I’m not 100% sure how you define “useful” but here is all I have:
inxi full
$ sudo inxi --admin --verbosity=8 --filter --no-host --width --repos
[sudo] password for nico:
Kernel: 6.6.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=bc2a29f9-9eae-4a93-995f-25e14a30f086 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: Framework product: Laptop v: AA serial: <filter>
Mobo: Framework model: FRANBMCP0A v: AA serial: <filter>
part-nu: FRANBZCP0A uuid: e41aaf6b-a76f-ec11-810f-309846000630 UEFI: INSYDE
v: 03.07 date: 12/14/2021
ID-1: BAT1 charge: 52.4 Wh (100.0%) condition: 52.4/55.0 Wh (95.3%)
volts: 17.4 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
status: not charging
System RAM: total: 16 GiB available: 15.41 GiB used: 6.34 GiB (41.1%)
igpu: 60 MiB
Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 width (bits): data: 64
total: 64 manufacturer: SK Hynix part-no: HMA81GS6DJR8N-XN serial: <filter>
Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
Slot: N/A type: N/A lanes: 1 status: available info: M.2, JWLAN length: other
bus-ID: 00:1d.0
Slot: N/A type: N/A lanes: 4 status: in use info: M.2, JSSD length: other
bus-ID: 00:06.0 children: 1: 01:00.0 class-ID: 0108 type: mass-storage
Info: model: 11th Gen Intel Core i5-1135G7 socket: U3E1 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 899 high: 4200 min/max: 400/4200 base/boost: 2400/4200
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 598 2: 400 3: 400 4: 4200 5: 400 6: 400 7: 400
8: 400 bogomips: 38720
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Framework
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: DP-4 off: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Dell Integrated_Webcam_5M_IR driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6.4:29 chip-ID: 413c:c01d
Display: server: X.Org v: 23.2.5 with: Xwayland v: 23.2.5
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :1 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: DP-4 model: Dell S2722DZ serial: <filter> built: 2022
res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.671 y: 0.325 green:
x: 0.310 y: 0.620 blue: x: 0.145 y: 0.059 white: x: 0.314 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 1920x1080, 1600x1200, 1400x1050, 1600x900, 1280x1024, 1152x864,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
Monitor-2: eDP-1 model: BOE Display 0x095f built: 2019 res: 2256x1504
dpi: 201 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 285x190mm (11.22x7.48") diag: 343mm (13.5") ratio: 3:2
modes: 2256x1504
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 15.05 GiB unified: yes
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
name: Intel Xe Graphics (TGL GT2) driver: mesa intel v: 24.0.2-manjaro1.1
device-ID: 8086:9a49 surfaces: xcb,xlib
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Framework
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Device-2: Dell S2722DZ driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6.3:30
chip-ID: 413c:c01c class-ID: 0300
API: ALSA v: k6.6.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3:4
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s13f0u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:7 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 2.05 TiB used: 1.38 TiB (67.5%)
model: PC SN730 SDBPNTY-256G size: 238.47 GiB block-size: physical: 512 B
fw-rev: 11140000 temp: 42.9 C scheme: GPT
SMART: yes health: PASSED on: 27d 6h cycles: 265
read-units: 7,604,363 [3.89 TB] written-units: 10,835,587 [5.54 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7 size: 1.82 TiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 10 Gb/s
lanes: 1 mode: 3.2 gen-2x1 tech: SSD serial: <filter> fw-rev: FXG42P2Q
temp: 39 Celsius C scheme: GPT
SMART: yes health: PASSED on: 89d 7h cycles: 15
read-units: 8,198,465 [4.19 TB] written-units: 6,328,661 [3.24 TB]
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 29.25 GiB (12.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: bc2a29f9-9eae-4a93-995f-25e14a30f086
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 89B3-A228
ID-3: /run/media/nico/silo-data raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.36 TiB (75.8%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: silo-data uuid: 0c4633a6-31aa-44a1-93b0-d3bfc10c51ec
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 2-2:2 info: Samsung PSSD T7 type: mass storage driver: uas
interfaces: 1 rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1
power: 896mA chip-ID: 04e8:4001 class-ID: 0806 serial: <filter>
Device-2: 2-3:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
Hub-3: 2-4:5 info: Realtek USB3.2 Hub ports: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0409
Hub-4: 2-4.1:6 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0812
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Hub-6: 3-6:11 info: Realtek USB2.1 Hub ports: 6 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5409
Hub-7: 3-6.1:12 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
Device-1: 3-6.2:13 info: Logitech Logi Bolt Receiver
type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-2: 3-6.3:30 info: Dell S2722DZ type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Device-3: 3-6.4:29 info: Dell Integrated_Webcam_5M_IR type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 413c:c01d class-ID: 0e02 serial: <filter>
Device-4: 3-6.5:15 info: Realtek BillBoard Device type: billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 chip-ID: 0bda:5418 class-ID: 1100
Device-5: 3-6.6:16 info: Realtek HID Device type: HID
chip-ID: 0bda:1100 class-ID: 0300
Device-6: 3-9:5 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:609c class-ID: ef00 serial: <filter>
Device-7: 3-10:7 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1323 libs: 369 tools: pamac
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
4: https://mirror.23m.com/manjaro/stable/$repo/$arch
5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 258
1: cpu: 6.7% command: librewolf pid: 180951 mem: 220.8 MiB (1.3%)
2: cpu: 2.8% command: signal-desktop pid: 8254 mem: 341.2 MiB (2.1%)
3: cpu: 1.9% command: librewolf pid: 14359 mem: 832.0 MiB (5.2%)
4: cpu: 1.4% command: kwin_wayland pid: 682 mem: 331.0 MiB (2.0%)
5: cpu: 1.2% command: librewolf pid: 179829 mem: 318.9 MiB (2.0%)
Memory top: 5 of 258
1: mem: 832.0 MiB (5.2%) command: librewolf pid: 14359 cpu: 1.9%
2: mem: 742.1 MiB (4.7%) command: thunderbird pid: 7721 cpu: 0.5%
3: mem: 484.4 MiB (3.0%) command: soffice.bin pid: 173284 cpu: 0.1%
4: mem: 375.2 MiB (2.3%) command: plasmashell pid: 814 cpu: 0.4%
5: mem: 349.2 MiB (2.2%) command: signal-desktop pid: 8036 cpu: 0.0%
Processes: 258 Power: uptime: 18h 5m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.15 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Sudo (sudo) v: 1.9.15p5
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
Build instructions with pictures here.
Next I could hop on a train to Augsburg. I’m down here at the Ammersee
