EDIT: It turns out the issue was the hard drive I was using. I’m not exactly sure what was wrong with it, but I put the original 128GB ssd that came with the computer and everything is working fine.
I have a new ThinkPad T14 with the AMD Ryzen 4750U. I did swap out the NVMe drives and add another 8GB of memory.
Here are the specs:
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.8-x86_64
root=UUID=22df65c2-987a-4a69-9c88-f9f7309b2b9c rw quiet
resume=UUID=c6f723fe-923c-42a7-9f0e-067f68422084 udev.log_priority=3
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20UDCTO1WW v: ThinkPad T14 Gen 1
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20UDCTO1WW serial: <filter> UEFI: LENOVO
v: R1BET56W(1.25 ) date: 09/16/2020
ID-1: BAT0 charge: 46.3 Wh condition: 50.5/50.5 Wh (100%) volts: 12.8/11.6
model: LGC 5B10W139 type: Li-poly serial: <filter> status: Unknown cycles: 2
Info: 8-Core model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 L2 cache: 4096 KiB
bogomips: 54317
Speed: 1400 MHz min/max: 1400/1700 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1400 3: 1397 4: 1395 5: 1399 6: 1396 7: 1397 8: 1397 9: 1397
10: 1394 11: 1395 12: 1394 13: 1399 14: 1577 15: 1397 16: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 07:00.0
chip ID: 1002:1636
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 2-2:2
chip ID: 04f2:b6d9 serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.18-1-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.2.2 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 07:00.1
chip ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 07:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 07:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.18-1-MANJARO
vendor: Lenovo driver: r8169 v: kernel port: 3400 bus ID: 02:00.0
chip ID: 10ec:8168
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
bus ID: 03:00.0 chip ID: 8086:2723
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 05:00.0
chip ID: 10ec:8168
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 465.76 GiB used: 8.94 GiB (1.9%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G2B0C-00PXH0
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 211070WD scheme: GPT
ID-1: / raw size: 97.66 GiB size: 95.62 GiB (97.92%) used: 8.18 GiB (8.6%)
fs: ext4 dev: /dev/nvme0n1p6
ID-2: /boot raw size: 2.00 GiB size: 1.91 GiB (95.30%) used: 60.7 MiB (3.1%)
fs: ext4 dev: /dev/nvme0n1p5
ID-3: /home raw size: 244.14 GiB size: 239.31 GiB (98.02%)
used: 664.1 MiB (0.3%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1
System Temperatures: cpu: 46.6 C mobo: 0.0 C gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): cpu: 0
Processes: 331 Uptime: N/A Memory: 14.93 GiB used: 820.6 MiB (5.4%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1050 lib: 299
Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.08
I’ve had the worst luck trying to get Linux running on this. Manjaro, OpenSuse, Pop all have had issues. Anyway, I’ll keep this issue specific to the current one.
I’m able to boot up and login just fine. I can use the desktop session as normal without any issues, but essentially every time, at some point the desktop will freeze, crash to a black screen and stay there. I can manually reboot and everything is working again. Rinse and repeat.
Any help is appreciated! I don’t know what to do anymore…I’ve never had any trouble with Linux before that even comes close to this…
Here is the tail end of journalctl before a crash.
Nov 18 10:42:07 ThinkPad kernel: wlp3s0: authenticated
Nov 18 10:42:07 ThinkPad kernel: wlp3s0: associate with 2c:30:33:38:e3:8c (try 1/3)
Nov 18 10:42:07 ThinkPad kernel: wlp3s0: RX AssocResp from 2c:30:33:38:e3:8c (capab=0x11 status=0 aid=1)
Nov 18 10:42:07 ThinkPad wpa_supplicant[1261]: wlp3s0: Associated with 2c:30:33:38:e3:8c
Nov 18 10:42:07 ThinkPad wpa_supplicant[1261]: wlp3s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Nov 18 10:42:07 ThinkPad kernel: wlp3s0: associated
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.4280] device (wlp3s0): supplicant interface state: associating -> associated
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.4280] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> associated
Nov 18 10:42:07 ThinkPad wpa_supplicant[1261]: wlp3s0: WPA: Key negotiation completed with 2c:30:33:38:e3:8c [PTK=CCMP GTK=CCMP]
Nov 18 10:42:07 ThinkPad wpa_supplicant[1261]: wlp3s0: CTRL-EVENT-CONNECTED - Connection to 2c:30:33:38:e3:8c completed [id=0 id_str=]
Nov 18 10:42:07 ThinkPad kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7180] device (wlp3s0): supplicant interface state: associated -> completed
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7181] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "NETGEAR71-5G"
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7181] device (p2p-dev-wlp3s0): supplicant management interface state: associated -> completed
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7184] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7215] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Nov 18 10:42:07 ThinkPad wpa_supplicant[1261]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-46 noise=9999 txrate=0
Nov 18 10:42:07 ThinkPad avahi-daemon[579]: Joining mDNS multicast group on interface wlp3s0.IPv6 with address fe80::6bb7:cb64:7dee:cdbc.
Nov 18 10:42:07 ThinkPad avahi-daemon[579]: New relevant interface wlp3s0.IPv6 for mDNS.
Nov 18 10:42:07 ThinkPad avahi-daemon[579]: Registering new address record for fe80::6bb7:cb64:7dee:cdbc on wlp3s0.*.
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7451] dhcp4 (wlp3s0): option dhcp_lease_time => '86400'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7451] dhcp4 (wlp3s0): option domain_name_servers => '192.168.1.1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7451] dhcp4 (wlp3s0): option expiry => '1605807727'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7452] dhcp4 (wlp3s0): option ip_address => '192.168.1.17'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7452] dhcp4 (wlp3s0): option requested_broadcast_address => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7452] dhcp4 (wlp3s0): option requested_domain_name => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7452] dhcp4 (wlp3s0): option requested_domain_name_servers => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7452] dhcp4 (wlp3s0): option requested_domain_search => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7452] dhcp4 (wlp3s0): option requested_host_name => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7452] dhcp4 (wlp3s0): option requested_interface_mtu => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7452] dhcp4 (wlp3s0): option requested_ms_classless_static_routes => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7453] dhcp4 (wlp3s0): option requested_nis_domain => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7453] dhcp4 (wlp3s0): option requested_nis_servers => '1'
Nov 18 10:42:07 ThinkPad avahi-daemon[579]: Joining mDNS multicast group on interface wlp3s0.IPv4 with address 192.168.1.17.
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7453] dhcp4 (wlp3s0): option requested_ntp_servers => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7453] dhcp4 (wlp3s0): option requested_rfc3442_classless_static_routes => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7453] dhcp4 (wlp3s0): option requested_root_path => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7453] dhcp4 (wlp3s0): option requested_routers => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7453] dhcp4 (wlp3s0): option requested_static_routes => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7453] dhcp4 (wlp3s0): option requested_subnet_mask => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7453] dhcp4 (wlp3s0): option requested_time_offset => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7454] dhcp4 (wlp3s0): option requested_wpad => '1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7454] dhcp4 (wlp3s0): option routers => '192.168.1.1'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7454] dhcp4 (wlp3s0): option subnet_mask => '255.255.255.0'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7454] dhcp4 (wlp3s0): state changed unknown -> bound
Nov 18 10:42:07 ThinkPad avahi-daemon[579]: New relevant interface wlp3s0.IPv4 for mDNS.
Nov 18 10:42:07 ThinkPad avahi-daemon[579]: Registering new address record for 192.168.1.17 on wlp3s0.IPv4.
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7495] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 18 10:42:07 ThinkPad dbus-daemon[581]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=582 comm="/usr/bin/NetworkManager --no-daemon ")
Nov 18 10:42:07 ThinkPad systemd[1]: Starting Network Manager Script Dispatcher Service...
Nov 18 10:42:07 ThinkPad dbus-daemon[581]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 18 10:42:07 ThinkPad systemd[1]: Started Network Manager Script Dispatcher Service.
Nov 18 10:42:07 ThinkPad audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7629] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 18 10:42:07 ThinkPad kernel: audit: type=1130 audit(1605721327.756:71): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7633] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7640] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7675] manager: NetworkManager state is now CONNECTED_SITE
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7676] policy: set 'NETGEAR71-5G' (wlp3s0) as default for IPv4 routing and DNS
Nov 18 10:42:07 ThinkPad dbus-daemon[581]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.3' (uid=0 pid=582 comm="/usr/bin/NetworkManager --no-daemon ")
Nov 18 10:42:07 ThinkPad dbus-daemon[581]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
Nov 18 10:42:07 ThinkPad NetworkManager[582]: <info> [1605721327.7702] device (wlp3s0): Activation: successful, device activated.
Nov 18 10:42:08 ThinkPad NetworkManager[582]: <info> [1605721328.1480] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 18 10:42:08 ThinkPad plasmashell[1541]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlasmoidHeading.qml:53:5: Unable to assign [undefined] to int
Nov 18 10:42:08 ThinkPad plasmashell[1541]: file:///usr/lib/qt/qml/org/kde/plasma/components/ModelContextMenu.qml:38:1: QML ModelContextMenu: Accessible must be attached to an Item
Nov 18 10:42:09 ThinkPad baloo_file[1536]: replace called with invalid arguments, docId: 16888502897672962 url: "/home/chris/"
Nov 18 10:42:09 ThinkPad kwin_x11[1490]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5199, resource id: 31457470, major code: 18 (ChangeProperty), minor code: 0
Nov 18 10:42:09 ThinkPad systemd[1411]: Created slice app.slice.
Nov 18 10:42:09 ThinkPad systemd[1411]: Started Konsole - Terminal.
Nov 18 10:42:09 ThinkPad kwin_x11[1490]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5634, resource id: 14680451, major code: 3 (GetWindowAttributes), minor code: 0
Nov 18 10:42:09 ThinkPad kwin_x11[1490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5635, resource id: 14680451, major code: 14 (GetGeometry), minor code: 0
Nov 18 10:42:12 ThinkPad systemd[1]: Stopping User Manager for UID 968...
Nov 18 10:42:12 ThinkPad systemd[1318]: Stopped target Main User Target.
Nov 18 10:42:12 ThinkPad systemd[1318]: Stopping D-Bus User Message Bus...
Nov 18 10:42:12 ThinkPad systemd[1318]: dbus.service: Succeeded.
Nov 18 10:42:12 ThinkPad systemd[1318]: Stopped D-Bus User Message Bus.
Nov 18 10:42:13 ThinkPad systemd[1318]: Stopped target Basic System.
Nov 18 10:42:13 ThinkPad systemd[1318]: Stopped target Paths.
Nov 18 10:42:13 ThinkPad systemd[1318]: Stopped target Sockets.
Nov 18 10:42:13 ThinkPad systemd[1318]: Stopped target Timers.
Nov 18 10:42:13 ThinkPad systemd[1318]: dbus.socket: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1318]: Closed D-Bus User Message Bus Socket.
Nov 18 10:42:13 ThinkPad systemd[1318]: dirmngr.socket: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1318]: Closed GnuPG network certificate management daemon.
Nov 18 10:42:13 ThinkPad systemd[1318]: gpg-agent-browser.socket: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1318]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Nov 18 10:42:13 ThinkPad systemd[1318]: gpg-agent-extra.socket: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1318]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Nov 18 10:42:13 ThinkPad systemd[1318]: gpg-agent-ssh.socket: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1318]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Nov 18 10:42:13 ThinkPad systemd[1318]: gpg-agent.socket: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1318]: Closed GnuPG cryptographic agent and passphrase cache.
Nov 18 10:42:13 ThinkPad systemd[1318]: p11-kit-server.socket: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1318]: Closed p11-kit server.
Nov 18 10:42:13 ThinkPad systemd[1318]: pipewire.socket: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1318]: Closed Multimedia System.
Nov 18 10:42:13 ThinkPad systemd[1318]: pulseaudio.socket: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1318]: Closed Sound System.
Nov 18 10:42:13 ThinkPad systemd[1318]: Reached target Shutdown.
Nov 18 10:42:13 ThinkPad systemd[1318]: systemd-exit.service: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1318]: Finished Exit the Session.
Nov 18 10:42:13 ThinkPad systemd[1318]: Reached target Exit the Session.
Nov 18 10:42:13 ThinkPad systemd[1319]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Nov 18 10:42:12 ThinkPad audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 10:42:13 ThinkPad systemd[1]: user@968.service: Succeeded.
Nov 18 10:42:13 ThinkPad kernel: audit: type=1131 audit(1605721332.999:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 10:42:13 ThinkPad systemd[1]: Stopped User Manager for UID 968.
Nov 18 10:42:13 ThinkPad systemd[1]: Stopping User Runtime Directory /run/user/968...
Nov 18 10:42:13 ThinkPad systemd[1411]: run-user-968.mount: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1]: run-user-968.mount: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1]: user-runtime-dir@968.service: Succeeded.
Nov 18 10:42:13 ThinkPad systemd[1]: Stopped User Runtime Directory /run/user/968.
Nov 18 10:42:13 ThinkPad audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 10:42:13 ThinkPad kernel: audit: type=1131 audit(1605721333.013:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 10:42:13 ThinkPad systemd[1]: Removed slice User Slice of UID 968.
Nov 18 10:42:18 ThinkPad systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Nov 18 10:42:18 ThinkPad audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 10:42:18 ThinkPad kernel: audit: type=1131 audit(1605721338.079:74): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 10:42:26 ThinkPad systemd[1]: systemd-hostnamed.service: Succeeded.
Nov 18 10:42:26 ThinkPad audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 10:42:26 ThinkPad kernel: audit: type=1131 audit(1605721346.883:75): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 10:42:27 ThinkPad audit: BPF prog-id=10 op=UNLOAD
Nov 18 10:42:27 ThinkPad audit: BPF prog-id=9 op=UNLOAD
Nov 18 10:42:27 ThinkPad kernel: audit: type=1334 audit(1605721347.026:76): prog-id=10 op=UNLOAD
Nov 18 10:42:27 ThinkPad kernel: audit: type=1334 audit(1605721347.026:77): prog-id=9 op=UNLOAD
Nov 18 10:42:28 ThinkPad wpa_supplicant[1261]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-51 noise=9999 txrate=234000
Nov 18 10:42:32 ThinkPad wpa_supplicant[1261]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-46 noise=9999 txrate=234000
-- Reboot --
