I have a DELL Lattitude 7285 (2-in-1, detachable) laptop, the only problem I am experiencing is that the cameras (inner and outer) do not work. According to hardware specification there shouls be:
Inner:
- IR camera (Realtek)
- 2 regular cameras
- light sensor
Outer:
- camera with autofocus
In /dev there are listed video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video2
/dev/video3
/dev/video4
/dev/video5
/dev/video6
/dev/video7
/dev/video8
/dev/video9
I tried to identify these using V4L2 (output bellow) since lsusb nor lspci had any information regarding cameras (could not find anything like cam, Realtek or IPU3).
I tried to get image using V4L2 Test Utility (with driver IPU3-CIO2).
I found mention of Libcamer according to their documentation is seems not to solve my problem, that is want to use cameras for usual purposes such as videoconferencing.
Thank you for any suggestions on how to get cameras working.
Notes:
Cameras work flawless using Windows 10
GNOME detects light conditions using lighsensor without problem
Output of lpci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 615 (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
00:05.0 Multimedia controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging Unit (rev 01)
00:13.0 Non-VGA unclassified device: Intel Corporation Sunrise Point-LP Integrated Sensor Hub (rev 21)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:14.3 Multimedia controller: Intel Corporation CSI-2 Host Controller (rev 01)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
00:15.2 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #2 (rev 21)
00:15.3 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #3 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:16.3 Serial controller: Intel Corporation Sunrise Point-LP Active Management Technology - SOL (rev 21)
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #10 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Device 9d4b (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
02:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
02:01.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
02:02.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
02:04.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
37:00.0 USB controller: Intel Corporation JHL6540 Thunderbolt 3 USB Controller (C step) [Alpine Ridge 4C 2016] (rev 02)
6c:00.0 Non-Volatile memory controller: Toshiba Corporation BG3 NVMe SSD Controller (rev 01)
6d:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
Output of inxi:
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
Desktop: GNOME 3.36.6 Distro: Manjaro Linux
Type: Detachable System: Dell product: Latitude 7285 v: N/A
serial: <filter>
Mobo: Dell model: 0M2PP1 v: A00 serial: <filter> UEFI [Legacy]: Dell
v: 1.7.0 date: 11/13/2019
ID-1: BAT0 charge: 28.4 Wh condition: 28.4/34.0 Wh (84%)
model: SMP DELL C668F68J status: Full
ID-2: BAT1 charge: 15.8 Wh condition: 15.8/20.9 Wh (75%)
model: BYD DELL 6HHW502G status: Full
Topology: Dual Core model: Intel Core i5-7Y57 bits: 64 type: MT MCP
arch: Amber Lake rev: 9 L2 cache: 4096 KiB
bogomips: 12805
Speed: 500 MHz min/max: 400/3300 MHz Core speeds (MHz): 1: 500 2: 501
3: 500 4: 500
Device-1: Intel HD Graphics 615 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0
Display: x11 server: X.org 1.20.8 driver: intel unloaded: modesetting
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel HD Graphics 615 (KBL GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit
vendor: Dell driver: ipu3-imgu bus ID: 00:05.0
Device-2: Intel CSI-2 Host vendor: Dell driver: ipu3-cio2 bus ID: 00:14.3
Device-3: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f040
bus ID: 6d:00.0
IF: wlp109s0 state: up mac: <filter>
Local Storage: total: 238.47 GiB used: 40.60 GiB (17.0%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG20ZMS256G NVMe 256GB
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 bus ID: 00:17.0
ID-1: / size: 27.93 GiB used: 12.40 GiB (44.4%) fs: ext4
dev: /dev/nvme0n1p1
ID-2: /home size: 197.01 GiB used: 28.20 GiB (14.3%) fs: ext4
dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 250 Uptime: 1h 42m Memory: 7.38 GiB used: 1.48 GiB (20.0%)
Init: systemd Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1317
Shell: Zsh v: 5.8 inxi: 3.1.05
Output of v4l2-compliance
v4l2-compliance SHA: not available, 64 bits, 64-bit time_t
Compliance test for ipu3-cio2 device /dev/video0:
Driver Info:
Driver name : ipu3-cio2
Card type : Intel IPU3 CIO2
Bus info : PCI:0000:00:14.3
Driver version : 5.8.6
Capabilities : 0x84201000
Video Capture Multiplanar
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04201000
Streaming
Extended Pix Format
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second /dev/video0 open: OK
test VIDIOC_G/S_PRIORITY: OK
test for unlimited opens: OK
test invalid ioctls: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK (Not Supported)
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Control ioctls (Input 0):
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK (Not Supported)
test VIDIOC_QUERYCTRL: OK (Not Supported)
test VIDIOC_G/S_CTRL: OK (Not Supported)
test VIDIOC_G/S/TRY_EXT_CTRLS: OK (Not Supported)
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK (Not Supported)
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 0 Private Controls: 0
Format ioctls (Input 0):
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
test VIDIOC_G/S_PARM: OK (Not Supported)
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
test VIDIOC_S_FMT: OK
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
test Scaling: OK
Codec ioctls (Input 0):
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls (Input 0):
fail: v4l2-test-buffers.cpp(717): q.create_bufs(node, 1, &fmt) != EINVAL
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: FAIL
test VIDIOC_EXPBUF: OK
test Requests: OK (Not Supported)
Total for ipu3-cio2 device /dev/video0: 45, Succeeded: 44, Failed: 1, Warnings: 0
