there are a lot of possible issues. this could be one of them. another one that is worth to check and exclude from the list is your bios. it’s from 2021. is a newer one avaiable? check the manufacturer if a newer one exists.
UEFI: INSYDE v: 03.07 date: 12/14/2021
one thing you could check is the following. use an editor and edit the
/etc/default/grub
in the line
GRUB_CMDLINE_LINUX_DEFAULT="
add the following to the existing entries
intel_iommu=off
you need sudo rights for editing. kate is a good editor that will ask for sudo-password if you wanna store the file back.
after editing run
sudo mkinitcpio -P
sudo update-grub
reboot and check if there is a change in behaviour. keep in mind this is just a test. to undo the setting reverse it by deleting the added entry and run the
Unfortunately no. I checked with fwupd. To be honest, I’m overall not too impressed by the laptop. The display was faulty on delivery and the wifi signal is terrible. I bought it because Cory Doctorow has it and said it’s cool :o)
Consider me impressed! With this the issue is actually gone :-o
Thank you for that tip too. I usually use nano for these sudo edits but as a matter of fact I just ditched sublime edit as my last proprietary software for kate when I switched to KDE a while ago. I really love it so far - just like the rest of Plasma. Lots of attention to detail.
So leaving iommu off is probably not a good option, hm? I think I should replace the laptop with a desktop machine. It constantly boots to the internal screen anyway and I have it stowed under my desk so that’s a pain every time.
it’s always good to give a summary for others that might read this topic in future because they suffer the same or similar problem.
keep in mind that this problem seems to be related to the implementation of the linux-firmware and the intel-cpu. this might change in future. therefore it’s good to test if newer kernels and firmware will solve it in future. undo the changes after upgrades to newer kernels and test if it runs without problems otherwise use this method to override the problem.
