Hi,
I would like to ask you for help with the integrated camera of my Dell Precision 5490 laptop. Sadly I do not know the exact name of the device as it is not written anywhere, the only thing the documentation says is that it is the “HD IR Camera with ALS sensor”.
Some outputs:
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 8086:0b63 Intel Corp. USB Bridge
Bus 003 Device 003: ID 27c6:634c Shenzhen Goodix Technology Co.,Ltd. Goodix Fingerprint USB Device
Bus 003 Device 004: ID 8087:0036 Intel Corp.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
lspci
0000:00:00.0 Host bridge: Intel Corporation Device 7d01 (rev 04)
0000:00:01.0 PCI bridge: Intel Corporation Device 7ecc (rev 10)
0000:00:02.0 VGA compatible controller: Intel Corporation Meteor Lake-P [Intel Arc Graphics] (rev 08)
0000:00:04.0 Signal processing controller: Intel Corporation Device 7d03 (rev 04)
0000:00:05.0 Multimedia controller: Intel Corporation Device 7d19 (rev 04)
0000:00:06.0 PCI bridge: Intel Corporation Device 7e4d (rev 20)
0000:00:07.0 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 10)
0000:00:07.1 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #1 (rev 10)
0000:00:07.2 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #2 (rev 10)
0000:00:07.3 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #3 (rev 10)
0000:00:08.0 System peripheral: Intel Corporation Device 7e4c (rev 20)
0000:00:0a.0 Signal processing controller: Intel Corporation Device 7d0d (rev 01)
0000:00:0b.0 Processing accelerators: Intel Corporation Meteor Lake NPU (rev 04)
0000:00:0d.0 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 USB Controller (rev 10)
0000:00:0d.2 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #0 (rev 10)
0000:00:0d.3 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #1 (rev 10)
0000:00:0e.0 RAID bus controller: Intel Corporation Volume Management Device NVMe RAID Controller Intel Corporation
0000:00:12.0 Serial controller: Intel Corporation Device 7e45 (rev 20)
0000:00:14.0 USB controller: Intel Corporation Meteor Lake-P USB 3.2 Gen 2x1 xHCI Host Controller (rev 20)
0000:00:14.2 RAM memory: Intel Corporation Device 7e7f (rev 20)
0000:00:15.0 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #0 (rev 20)
0000:00:15.3 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #3 (rev 20)
0000:00:16.0 Communication controller: Intel Corporation Device 7e70 (rev 20)
0000:00:1c.0 PCI bridge: Intel Corporation Device 7e3f (rev 20)
0000:00:1f.0 ISA bridge: Intel Corporation Device 7e02 (rev 20)
0000:00:1f.3 Multimedia audio controller: Intel Corporation Meteor Lake-P HD Audio Controller (rev 20)
0000:00:1f.4 SMBus: Intel Corporation Meteor Lake-P SMBus Controller (rev 20)
0000:00:1f.5 Serial bus controller: Intel Corporation Meteor Lake-P SPI Controller (rev 20)
0000:01:00.0 3D controller: NVIDIA Corporation AD107GLM [RTX 2000 Ada Generation Laptop GPU] (rev a1)
0000:02:00.0 Network controller: Intel Corporation Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2 (rev 1a)
0000:ab:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5260 PCI Express Card Reader (rev 01)
10000:e0:06.0 System peripheral: Intel Corporation RST VMD Managed Controller
10000:e0:06.1 PCI bridge: Intel Corporation Device 7eca (rev 10)
10000:e1:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO
v4l2-ctl --list-devices
Cannot open device /dev/video0, exiting.
It’s an Intel Core Ultra 7 processor 165H and I use kernel 6.8.8-2 (because with 6.6 speakers were not working). Camera is turned on in BIOS.
I have found that maybe I need to do something with IPU6 drivers but to be honest I’m not really sure what/how to do it.
Thank you.
