, please provide system information as described (below).
System information should be formatted as preformatted text as described in the links you have been directed to.
When you have read the information, use your newly acquired knowledge to edit your previous post so that the command output you posted appears as preformatted text.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
Hi Nachlese,
Yes, the system up to date.
Yes, it was rebooted after kernel update.
It is a HP EliteBook 820 G4
It looks like all of the USB ports are working.
The system is:
    date: 10/05/2023
  System RAM: total: 16 GiB available: 15.5 GiB used: 4.35 GiB (28.1%)
    serial: <filter>
    serial: <filter>
    microcode: 0xF6
  Speed (MHz): avg: 400 min/max: 400/3500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 23209
    xtopology xtpr
    inactive: wayland
    x11: xprop,xrandr
    class-ID: 0280
    class-ID: e001
    uuid: A023-D873
  System Temperatures: cpu: 33.8 C pch: 35.5 C mobo: N/A
    pkgs: 6
Processes:
  CPU top: 5 of 215
  1: cpu: 13.0% command: chrome pid: 15565 mem: 329.5 MiB (2.0%)
  2: cpu: 7.2% command: chrome pid: 8662 mem: 323.2 MiB (2.0%)
  3: cpu: 6.3% command: chrome pid: 8616 mem: 543.4 MiB (3.4%)
  4: cpu: 4.8% command: Xorg pid: 770 mem: 111.2 MiB (0.7%)
  5: cpu: 4.1% command: chrome pid: 15487 mem: 466.6 MiB (2.9%)
  Memory top: 5 of 215
  1: mem: 693.8 MiB (4.3%) command: telegram-desktop pid: 14751 cpu: 2.6%
  2: mem: 543.4 MiB (3.4%) command: chrome pid: 8616 cpu: 6.3%
  3: mem: 485.0 MiB (3.0%) command: chrome pid: 10135 cpu: 1.5%
  4: mem: 466.6 MiB (2.9%) command: chrome pid: 15487 cpu: 4.1%
  5: mem: 373.8 MiB (2.3%) command: chrome pid: 8809 cpu: 3.1%
  Processes: 215 Power: uptime: 4h 47m states: freeze,mem,disk suspend: deep
Sorry - imprecise language on my part.
What I wanted to know is what kind of device was it that failed - not the computer, but the other side of the equation :upside_down_face:
I used a pendrive to install the system, then I removed it from the laptop. That’s all.
System information only needs to be provided once; usually, in the first post. If you have already provided system information and it’s incomplete or needs to be updated, a Member might ask you edit the post accordingly. Otherwise, just politely point them to the post concerned (they might have missed it).
You have provided very little description of your issue; we can see that it’s likely a USB device of some kind, but beyond that we can only guess.
I see you read how to use preformatted text for command output. Thank you. Now, if you could also read “How to Post” and “How to Request Support” I’m sure these will be beneficial.
It’s possible that the ISO wasn’t written to USB correctly; or that the device is of poor quality, or wasn’t properly erased.
Ventoy is highly recommended rather than physically writing an ISO to USB. I wrote a tutorial for creating a Ventoy USB recently; I hope you find it useful:
Did you remove it before installation had completed?
No, I removed after the restart, but it stopped with black screen. So, I removed the pendrive and it restarted.
Does this pendrive give you these messages when you plug it in and unplug it?
Does it work? - the drive, I mean.
