I installed the linux59.
echo /dev/video* | tr -d '\n' | xargs -n 1 -d ' ' timeout 3 qvidcap -d
Still outputs the same.
Here is the output of sudo lspci -v
00:00.0 0600: 8086:590c (rev 02)
Subsystem: 1028:07a5
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=10 <?>
Kernel driver in use: skl_uncore
00:02.0 0300: 8086:591e (rev 02) (prog-if 00 [VGA controller])
DeviceName: Onboard IGD
Flags: bus master, fast devsel, latency 0, IRQ 141
Memory at eb000000 (64-bit, non-prefetchable) [size=16M]
Memory at 60000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] Page Request Interface (PRI)
Kernel driver in use: i915
Kernel modules: i915
00:04.0 1180: 8086:1903 (rev 02)
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at ec630000 (64-bit, non-prefetchable) [size=32K]
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 3
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device
00:05.0 0480: 8086:1919 (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 139
Memory at ec000000 (64-bit, non-prefetchable) [size=4M]
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [a0] PCI Advanced Features
Kernel driver in use: ipu3-imgu
Kernel modules: ipu3_imgu
00:13.0 0000: 8086:9d35 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 20
Memory at ec64c000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [80] Power Management version 3
Kernel driver in use: intel_ish_ipc
Kernel modules: intel_ish_ipc
00:14.0 0c03: 8086:9d2f (rev 21) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 136
Memory at ec620000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 1180: 8086:9d31 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at ec64b000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [50] Power Management version 3
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.3 0480: 8086:9d32 (rev 01)
Flags: bus master, fast devsel, latency 32, IRQ 138
Memory at ec610000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: ipu3-cio2
Kernel modules: ipu3_cio2
00:15.0 1180: 8086:9d60 (rev 21)
Memory at ec64a000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [90] Vendor Specific Information: Len=14 <?>
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 1180: 8086:9d61 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at ec649000 (64-bit, non-prefetchable) [size=4K]
00:15.2 1180: 8086:9d62 (rev 21)
Memory at ec648000 (64-bit, non-prefetchable) [size=4K]
00:15.3 1180: 8086:9d63 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at ec647000 (64-bit, non-prefetchable) [size=4K]
00:16.0 0780: 8086:9d3a (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 137
Memory at ec646000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: mei_me
Kernel modules: mei_me
00:16.3 0700: 8086:9d3d (rev 21) (prog-if 02 [16550])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 19
I/O ports at f0a0 [size=8]
Memory at ec645000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [40] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel driver in use: serial
00:17.0 0104: 8086:282a (rev 21)
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 131
Memory at ec640000 (32-bit, non-prefetchable) [size=8K]
Memory at ec644000 (32-bit, non-prefetchable) [size=256]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at ec643000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Kernel driver in use: ahci
00:1c.0 0604: 8086:9d10 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=01, subordinate=6b, sec-latency=0
I/O behind bridge: 00002000-00005fff [size=16K]
Memory behind bridge: bc000000-ea0fffff [size=737M]
Prefetchable memory behind bridge: 0000000070000000-00000000b9ffffff [size=1184M]
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [90] Subsystem: 1028:07a5
Capabilities: [a0] Power Management version 3
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Access Control Services
Capabilities: [220] Secondary PCI Express
Kernel driver in use: pcieport
00:1c.4 0604: 8086:9d14 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=6c, subordinate=6c, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: ec500000-ec5fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Capabilities: [200] L1 PM Substates
00:1d.0 0604: 8086:9d19 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124
Bus: primary=00, secondary=6d, subordinate=6d, sec-latency=0
Memory behind bridge: ec400000-ec4fffff [size=1M]
00:1f.0 0601: 8086:9d4b (rev 21)
00:1f.2 0580: 8086:9d21 (rev 21)
Memory at ec63c000 (32-bit, non-prefetchable) [size=16K]
00:1f.3 0403: 8086:9d71 (rev 21) (prog-if 80)
Flags: bus master, fast devsel, latency 32, IRQ 142
Memory at ec638000 (64-bit, non-prefetchable) [size=16K]
Memory at ec600000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl
00:1f.4 0c05: 8086:9d23 (rev 21)
Flags: medium devsel, IRQ 16
Memory at ec642000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
6c:00.0 0108: 1179:0113 (rev 01) (prog-if 02 [NVM Express])
Subsystem: 1179:0001
Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0
Memory at ec500000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Express Endpoint, MSI 00
Capabilities: [90] MSI: Enable- Count=1/32 Maskable+ 64bit+
Capabilities: [b0] MSI-X: Enable+ Count=32 Masked-
Capabilities: [150] Virtual Channel
Capabilities: [260] Latency Tolerance Reporting
Capabilities: [300] Secondary PCI Express
Capabilities: [400] L1 PM Substates
Kernel driver in use: nvme
6d:00.0 0280: 8086:24fd (rev 78)
Subsystem: 8086:0050
Flags: bus master, fast devsel, latency 0, IRQ 140
Memory at ec400000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [140] Device Serial Number 34-41-5d-ff-ff-87-35-5c
Capabilities: [14c] Latency Tolerance Reporting
Capabilities: [154] L1 PM Substates
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
If I understand the page about configuration correctly (kernel documentation), the problem could be solved if I cold get the correct pipe setup, possibly inspired by data from windows driver (similarly to the case of MS Surface). Correct?
Only problem is that I did not do a dual boot install (to avoid all problem of such approach), so I would have reinstall W10 from backup, that would overwrite Manjaro.
