Deskop background and pinned software position resetting
Hello people!
I have had this issue where my desktop background keeps resetting to a default background along with the position of my software on my desktop changes positions to the top left. This happens approximately every 3-4 reboots.
I have attempted to lock the applications in place on my desktop to keep them from being moved around on the desktop, it continues to reset the applications’ position to the top left regardless of lock status. I have heard of putting the wallpaper into the wallpaper folder, but I don’t know how to do it without giving me an error telling me I can’t move the file into the wallpaper system folder, plus I don’t know how to move files using the terminal.
System Information:
  Kernel: 6.0.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
    root=UUID=d0f4123d-e003-42fd-abdc-ac1d9f697701 rw quiet
    resume=UUID=5d0c86f0-1bba-4412-91a5-3d8b576b6965 udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Acer product: Aspire E5-575 v: V1.47
    serial: <superuser required>
  Mobo: Acer model: Ironman_SK v: V1.47 serial: <superuser required>
    UEFI: Insyde v: 1.47 date: 09/06/2018
  ID-1: BAT1 charge: 34.5 Wh (70.4%) condition: 49.0/62.2 Wh (78.9%)
    volts: 11.6 min: 11.1 model: PANASONIC AS16B5J type: Li-ion serial: <filter>
    status: discharging
  RAM: total: 3.7 GiB used: 1.31 GiB (35.4%)
  Info: model: Intel Core i3-7100U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
    family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1599 high: 2400 min/max: 400/2400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2400 2: 800 3: 799 4: 2400
    bogomips: 19204
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
    invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
    msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
    sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI Aspire E5-575G
    ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:5916 class-ID: 0300
  Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:3
    chip-ID: 04f2:b571 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x15d2 built: 2015 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 620 (KBL
    GT2) direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
    Aspire E5-575G driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
    class-ID: 0403
  Sound API: ALSA v: k6.0.8-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.59 running: yes
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
    vendor: Acer Incorporated ALI Aspire E5-575G driver: r8169 v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.1
  IF: enp3s0f1 state: down mac: <filter>
  Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
    v: 0.8 bus-ID: 1-5:2 chip-ID: 04ca:3015 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 465.76 GiB used: 23.79 GiB (5.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE5000PNC
    type: SSD serial: <filter> rev: 20RL scheme: GPT
  Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8AESH rev: XA11
    dev-links: cdrom
  ID-1: / raw-size: 457.32 GiB size: 449.07 GiB (98.20%) used: 23.79 GiB (5.3%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: d0f4123d-e003-42fd-abdc-ac1d9f697701
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: E643-2815
  ID-1: swap-1 type: partition size: 8.14 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: 5d0c86f0-1bba-4412-91a5-3d8b576b6965
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Lite-On Qualcomm Atheros QCA9377 Bluetooth
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 04ca:3015 class-ID: e001
  Device-2: 1-7:3 info: Chicony HD WebCam type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b571
    class-ID: 0e02
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 33.0 C pch: 32.5 C mobo: N/A
  Processes: 163 Uptime: 6m wakeups: 1 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1338 libs: 354 tools: pamac,paru pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
I am no expert when it comes to using the terminal, so If you have any solutions to my ongoing issue I’ve been having for a while and it can be fixed using the terminal, please provide me the solution with detail as I want to learn about the different things you can do in the terminal.
If there are any additional information or information I have not provided, please let me know!
I hope whatever solution(s) come from this topic can help others with similar issues!
You don’t need to mess with system folders. Plasma can load a wallpaper from any location in the filesystem where you have the permission to read files.
However, that said, there appear to be various ongoing reliability issues in Plasma for lots of people — albeit strangely enough not for everyone — ever since Plasma 5.25 was released, and at this point in time, many of those issues continue to endure in 5.26. I would therefore advise you to read and/or participate in the thread below. :arrow_down:
